Results 41 to 60 of 65
Thread: Ls1 To Ls6?
03-30-2007, 07:14 AM #41
I'd have to say thats a pretty dang good deal....If I had the $$$$, I'd probably buy one right now lol
-Will
04-04-2007, 04:18 AM #42
- Mar 2007
- SE of Pittsburgh PA
White- 1998 Pontiac TransAM WS6
Ok I installed this package, and everything went well until I attempted to mount the coils. My car is a 98 with the perimeter bolt valve covers, and the coil mounts moulded in. I got valve covers off a 2003 truck, that fit, but I could not figure which of the 12 coil mounts to use. So I purchased what I thought would work from the pictures, and they did not work. Then I got smart, and contacted a local shop specializing in F-bodys, and he knew exactly what I needed. They have been ordered, and should arive this afternoon. Hopefully it will be running tonight, if nothing else goes wrong.
Tracey
04-04-2007, 04:30 AM #43
04-07-2007, 08:09 PM #44
- Mar 2007
- Omar's Tittie Taverna & Grill, Deh Rawod
18D Cock Diesel- 1999 Z28; 98 SS #2043 RIP
I just contacted the seller too. I am waiting to hear back from him. I hope that you like it. let us know how it feels as soon as you get her running. Take pics too. Also, could you please let us know what covers and coils, etc...you used. Like an additional needed parts list or something. I have a 98 SS that I want to do this to.
Did you have to drop the engine to do the work?
04-08-2007, 04:53 AM #45
- Mar 2006
- Long Island, NY
Hugger Orange- 1999 Camaro Z-28
nope - just come in from obove
remove radiator & pull the pwr steer pump off (dont waste time with the pulley
just get everything out of the way & your set to go
www.ls1howto.com
04-08-2007, 04:55 AM #46
- Mar 2007
Thanks...will do!!
04-10-2007, 05:26 AM #47
- Mar 2007
Ok I did this swap, and had several issues, since my car is a 98.
1. The valve covers on the 98's use perimeter bolts, and these heads use center bolts. Found a junk yard set no problem.
2. Coils on 98 bolt directly to the valve covers. Had to purchase the coil mounts.
3. PVC connections are in different place, so some modification of the original plumbing had to be done.
Don't forget to transfer all of the plugs over off of the old heads, especially the coolant temperature plug on the right head.
She fired right up, and idled fine, with no programming.
Now having said all of that my original problem is still there. I have a ticking noise that sounds like a valve tick. I will open a new thread to discuss this problem.
This would be a lot easer swap on a 99 or newer model.
That is all I have for now.
Tracey
04-21-2007, 04:56 AM #48
Was you ever ablt to run out your car with the conversion? If so how does it perform?
04-22-2007, 03:21 AM #49
- Mar 2007
No, I was not able to test it.
My original ticking problem is still there.
So now the motor is at the machine shop, and I am having it totaly rebuilt. Every nut and bolt is to be removed and checked. Including these new heads, just to make sure. This is so frustrating!!!
Tracey
04-22-2007, 07:08 AM #50
- Jun 2006
- USA
- 2001 WS6, 2003 SRT4(sold)
I want this!
04-22-2007, 09:21 AM #51
- Mar 2007
I was just given the link to his new auction and bought this setup. Hopefully, its all its cracked up to be. We'll see. I'm thinking about upgrading the roller rockers to 1.7. Do you guys think its worth the expense?
04-22-2007, 09:59 AM #52
subscibed. to all who are doing this, update frequently with pics if you can.
05-03-2007, 03:42 PM #53
05-04-2007, 04:36 AM #54
- Mar 2007
Well mine is still sitting at the machine shop. I won't know much until I get it all back together.
05-04-2007, 06:47 AM #55
- Mar 2006
- Long Island, NY
ticking...
many people have some ticking issues after a swap...
naturally these ls1's are known to have a sewing machine sound after a swap
then again if you went with a ZO6 cam it shouldn't....
one very important aspect that is overlooked & wasn't thought of when the how to on ls1howto.com was written up
the oil pump pick up tube o-ring (blue) MUST be replaced if oil pump pick up tube is disconnected (ie changing timing chain to LS2 and/or swapping out the oil pump which i HIGHLY reccomend)
once the o-ring is compressed it is not re-usable
if put back together with out replacing & installed properly you should still have good oil pressure....
however
@ idle there may not be a tick but ticking will occur or get louder when the engine is under a load... this happens bc of aeration due to the old seal/o-ring
remember though oil pressure will still read good.....
once the load is released good oil is getting to the lifters & the ticking will stop/become more settle again
now we tear apart my friends car again to replace the $3-$5 o ring....
so drop k-member & oil pan to not pull the front apart again and install rod bolts
may as well make it worth it
(we're going to try and not drop the K.... but im not holding my breath it will work)
05-04-2007, 07:52 AM #56
05-05-2007, 06:23 AM #57
- Mar 2006
- Long Island, NY
part numbers
oil pump pick up tube o-ring/seal
12557752
LS6 oil pump
12586665
LS2 timing chain
12586482
05-13-2007, 02:59 PM #58
- Mar 2007
Mine is finally in the shop and getting this kit installed along with a ford 9" rear with detroit true trac POSI and 3.73 gears. I can't wait to get it back. Hopefully it adds some good power.
05-14-2007, 07:46 AM #59
- Mar 2006
- Long Island, NY
keep us updated with the before/after swap/after swap + tune dyno graphs please
05-14-2007, 11:32 AM #60
- Nov 1999
- over here...
i bought a crate LS6 and dropped that in...
