Results 4,081 to 4,100 of 7110
05-11-2015, 10:08 AM #4081
- Jan 2015
- Sacramento
Black- 2002 WS6 Trans Am
I did a full wash and wax, complete detail on the inside, and did touch up on a few little rock chips on the front. Went through and tightened up all the panels to eliminate the rattle from the sub in the back. Ordered custom WS6 floor mats.
Also should be ordering my new R1 rotors and pads today as soon as I hear back from Kevin.
To celebrate the clean ride, The lady and I cruised to In-n-Out with the T-tops off for a burger and fries. Was beautiful weather all weekend.
05-11-2015, 05:50 PM #4082
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Had to cut up the rear mount on the UMI torq arm to get it to fit on the S60 today glad they make them with 2 mounting holes for just this problem. Just have to cut off the out side two holes and move in to the inside holes thus bringing the arm in closer to the drive shaft and away from hitting body. Good Job UMI for covering all the bases...made up a check list to start crossing off things so nothing is over looked
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
05-12-2015, 12:41 PM #4083
05-12-2015, 01:15 PM #4084
Jeff what Magnaflow Muffler are you using, looks like it's 3" and that's what I'm needing.
05-12-2015, 06:09 PM #4085
- Apr 2011
- Johnstown,PA
This is the system I'm using if this helps research it. Magnaflow Catback 98-02 F-Body Twin tips sure what muffler it is! Should be in the garage tomorrow night I will look for a number. It for sure is 3" inlet and sounds awesome. I could only imagine your motor paired up with it....
05-14-2015, 05:53 PM #4086
- Apr 2011
- Johnstown,PA
Sway bar mounted, S/S brake lines on, calipers separated from mounting brackets sanded and painted. Amazing how many little things you come across along the way.
Hey Scott looked at the muffler and I can't find a single number anywhere. Try that link to research or contact Magna Flow I'm sure they will help you
05-15-2015, 03:12 AM #4087
05-17-2015, 07:15 PM #4088
- Apr 2011
- Johnstown,PA
Finished up some more odds and ends, brakes, Drive shaft, safety loop, loaded suspension and torqued everything down. Just need to add fluids and swap the front rotors and lines and bleed the system and hopefully the PCM will be back from Frost then it should be go time. I'll post some pictures soon.
. something showed up from FrostLast edited by kingls1; 05-18-2015 at 01:59 PM.
05-20-2015, 07:44 AM #4089
05-20-2015, 11:02 AM #4090
Sold the Trans Am today. The guy who purchased it is becoming a member, so please give him a warm welcome!
2000 Trans Am - Sold
BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, American Racing Torq Thrust 2's, Founders STB, LCA's, LCA Relocation Brackets, Adjustable PHB, BMR Lowering Springs. Deleted AIR & EGR & Tuned By Frost. 1 of 23 MRM with options.
2009 Pontiac G8 GT Stock
05-21-2015, 07:42 AM #4091
well, had planned to replace the front bearings but noooooo.... have to wait until the bs rain stops
2000 Jet Black M6 Trans Am aka Kitte:
SLP lid, cai kit, smooth bellows; Hawks HPS pads/slotted rotors; Centerforce D7X street/strip clutch; DDM HID conversion; Black w/ metal lip C5 Z06 replica 17x9.5 rims; free ram air mod; Bilstein HD shocks; LTs and ORY; Magnaflow quadtip catback
05-21-2015, 01:22 PM #4092
Swapped out my driver side window motor and fixed the crack in the panel. Got two motors off carparts .com for 33 bucks and it works better than ever sunshine performance are wonderful guys but I couldnt pay him 100 bucks to fix something I could fix so easily.
05-22-2015, 07:05 PM #4093
- Apr 2011
- Johnstown,PA
Some of the final steps
finally got it done and out on the road, finished pretty late so missed the inspection so I'm running illegal, oh well! Got 51 miles on it and I'm 100% satisfied, almost no gear noise what so ever, above picture only 1900 rpm's at 70mph in 6th gear that's only 400 more with 4:10's compared to the 3:42's. I have to put 50 miles on it then cool 1/2 hr for several heat cycles. May hit a show tomorrow with some friends
05-23-2015, 08:35 AM #4094
Sweet! Time to set a date for the track, eh?
05-23-2015, 02:06 PM #4095
- Apr 2011
- Johnstown,PA
As soon as I rack up 500 on the clock and change the oil. I talked to the guy I ordered it from and he was very adamant about proper break in and it said NO Hard launches or extrem driving. I haven't put more than 1,600 on per year for the past 4 so I plan on stepping it up cause Me Need Another Track Day...
Stopped for a few pics on the way home.
Had my favorite copilot along today.
05-24-2015, 08:35 AM #4096
I've been driving mine every day I have had it since buying it May 8th. I wish I could stop but I can't help it. There is only 2 days I haven't brought it out. At some point i'll cool off and be content with it!
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
05-24-2015, 12:40 PM #4097
Never say that I love my bucket of bolts too 😊and I drive her everyday. Enjoy her and all the good times you can cuz yolo and there is always rebuild time.
05-24-2015, 01:10 PM #4098
05-26-2015, 04:03 AM #4099
05-27-2015, 05:51 PM #4100
kooks LTs, kooks catted y, and magnaflow quadtip cat back put in today. LOUD as hell now lol
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
