Results 21 to 31 of 31
Thread: Torque Arm suggestions?
01-29-2008, 06:55 AM #21
- Dec 2007
- Brookville, PA
White- 2001 Z28
There is really short, a little shorter than stock, and stock. The shorter a TA gets, the more it plants the rear tires on hard throttle.... but it also makes brake-hop worse, and you have to consider where they mount and all the loads involved.
I run full-length arms, and if you want if off the transmission mount we use a relocation bracket that moves it to the tranny crossmember which in turn is mounted to a MUCH stronger part of the floorpan than the tunnel brace area. And you stay with a full length TA, which I prefer and there are plenty of folks pulling good 60's on full length versions. All of them are shown on my website under "suspension".Sam Strano
SCCA National Champion (x6)
SCCA ProSolo Class Champion (x5)
2009 SCCA ProSolo Overall Champion
Owner--Strano Performance Parts
814-849-3450
01-29-2008, 06:55 AM #22
- Thornton, CO
I check it annually.
Along with every bolt on the suspension.
01-29-2008, 07:00 AM #23
01-29-2008, 09:08 AM #24
01-29-2008, 09:14 AM #25
- Jan 2006
- Shepherd, Michigan
niccce how long did it take for your umi 3 points to ship?
01-29-2008, 09:15 AM #26
01-29-2008, 09:21 AM #27
- Jan 2006
6 days waiting..order still in shipping
01-29-2008, 11:52 AM #28
01-29-2008, 12:18 PM #29
01-29-2008, 12:31 PM #30
01-29-2008, 02:39 PM #31
I already had just the HPM T/A installed on my 97 SS. I got into an accident and the T/A held it's ground. As we got to the last bolt taking the T/A off after the accident, the T/A popped as the body was under pressure.
One thing that you all do not realize about the HPM T/A (and I forgot to mention) is that it has a total of 5 mounting points. One is directly in front of where the T/A and Brace mount together. The other is next to next to where the LCA bolt is. The original owners of HPM recommended that the T/A be welded in.
The HPM T/A takes a lot of stress off of the tunnel brace holes. Yes, not all, but more than your typical tunnel mounted T/A's. Think about where the force is exerted the most.
I already have the SFC's and T/A installed, and I can assure you that it is solid! It ain't goin anywhere!Last edited by 9t8z28; 01-29-2008 at 02:48 PM.
For Sale: umi tunnel mount torque arm brace and on car adj torque arm
By 99yellowz28 in forum Parts For Sale / TradeReplies: 3Last Post: 07-10-2011, 08:33 AM -
Torque Thrust II's vs Torque ThrustM Chrome's??
By SteelmanLS1 in forum Wheels and TiresReplies: 5Last Post: 03-01-2008, 03:36 PM -
Need suggestions
By DKSS00 in forum Internal EngineReplies: 0Last Post: 10-18-2007, 09:25 AM -
Z28 vs SS - Suggestions
By scottay in forum Camaro / SSReplies: 58Last Post: 09-02-2007, 10:36 AM -
Suggestions...
By txws6 in forum General HelpReplies: 0Last Post: 05-24-2006, 01:46 PM
