Results 21 to 34 of 34
Thread: burnout questions for automatics
04-14-2006, 03:10 PM #21
- Aug 1999
- Arizona
If you can't spin them to do a burnout. Then you won't spin them at the line. Just line them up and go.
Since you have an A4, get a converter.Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
04-14-2006, 04:22 PM #22
Originally Posted by z_driver1
04-14-2006, 05:07 PM #23
- Aug 1999
- Arizona
That's true, but if he is not spinning off the line. Why worry about a burnout?
04-14-2006, 05:32 PM #24
Originally Posted by Ed Blown Vert
04-14-2006, 05:56 PM #25
Originally Posted by cailey37
04-14-2006, 06:05 PM #26
Originally Posted by x-40oz-x
Bottom line: Drag radials need to be warmed up before you race.....you guys are gonna get me to drinking again....
04-14-2006, 06:38 PM #27
04-14-2006, 07:54 PM #28
- Aug 1999
- Arizona
04-15-2006, 05:05 AM #29
04-15-2006, 08:01 AM #30
- cali
- 1990
I never said I was hooking at the line without a burnout on drag radials. I was talking about trying to burn out in with the drag radials and not being able to. But it's not like this is my first time drag racing, I've been doing this for about two years. My launch technique has always been the same but this was my first time on drag radials.
04-15-2006, 09:13 AM #31
- Aug 1999
- Arizona
Well that would have help alot if we knew that in the beginning.
Your going to have to use water to spin the tires.
04-22-2006, 01:02 PM #32
yea, If you cant light em up then thats good. You do not need to burnout b4 if you are not burning out on ur launch. Are you burning out when you go down the track?
04-22-2006, 05:54 PM #33
- Knoxville, TN
Torch Red- 2000 Corvette
When you change to a looser converter you will definately need to heat the tires because they will spin off the line. The looser converter will really help your ET. Even though you are launching without spinning the tires (so you think) if you could get a video where you could watch the tires in slow motion I believe you would see some loss of traction. I think you need to heat the tires now and certainly when you go to a looser converter. Even though it doesn't feel like the tires are spinning, I bet that if you heat them before running that you will run quicker.
04-29-2006, 02:45 PM #34
- Cape Coral, FL
Mystic Teal- 99 Trans Am & 01 CBR 929
Ok I have to back cailey on this because I could not get a powerbrake for shit on dry road (turns out it was because of my sway bar missing an endlink) but then when I would take off at the line I would spin almost clear to the 1/8 at times.. However if his times did not improve when he put on the DR's they will not be likely to improve when he heats them. They will help most cars but he seems to have more of a weight transfer problem than anything. I would say some looser shocks up front and disconnect the front sway bar and possibly some gas shocks in the rear and he could see another couple of tenths.
Question: FLT or Extreme Automatics?
By 98TransAmWs-6 in forum Automatic TransmissionReplies: 29Last Post: 03-21-2014, 02:17 PM -
Talking Automatics and ATF
By Sarge in forum GTOReplies: 5Last Post: 04-01-2008, 07:55 PM -
Anybody know what c6 automatics dyno?
By mach350z in forum Internal EngineReplies: 0Last Post: 06-27-2007, 06:58 AM -
NOS & Automatics??
By BDowning in forum NitrousReplies: 19Last Post: 02-14-2007, 04:38 PM
