Page 251 of 357 FirstFirst ... 51101151201211221231247248249250251252253254255271281291301351 ... LastLast
Results 5,001 to 5,020 of 7122
  1. #5001
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Lol my Christmas was late this year
    Sent from my HTC6535LVW using Tapatalk
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
  2. #5002
    Greensboro, NC
    2002 Trans Am WS6 M6
    Finally finished ordering everything now just waiting for the stuff to arrive. Still waiting on seat covers, strano sway bars, rear konis, umi a arm kit and hardware, the vette shift knob. My office is starting to look like a car part storage room.
    Full list of stuff that will be going on the car this spring as follows. All new suspension components - Strano sway bars and springs, Koni yellow on car adjustable shocks/struts, UMI upper and lower a arms, Founders lower control arms and pan hard bar (cheaper then replacing the rod ends on the UMI pieces with their roto joints), Founders torque arm, UMI torque arm relocation kit, MWC drive shaft safety loop, real leather seat covers, seat heaters, vette shift knob and finally going to get around to putting on the 6LE rear diffuser and front splitter ive had for a couple years but just never got around to doing it.
    This should keep me busy for a while.
  3. #5003
    You have just about 2 months to get it all ready for your trip to the GM Nationals in Carlisle. Come join us!
  4. #5004
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Was out cruising yesterday and some guy in a pickup was in the middle lane on the eway and tried cutting over the last minute to get off on an exit....the same exit I was just starting to get off on.... and he plowed through all the construction cones. The cones went flying everywhere and I literally had to lock them up at about 70mph and swerve several times to dodge the cones which were flying/rolling back at me. He kept going and I chased him down. Two idiots. I looked over the car when I got home very quickly and didn't see anything. I still don't know how I managed to dodge them.
    Sent from my SM-G900V using Tapatalk
  5. #5005
    Greensboro, NC
    Wish I could but we are taking a big family vacation before my nephew joins the army that weekend.
  6. #5006
    Yikes, Jon. That had to get the blood pressure up a few points. Idiots.
  7. #5007
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Holy shit Jon!!! When did you move to Maryland??!! LOL That's the kind of garbage that happens here several times a day. It's like everyone and their sister is drunk or high and go out driving. No respect for other drivers or any awareness what so ever of their surroundings. Even when you pull off next to them and give them the "WTF" look, they seem completely oblivious that they did anything wrong. Too bad you dont have train horns mounted under your hood to give them a nice 10 second blast!! LOL Glad to here you (and the SS) made it out without any issues. Great driving Cole Trickle!!!!
    1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
  8. #5008
    Member BobbyGFirebird's Avatar
    Jul 2015
    NY
    Blog Entries
    1
    Treated like VIP today at GM dealer ! After fixing all the little nits on the car --- with all of your help, thanks :-) --- I brought 30th Ann Ed. T/Am in for a proper major service. Much buildup as one of the techs there owns a similar year ws6 and is going to handle for me. Service guys were all dying to drive my ride. Good news: major vibration and rattle under hard throttle in 3-5k rpm range turned out to be just a worn tranny mount.
    Better news: it was NOT internal valves, rockers, chains, etc. ! HOORAY ! Can't wait to get car back from first major service in over a decade. Replaced all fluids: tranny, diff, coolant, oil, greased the ball joint and other fittings, siliconed and weather-stripped, rotated tires, and had the full multi-point inspection. New brake pads to boot ! Re-Birth !
    Tech said rotors "rusted and worn" but have driven fine to my feel, and I can't imagine at 40k miles of "mid-aged guy driving" they're below 1223"and .985" Front/rear min. thickness. Told them I'd take another look in 10k miles. So, not too bad for the first in-shop visit in a LOOOOOONG time for this car. I ran to dealer as 2nd owner told me last week that 1st owner hadn't really driven it more than 50miles/year from '02 to '11, and 2nd owner only changed oil every year from '11 to '15. No other maintenance.
    Absolutely hilarious: on the 20 mile drive to dealer today, the "Change Oil" light came on. F A T E !
