Results 41 to 60 of 61
12-09-2009, 10:31 AM #41
- Jan 2009
- North Jersey
My friend is considering an LS7 for his 05 goat. He can't make up his mind though. He had the LS2 built up, chipped a piston, had the car de-modded and put it up for sale. Now he is considering forced induction for the LS2, or a forged bottom end, or an LS7. I just told him to go for the gold and go with an LS9. He thinks I'm crazy.
12-09-2009, 06:43 PM #42
- Jan 2009
- North Jersey
I like this
[ame]http://www.youtube.com/watch?v=L7nzC2JRxOM[/ame]
12-09-2009, 07:11 PM #43
- Mar 2007
- Ontario, Canada
yellow- 02 Collector Trans Am
check out this solstice!!
http://cgi.ebay.com/ebaymotors/2009-...item33581dbb4a
I think it looks sick
12-09-2009, 07:16 PM #44
12-09-2009, 09:47 PM #45
12-10-2009, 04:50 AM #46
12-10-2009, 06:59 AM #47
12-10-2009, 09:24 AM #48
I was looking those on edmunds yesterday. They are lighter and more powerful than the Z4 coupe. Just not as nice but I'm sure cheaper to maintain. FYI the Solstice coupe is about 10K more than the used 2006 Z4 coupe.
Originally Posted by shady milkman
Just pick one:
"LS1, LS6,LS2, LS3, L99, LS4, LS7, LS9 And LSA Engine History - LS Engine And LSX History
LS1/LS6
LS1 5.7L (346-cu-in) engines were produced between the 1997 and 2004 model years in the United States (Corvette, Camaro, Firebird and GTO) and stretching into 2005 in other markets (primarily Australia). The LS6 was introduced in 2001 in the Corvette Z06 and was manufactured through 2005, where it also was found in the first generation of the Cadillac CTS-V. The LS1 and LS6 share a 5.7L displacement, but the LS6 production engine uses a unique block casting with enhanced strength, greater bay-to-bay breathing capability and other minor differences. The heads, intake manifolds and camshaft also are unique LS6 parts.
LS2
In 2005, the LS2 6.0L (364 cu in) engine and the Gen IV design changes debuted. In GM performance vehicles, it was offered in the Corvette, GTO and even the heritage-styled SSR roadster. It is the standard engine in the Pontiac G8 GT. Its larger displacement brought greater power. The LS2 is one of the most adaptable engines, as LS1, LS6, LS3 and L92 cylinder heads work well on it.
LS3/L99
Introduced on the 2008 Corvette, the LS3 brought LS base performance to an unprecedented level: 430 horsepower from 6.2L (376 cu in) - making it the most powerful base Corvette engine in history. The LS3 block not only has larger bores than the LS2, but a strengthened casting to support more powerful 6.2L engines, including the LS9 supercharged engine of the Corvette ZR1. The LS3 is offered in the Pontiac G8 GXP and is also the standard V-8 engine in the new, 2010 Camaro SS. The L99 version is equipped with GM's fuel-saving Active Fuel Management cylinder deactivation system and is standard on 2010 Camaro SS models equipped with an automatic transmission.
LS4
Perhaps the most unique application of the LS engine in a car, the LS4 is a 5.3L version used in the front-wheel-drive Chevrolet Impala SS and Pontiac Grand Prix GXP. The LS4 has an aluminum block and unique, low-profile front-end accessory system, including a "flattened" water pump, to accommodate the transverse mounting position within the Impala and Grand Prix. It is rated at 303 horsepower and 323 lb-ft of torque.
LS7
A legend in its own time. The LS7 is the standard engine in the Corvette Z06 and its 7.0L displacement (427 cubic inches) makes it the largest LS engine offered in a production car. Unlike LS1/LS6, LS2 and LS3 engines, the LS7 uses a Siamese-bore cylinder block design - required for its big, 4.125-inch bores. Competition-proven heads and lightweight components, such as titanium rods and intake valves, make the LS7 a street-tuned racing engine, with 505 horsepower. LS7 engines are built by hand at the GM Performance Build Center in Wixom, Mich.
