Results 21 to 40 of 1145
Thread: Been testing Oil
07-08-2008, 04:28 PM #21
ok dumb question but does the oil make the car smoke any or does it just get burned in the combustion camber?
07-08-2008, 04:34 PM #22
- Retired Outlaw Sum Bitch
No at 500:1 there is zero smoke or smell.
07-08-2008, 04:37 PM #23
ok i guess i should try it out and does it have to be the syn. 2 stroke marine oil?
07-08-2008, 04:57 PM #24
You want TC W3 rating. That is for water cooled marine 2 stroke engines. Valvoline/Pennzoil/SuperTech at Walmart.....your after the TC W3 as it has the add packs/viscosity we were looking for.
07-08-2008, 05:38 PM #25
OK Sarge I'm going to try this. BTW do you know the capacity of the Camaro's fuel tank? I want to get the mix right.
07-08-2008, 05:38 PM #26
ok i will look at advance tomorrow if i can get time and go
07-08-2008, 05:46 PM #27
07-08-2008, 05:47 PM #28
07-08-2008, 06:09 PM #29
Thanks guy's
07-09-2008, 05:47 PM #30
are there any side effects if you stop using it after any X amount of treatments?
07-09-2008, 05:59 PM #31
Well I bought a gallon today at wally World so we will see how it goes. I bougt the Super Tech brand it was 8 bucks and some change. I looked at the Penzoil brand but it was 23 bucks a gallon. I hope the cheaper one works as well as the other ones.
07-10-2008, 02:34 AM #32
07-10-2008, 02:35 AM #33
07-10-2008, 04:41 AM #34
- Nov 2005
- Royal Oak, Michigan
Black- 2004 GTO A4
Sarge - I like the idea of this. Everyone knows that 2-stroke motors run strong. I have always wondered if the oil in the fuel had anything to do with it (better lubrication, more octane or whatever)
I was one of those guy's who thought that Acetone gave you power gains. After 1 year of testing and Acetone exploding in my face on 1 hot summer day (due to the vapor build-up in the injector bottle) I found no gains in efficiency or power and quit using the shit. At least my wife can use the leftovers as a lifetime supply of nail polish remover (2 gallons)!
07-10-2008, 04:49 AM #35
- Jul 2007
- Augusta, Georgia
Bright Red- 99 Z28 M6, 03 Gixxer 1000
Going to get my Penzoil today. Thanks for all the info and testing Sarge.
07-10-2008, 04:52 AM #36
Well...at the end of the day the Fuel Power and Lucas UCL work....but you have to look at a cost to benefit profile.....2 stroke oil is a gas additive....has excellent lubrication/cleaning properties....so we know what it does.....burns clean.....what we had to test and test is the ratio of the mix to achieve optimum benefits. The 1oz to 5 gallons of gas has returned very clean spark plugs/upper cyliner as well ( piston top etc.) and smoother idle and acceleration.....past the point of "butt dyno" bullshit.....it is pennies compared to dollars of the others I have been using with better resluts. Just do not over mix....stick with the ratio I outline.....more is not better
07-11-2008, 11:20 AM #37
- Oct 2007
- Beaver Dam KY
The oil is in. I got a friend at work with a newer car that has the average MPG setting on the dash and im trying to convince him it wont hurt the car
07-11-2008, 12:33 PM #38
Put royal purple in mine Thursday,TWC-3 4 oz and have in the trunk for future fill ups, can't wait to see the results. Will post as soon as I burn about 3 tanks. Thanks Sarge
07-11-2008, 12:39 PM #39
07-11-2008, 12:42 PM #40
Good man! We have over a collective 100,000 miles and 6 months testing already. Checked the cylinders ( top end piston and walls) spark plugs etc. All cleaner than they were when we started....all reported ( including myself) smoother idles and acceleration and a increase in MPG. So nobody is a guinea pig here guys......
Testing
By mrwdjv in forum Almost Anything GoesReplies: 5Last Post: 05-11-2009, 03:11 PM -
testing
By Spikito in forum Almost Anything GoesReplies: 55Last Post: 02-21-2009, 03:56 PM -
Well testing
By 99formulals1 in forum Almost Anything GoesReplies: 8Last Post: 11-28-2008, 08:12 PM -
Testing
By Y2KPewterSS in forum Camaro / SSReplies: 0Last Post: 04-25-2007, 06:41 PM
