Results 41 to 60 of 134
Thread: How to run your LS1 on E85
11-10-2006, 01:20 PM #41
- Retired Outlaw Sum Bitch
You know....I am curious of the blend quality control with this stuff...who regulates it and who "signs off" it has not been contaminated with copious amounts of moisture after it has left the plant that produced it? In other words....I think we are having a raging agreement the transport of this stuff itself can introduce large amounts of water into the E85....by the time it gets to the "blending facility" it may have a shitload of water in it....due improper storage or transport.....is this a possible explanation?
11-10-2006, 01:20 PM #42
11-10-2006, 01:24 PM #43
Actually...and I will go a hunting for it...GM recommends not using it at all in our engines....that is why I had a flaming/old man blow out when I saw this kid posting this stuff as if it was just tune here and tweak there.....it is misleading as hell and could cost somebody a shitload of parts replacement money if one just took his post as "sticky worthy"....
11-10-2006, 01:24 PM #44
11-10-2006, 01:25 PM #45
11-10-2006, 01:32 PM #46
All the new GTO are returnless....04/05 and 06's.....as is my 408 Stroker...all LS1's are returnless if I remember correctly....and to answer.....a returnless system does not allow any "flushing"....everything offered up to the rails goes into the injectors...problem with water/contaminates is they have a totally different volume and "gather" along the edges as the lighter fuel flows around/over them....
11-10-2006, 01:34 PM #47
Well dammit boys, I'm gettin thirsty. All this serious talk at the end of a workday on Friday has my favorite beverage calling my name! Have a great weekend!
11-10-2006, 01:37 PM #48
11-10-2006, 01:38 PM #49
11-10-2006, 01:40 PM #50
After I posted that, I re-read your post and realized what you were asking, my bad. As far as that goes, we had some f*cknut try to reject our load of product because it had diesel in it
I told them it was their problem they didn't completely empty their tanker before coming to pick up their load here. You see, I don't think those issues are solely with ethanol blended fuel, but rather any fuel.
11-10-2006, 01:42 PM #51
11-10-2006, 01:42 PM #52
11-10-2006, 01:43 PM #53
11-10-2006, 01:44 PM #54
11-10-2006, 01:53 PM #55
Nah...I got some home brew that will blind you for an hour and make you howl at the moon for a couple of days....I'll stick with the good stuff and wait on our Swedish pal to respond here.....
So damn good mature discussion......Is it fair to summarize?
We all in agreement to tune your car back and forth is bullshit? That E85 is corrosive and will damage aluminum parts? Or not?
11-10-2006, 05:49 PM #56
- Thornton, CO
Honestly, there is ONE station local to me that doesn't sell an ethanol mix fuel.
I haven't heard of any issues with any cars around here.
I do try to fill up at that one station...but it doesn't always happen.
My car is 7 years old and just this spring I replaced several parts of my fuel system. All looked good when removed from the car.
That is all I have though.
11-10-2006, 09:28 PM #57
- Oct 2006
- Seaford
Black- 2001 Trans Am
between fasstchevys and sarge, where the hell was the swedish threadstarter in all of this?
11-10-2006, 09:36 PM #58
11-11-2006, 12:59 AM #59
1. Yes this is a problem. They are not yet using E75 in Sweden but they are talking about it. But it looks like this is the system thats going to be used.
But since i dont use my car in the winter it´s not a problem for me but i understand that it might be different in USA.
But the Lambda adjustment doesn´t have any problems with compensating for the small different between E85 and E75. You already have pumps with E10 (and there are talking about E20 correct?) and pumps without and the cars are adjusting for the difference without trouble.
We have a HUGE carpark with cars that have been convertaed be the owners themself and we are trying to convince the goverment not to use E75 or atleast give us the option to decide for usself which fuel to use.
But yes it is a problem. I want my car to have a perfect tune and it isn´t possible if the fuel is changing... But it is only two times a year, And i like to tune... But if you dont have a tuner i understand your problem or if you cant get the fuel you want. Here we have E85 everywhere.
2. Yes, Water contamination is a problem, I agree.
It would be really interesting to see a test done on an open and closed fueltank, How long time it takes for the E85 to suck up water from the air to the point to it is dangerous to use. It might come in the future, But up til then keep your fueltanks closedI only damage i have seen from E85 yes is a rubber hose that couldn´t take it on my -82 Datsun
Yes it is possible to run it on E85, Hell i even run my lawnmower on E85. I just wish i had a Turbocar to experiment on. Since E85 is perfect for boost, I have many friends here in Sweden with forced induction that use E85... Thanks to the cooling effects and higher octane you can use alot more boost.
Just look at the Saab 9-5 Turbo with Biopower engine (big seller here in Sweden) that when it is fueled with E85 gives 20% more hp and 16% more torque compared with regular gas.
Water contaminated fuel from the pump isn´t much you and i can do anything about but hoping the gascompanies have there shit together
Is E85 more toxic or dangerous than gasoline?
No. 100% ethanol (not 100% E85) can be and is ingested by human beings. The fuel ethanol must be "denatured" with gasoline or a bitter agent to prevent ingestion. Also, ethanol does not contain the harmful carcinogens and toxins found in gasoline.
Statement below is taken from the flextek page.
If I have a gasoline vehicle and convert it to alcohol, am I going to damage the engine?
No. There are currently over 50,000 vehicles on the road using the FlexTek to burn alcohol fuels. There have been no reports of engine damage due to the conversion. In fact, burning alcohol instead of gasoline has been shown to decrease engine oil contamination and extend engine life. Alcohol burns cooler than gasoline providing additional benefits in terms of engine life and performance.
BTW i will copy and paste this post in the thread on the other forum which cant be named here, this info was made for that forum from the start but since i post here from time to time i thought i would be i nice fellow and post it here aswell. OuchBoy was i wrong. I wont post any more here since i dont feel welcome. I have gotten a few "hatemail" since i started this thread aswell, I wont post any names, You know who you are...
Bye.
If you have more question feel free to post in the other thread.Last edited by Runn_WS7; 11-11-2006 at 01:11 AM.
www.ws7.se
http://www.ls1.com/forums/showthread.php?t=1249
Running on E85
Twin Turbo Project Started
Hello from Sweden.
11-11-2006, 02:48 AM #60
