Results 21 to 40 of 41
Thread: rubbin?
08-12-2006, 03:03 AM #21
tere not looosing the shine just some of the clear coat is got eat off some how due to former owner.
that iroc is nicemo
08-13-2006, 01:25 AM #22
here you go I found these .. they are a sort of Iroc rim.. but in 20's... im sure if you got them in 17 or 18's under the roc it would look sick
2002 Camaro SS #1539
MTI Clear AirLid /Magnaflow catback/Polished Hotchkis Strut Tower Brace/K&N Filter/Bilstein Suspension/
http://www.cardomain.com/ride/553601
http://www.fquick.com/illcul8troffcr
08-13-2006, 07:49 AM #23
that does look coo but it would have to have some black on it tomake to crom stand out
08-13-2006, 04:06 PM #24
shit man you could eaasily get them powdercoated accents... lines kind of like your factory ones you have now have.. or like the 88 and 89 Irocs have where the indented slits are colored and the inner lip and the rest is chrome
like this.. excuse the pic I found it on the net but it shows the rim well ...
08-13-2006, 04:07 PM #25
seeing this shit is making me want my iroc again haha oooooooh the memories
08-13-2006, 05:46 PM #26
cant see the pix sorry
08-13-2006, 06:34 PM #27
08-13-2006, 07:11 PM #28
idono man there still just showing up as "image hosted by angerfire" im thinking about alot off different wheels now just dono wich any sugestions open to all
08-17-2006, 02:16 PM #29
on a third gen car, a 17 x 9 wheel with 5.25" backspacing is what fits without interference. if the wheel has 5.5" backspacing, then you'll need to grind a little off the tie rod to clear the wheel. i think it was car craft that did an article on fitting wheels on a thirdgen. this was with 275/40-17 tires.
08-17-2006, 02:19 PM #30
http://www.carcraft.com/techarticles..._tires_wheels/
just found this month's article online.
1982-1992 Camaros and Firebirds
15-inch: 15x8 with 4-1/2-inch back-spacing front and rear. Use tires with an aspect ratio of 55 or less with a section width of 255.
16-inch: 16x8 with 4-1/2-inch back-spacing front, 51/8 backspacing rear. Use tires with an aspect ratio of 55 or less and a section width of 255.
17-inch: 17x9 with 5-1/2-inch back-spacing front and rear. Use tires with an aspect ratio of 40 or less with section widths of 255 front, 275 rear.
18-inch: 18x9-1/2 with 5-1/2-inch back-spacing front, 18x10 with 6-inch backspacing rear. Use tires with an aspect ratio of 35 or less with section widths of 275 front, 275-295 rear
08-18-2006, 07:35 AM #31
awsoem link i was almost bought some 15' with 295 on rear and 195's for front but i changed my mind cuz they were steelies and...15 inches that tec artical was good info it sed to go with a 255 for the fron on a 17'' wheel can u go with 275? or would that fuck up things
08-19-2006, 04:45 PM #32
ok so ive been dooin alot of lookin around does it effect anything that much if you go with
17x9.5 rear { 275's }
17x8.5 front { dono front }
would that work or should i just go all 9.5?? with 275 on all
08-19-2006, 05:45 PM #33
you could do 9.5" wide with a 5.25" backspacing all the way around with a 255/40-17 so as not to rub the inner fenderwell in the front.
one of the other mags did a 17 x 9 with 5.25" backspacing with 275/40-17 all the way around. SLP even came back with their 3rd gen wheels for a short time a couple years ago.
08-23-2006, 08:37 PM #34
so i decided to go with a staggered set 17x9.5 275 rear and a 17x8.5 245 in front is this bad for performance? if so lett me know b4 i order the set of rims wich hofuly will be perchased this week end
08-25-2006, 07:29 AM #35
ok guess this thred is gettin old o well
08-25-2006, 12:32 PM #36
08-25-2006, 02:13 PM #37
now anyoneknow the best place to buy em i think im going with group a wheels? they seem lie a good place to bu em
08-29-2006, 06:25 PM #38
08-30-2006, 08:37 PM #39
so right b4 i ordered then i was just told nothin bigger than a 8inch wide would fit at all im so confuzed and dont wana make a mastake that will cost this much
08-31-2006, 03:56 PM #40
- Jun 2002
- Montreal, CANADA
9" fit well on a 3rd gen.
here are some pix of 3rd gen w/ 4th gen wheels but had adapters to have the wheel stick out a bit more.
http://rides.webshots.com/album/64845209aRhImEEugenio_SS