  9. #5009
    Jul 2015
    NY
    Blog Entries
    1
    Great news! Rotors all-around were comfortably above the min. thickness (after a grind) and way over the discard thicknesses per Haynes manual. I told dealer I'd keep the rotors. They said rusted and should think about replace, but correct me if wrong, but even I know from the 1970s and 1980s that rusted rotors are fine as long as not warped. Won't some hard driving with new pads clean off any rust? They looked shiny as a silver spoon to me.... Is that just dealer trying to push $$$ rotors on me? I'd rather be rough on a set of new pads than replace 4 rotors at 40k miles. Thoughts?
  10. #5010
    Apr 2010
    Alabama
    Black/ Silver
    Depends how rusted. As rust will eventually eat into the rotor and destroy it. Me I replace if rusted especially if I've never replaced the rotors on the car or it's been a really long time.
  11. #5011
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Rotors can get rusty enough that they won't clean up nicely.
    Here's what might have happened at the dealer. They probably assumed you'd be happier with fresh, clean, brand new rotors.
    Kooks 1 7/8" race headers, Kooks ORY, Borla catback, Nitto 555R, LS6 intake manifold, Shaner S3 ported stock throttle body, SLP lid, smooth bellows, JAAM Ram Air kit, Elite Engineering catch can, LS6 valley cover, EGR and AIR deleted, Frost tune, and Simpson Racing child car seat in the back. 13.2 @ 108MPH
  12. #5012
    Quote Originally Posted by RONS98TA View Post
    It seriously was just like that scene lol
  13. #5013
    Greensboro, NC
    New seat covers came in today but one of the headrest covers are missing. Waiting to hear from 6le. Of course they arrived Friday afternoon which means I probably won't hear anything till Monday.
    Patience is not my strongest trait.
  14. #5014
    Greensboro, NC
    Found the other headrest was going inside and look down and it was behind a flower pot. Must of fallen out of the giant hole fedex left in the box an I was in a rush and just didn't notice.
  15. #5015
    Apr 2010
    Alabama
    Black/ Silver
    Got the newer 0411 pcm to swap into my 98.
  16. #5016
    Member udy2554's Avatar
    Jun 2015
    Naples, NY
    Dark metallic blue
    2000 WS6 vert!
    Finally...pass. side motor mount, plugs, and wires are done! Header is in, coil pack is in! Tomorrow pulling tranny to measure slave and clutch! (Plus new tranny cross-member and mount with TA mount!)
    Good clearance?
    First time the hood's been down in a while! DUSTY!
  17. #5017
    Member DarrenWS6's Avatar
    May 2015
    Blossburg, PA
    Silver Metallic
    2000 Trans Am WS6
    Nice work man. But I can't believe you leave the window down on it while it sits. I would fear dust build up inside like a mad man haha!
    2000 Trans Am WS.6 M6
    SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
    Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
    YouTube.com/DarrenWS6
  18. #5018
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    I should have had my shop do new motor mounts when I had my headers/exhaust put in.
    SLP Air Lid/Smooth Bellows
    Elite Engineering PCV Oil Catch Can
    SLP Smooth Air Lid and Smooth Belows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @ 415 rwhp
    Weight reduction via removal of dead mice
  19. #5019
    Jun 2015
    Naples, NY
    Dark metallic blue
    2000 WS6 vert!
    Quote Originally Posted by DarrenWS6 View Post
    The car was covered for most of the winter! Now I'm feeling your pain!8-(
    LOTS of dust!
  20. #5020
    Quote Originally Posted by udy2554 View Post
    Good clearance?
    If you find that those MSD wire's are too tight for your tastes look for the truck version of those MSD's. They are a couple of inches longer and make it easier to position and clear the heads and exhaust.
  1. new guy just got my first trans am today
    By roger_johnson2002 in forum New Member Introductions
    Last Post: 07-14-2011, 09:35 AM
  2. Found this on the windshield of my Trans Am today
    Last Post: 03-10-2009, 01:11 PM
  3. Got into an accident in the Trans Am today
    Last Post: 09-21-2008, 05:32 PM
  4. Just got my Trans Am today!
    Last Post: 09-20-2007, 10:57 AM
  5. First time at Track today!!! 2000 Trans Am ws6
    Last Post: 11-12-2005, 02:34 PM
