Results 21 to 25 of 25
Thread: Replacing Ignition Lock Cylinder
04-08-2011, 06:13 PM #21
- Jan 2010
- texas
silver- 2000 formula
500$ for a new ignition cylinder and keys at the stealership for me
01-21-2012, 04:22 AM #22
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
I to had this $500. quote and it was from a shop foreman that I trusted he told me about the thin wires this was about 8 years ago.
all I did was read up on VATS.for the solution.
I'm sure eventualley these thin wires will fail.
My ? is can I connect these thin wires to a push button under dash hence igintion and just use the lock cylinder as a wheel lock?
Thankscam-LTs-FAST78-Susp.-Rims
07-16-2014, 12:58 PM #23
I realize this an old thread and you may already have the answer. If not, the short answer is no. Your key has a resistor in it, some call it a chip but it is not a computer chip. There are 15 different types of keys with 15 different resistance values. The VATS II system needs to match your resistance to the set, programmed resistance in the system. If VATS detects the correct value, then you get to start the car.
There are many very well written articles on the web about VATS and how to bypass or change the ignition cylinder.
I personally hope that this problem will someway become part of this massive recall...but good luck to us with that one. ;-)
07-16-2014, 01:00 PM #24
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by VengeanceSCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
09-18-2015, 06:35 PM #25
- Sep 2015
- Northern California
Not sure if im.in the righy spot here but my situation is similar and I need some guidance. The problem with my ignition is the actuator rod snapped and the stealer ship wants 1300 dollars to fix it. Part number 26010649 is discontinued so they want to source a used column and pull this 20 dollar part from it and charge a bunch for labor. Is there anyone out there who has one I can purchase or have any info on a repopped unit? I have a black t top 2000 SS with only 66k miles and I would just be tickled to drive her again! Any info would help thanks so much
VATS bypass/ignition cylinder lock question
By mezzoni in forum General HelpReplies: 8Last Post: 03-25-2013, 06:43 PM -
02 Avalanche ignition lock cylinder
By silverWS6 in forum GM TrucksReplies: 17Last Post: 12-04-2012, 04:37 AM -
ignition lock cylinder is very loose
By camaro02sprspt in forum Computer & TuningReplies: 0Last Post: 09-21-2009, 06:11 PM -
Ignition Lock problem
By slims00ls1z28 in forum GTOReplies: 36Last Post: 07-24-2009, 08:37 AM -
Ignition Cylinder Lock Button
By CamaroDMD in forum General HelpReplies: 8Last Post: 05-29-2009, 11:02 PM
