Results 21 to 38 of 38
Thread: headers, whats your preference?
04-25-2010, 07:11 PM #21
I have Fel Pro header gaskets i ordered from summit are those good gaskets when i install my LT's.
04-25-2010, 09:28 PM #22
The factory gaskets are great and many have just reused theirs. Do not use the fiber gaskets that come with some headers. I've never seen the FelPro gaskets- what are they made of? I'd also recommend getting a good set of bolts like the Stage 8's or Percys simply because you can save yourself a lot of headache just by keeping the header bolts snug- most header gaskets leak because of the constant heating and cooling lead to the bolts backing out enough to let exhaust gas get by.
04-25-2010, 09:46 PM #23
i have the stage 8 bolts i was thinking of using anti seize on them and then trying to see if there are a good set of lock washers just in case for them instead of using the locking they come with. I might just re use my existing header gasket since its settled already but i was told fel pro was a good replacment not sure anymore ill check and see what kind of gasket the are.
04-26-2010, 06:26 AM #24
A little anti-seize is always a good idea when you're using two different metals. As for the locking washers- just use the ones that come with the Stage 8's. On the center ones there's not much you can do- maybe someone who's set them up on a LS1 can give you a better idea. I ended up going with the Percy split bolts more out of curiosity- used Stage 8's for years, just wanted to do something a little different.
04-27-2010, 07:19 AM #25
05-01-2010, 02:55 AM #26
I just bought the same headers from the guy you got them from off ebay, i also go the hooker matching y pipe that goes with these headers. Hope it works out well. But how was his shipping? I havent heard anything from him i asked what the headers came with like if i need to order the o2 extensions or not.
05-01-2010, 09:07 PM #27
Running Pacesetter LT's here. Love 'em and great for a budget
05-02-2010, 09:42 AM #28
headers
the best headers are the ones you get for free.but if you cannot find those,do like i did, and search craigslist for a while.i found some LTs for 40$ kinda ugly,but they seal good and they are the same design as hooker or flowtech.they work great with my NOS kit!!
05-02-2010, 12:25 PM #29
05-02-2010, 05:04 PM #30
05-02-2010, 05:17 PM #31
I just oredered Pacesetters, gm gaskets and Poly motor mounts and TSP Y pipe. But the headers are back ordered for 2 weeks.
05-02-2010, 05:18 PM #32
05-02-2010, 05:52 PM #33
Woodbine. Its southern carroll county. Where are you at?
05-02-2010, 05:56 PM #34
05-02-2010, 06:12 PM #35
i might come down one night. theres a few people ive met on here up at mason dixon.
05-04-2010, 11:49 AM #36
05-04-2010, 11:54 AM #37
05-04-2010, 11:56 AM #38
- Jan 2006
- Shepherd, Michigan
very true...i believe they have started to tighten up their QC tho as of late...but they had that horrible batch of headers with the leaking primaries and piss poor header flange( i think that is the right word) fitment.
their Y pipes blow hard ..only good thing is their high flow y pipe merge......
Cam preference
By Babayaga in forum Internal EngineReplies: 1Last Post: 10-20-2016, 08:58 AM -
whats the difference in headers
By the_formula in forum External EngineReplies: 28Last Post: 04-25-2008, 03:28 PM -
Oil Filter Preference
By lmyers1 in forum External EngineReplies: 16Last Post: 02-11-2008, 07:06 PM -
Any preference: SFC's and Lids
By BowtieFever in forum General HelpReplies: 16Last Post: 12-04-2006, 12:24 PM -
whats the differance in headers???
By momsls1 in forum External EngineReplies: 6Last Post: 09-25-2006, 08:30 AM
