Results 21 to 29 of 29
Thread: no spark help!!!!
04-17-2013, 06:29 AM #212002 Trans Am 514 RWHP / 510 Torque
04-17-2013, 01:13 PM #22
Sorry you're so offended at my thoughts, but guessing is fucking stupid. It probably is the opti, but these things shouldnt just fail when they're 3-4 years old unless they were installed incorrectly or there was another problem to being with that is contributing to its failure. Sorry yuo've gotten screwed by a dealer in the past.
04-17-2013, 01:40 PM #23
Offended??? No...hardly. I have changed out many of Opti's in my day and have never taken any cars to the dealer unless it was under warranty.
Don't be a douche bag just because someone is in disagreement with you. The opti issue is nothing new and not rocket science. Don't try and make things more difficult than it needs to be.
You getting pissed is nothing surprising though. You have been doing for years on this forum. You are a self acclaimed internet expert which in reality means absolutely nothing.
Sent from my EVO using Tapatalk 2
04-17-2013, 11:34 PM #24
Not sure why you felt the need to add in the insults, so if anyone's getting bent out of shape it's you (even though in typical fashion you were really hoping I was mad and you got under my skin
). Disagree with me all you want, but guessing at issues and throwing parts at a problem is rarely the answer, even if this does turn out to be the opti. Got anything else to say to me take it to PMs. And here's your points for flaming.
04-18-2013, 02:14 AM #25
1995 t/a
Ok guys before the i got no spark i started the car and left it running and went back in the house to get sum it was 3_4 min i heard the car die so i went to restart and it wouldnt it would just turn over so i check for gas so it is getting gas but has no spark any ideas
04-19-2013, 01:05 AM #26
How are you checking for gas? Just curious. Have you ever started the car and let it run, with a fuel pressure gauge installed. I'm pretty sure you can rent one that will work. Just to observe what's happening with the pressure when the car dies. I only bring it up because it's an easy way to confirm no issue there. I've had fuel issues with cars where you would get fuel coming visually out of lines, and you didnt see the problem until a gauge was there. It may all be a moot point if you've verified no spark. It just seems odd the car will run for so long and then die. Which makes it an intermittant no-spark condition. I've heard of optis failing in a miriad of different ways though. I wonder if the issue is related to the car going from open loop to closed loop as it heats up.
04-22-2013, 07:28 PM #27
Classic symptom of a bad opti....
But wait...you might want to check your tire pressure and see if that has an effect on your no start issue. Also...it could be a blown tail lamp bulb too. Just make sure you check everything else on the car before starting with the logical answer.
04-23-2013, 10:11 AM #28
awesome.....
now that's some funny shit right there......
I agree with both him and 5.0. I think it's the opti but I would never change it without trouble shooting it to be sure that's what it is. Last time I checked opti's were pretty damn expensive.
05-06-2013, 09:30 AM #29
OK! Check for the ICM signal from the PCM w voltometer...it should read low like 8v or 5v or somthing when key is cranking! Unplug ICM and connect Voltometer to Harness from PCM..... NO CIGNAL means 2 things! BAD OPTI TRIGGER or BAD PCM.... the OPTI signals the PCM to signal the ICM to fire the coil pack! BUT I'VE SEEN THE PCM ACT FUNNY ON MANY OCCASION!!!
Enerpulse Pulstar Spark Plugs - Supersize Your Spark
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-15-2013, 09:00 PM -
spark gap 02' 5.7l
By johnfin in forum Firebird / WS6Replies: 6Last Post: 09-19-2012, 05:18 PM -
What kind of oil 5w30& spark plugs&spark plug wire
By ROMERO98Z28 in forum General HelpReplies: 20Last Post: 09-01-2009, 01:50 PM -
No spark
By 70 camaro in forum General HelpReplies: 2Last Post: 01-14-2006, 12:31 AM