LS9
The most powerful production engine ever from GM, the LS9 is the 6.2L supercharged and charge-cooled engine of the Corvette ZR1. It is rated at an astonishing 638 horsepower. The LS9 uses the strengthened 6.2L block with stronger, roto-cast cylinder heads and a sixth-generation 2.3L Roots-type supercharger. Like the LS7, it uses a dry-sump oiling system. It is the ultimate production LS engine. It is built by hand at the GM Performance Build Center in Wixom, Mich.
LSA
A detuned version of the LS9, this supercharged 6.2L engine is standard in the 2009 Cadillac CTS-V. It is built with several differences, when compared to the LS9, including hypereutectic pistons vs. the LS9's forged pistons; and a smaller, 1.9L supercharger. The LSA also has a different charge-cooler design on top of the supercharger. Horsepower is rated at 556 in the super-quick Caddy."
Block quote bc I'm feeling lazy.
12-10-2009, 09:59 AM #49
12-10-2009, 10:54 AM #50
12-10-2009, 10:58 AM #51
12-10-2009, 11:17 AM #52
12-10-2009, 12:42 PM #53
The thought I had was about the LS3 and its bore compared with the LS7. I grabbed the wrong article on top of it. This is what I was thinking of:
"LS9
The big hoss in LS land, at least for the moment, is the factory-supercharged 638hp small-block that powers the new Corvette ZR1. Not only is the Gen IV LS9 the most powerful engine ever conceived by GM, it easily produces the fattest torque curve of any Chevy in history. While its torque peak of 604 lb-ft at 3,800 rpm is very impressive, the fact that it belts out 350 lb-ft at just 1,000 rpm is downright breathtaking. At its core, the LS9 shares more in common with the LS3 and L92-found in base Corvettes and Cadillac Escalades, respectively-than the LS7. To enhance block rigidity, GM passed on the LS7's 4.125-inch bore dimensions for the thicker cylinder walls afforded by smaller 4.065-inch holes. Furthermore, the block is cast from 319-T7 aluminum and features larger bulkheads, which makes it substantially stronger than prior LS units. It encases a steel crank, titanium rods, and forged 9.1:1 pistons. With a remarkably efficient 2.3L Eaton blower huffing out 10.5 psi through a dual-core intercooler, the exotic race-ported 12-degree LS7 cylinder heads were deemed unnecessary. Instead, GM opted for 15-degree rectangle-port castings that are very similar in design to the L92 and LS3 heads, but built from more durable A-356T6 aluminum. Sometime this summer, GM Performance Parts will start selling complete LS9 crate motors (PN: 19201990) for about $22,000. Granted that isn't cheap, it's still a heck of a lot less than trying to replicate a motor of this caliber that's also emissions legal and capable of lasting 100,000 miles. Moreover, the rugged LS9 block will certainly be a popular foundation for LS stroker buildups once it's released.
DISPLACEMENT: 376 ci
BLOCK: Cast aluminum
HEADS: Aluminum 15-degree rectangle port
BORE/STROKE: 4.065 x 3.622
COMPRESSION: 9.1:1
CAMSHAFT: 211/230 @ 0.050; 0.562/0.558; 122.5
OUTPUT: 638 hp and 604 lb-ft
WHAT IT’S IN: '09+ Corvette ZR1
GMPP PN: 19201990"
Full article at:
www.chevyhiperformance.com
12-10-2009, 12:43 PM #54
12-10-2009, 12:47 PM #55
- Jan 2009
- North Jersey
$22k for an LS9? Daaaaaaaaaayum!!! That's more than a RamJet 572!!
12-11-2009, 04:33 AM #56
12-11-2009, 04:35 AM #57
12-13-2009, 10:09 PM #58
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
12-13-2009, 10:26 PM #59
12-14-2009, 04:50 AM #60
- Jan 2006
- Shepherd, Michigan
justin i should slap you in the face for posting those pictures
What will happen to Solstice/Sky
By predator in forum Domestics and ForeignsReplies: 21Last Post: 01-13-2010, 03:28 PM -
Solstice...
By blue02Z in forum Kill StoriesReplies: 15Last Post: 09-09-2007, 06:04 PM -
My new wheels: Solstice GXP
By Warbird in forum Member's RidesReplies: 6Last Post: 06-06-2007, 09:04 AM -
LS7 Solstice
By SexyTransAm in forum Multimedia SectionReplies: 0Last Post: 04-24-2007, 09:26 PM
