Results 21 to 40 of 43
Thread: grinding 3rd gear?
12-31-2006, 01:56 PM #21
In the end......he will drive it till it breaks.....
Got passenger window problems?
http://www.autotrix.net
**Window Express Down Modules now availible**
http://www.autotrix.net/products.html
01-01-2007, 08:58 PM #22
- Jan 2007
- Altus Oklahoma
Black- 1998 Trans Am
I too have the same problem with my 98 T/A M6. Low RPM shifts in to 3rd are rough. I had the fluid changed and it seemed to help a bit but not much. I was surprised to find that the fluid is automatic trans fluid and not gear oil
01-01-2007, 09:39 PM #23
hmm mine did that.. my tranny was all sorts of f****D up though... my guess would be synchro's next id say bent shift fork.. third gear is the week link in t56's.. but i have heard and seen pro 5.0 shifters give t56's problems by not havin the stops adjusted correctly.. hope perhaps some of this helps
01-02-2007, 04:44 PM #24
01-05-2007, 10:31 AM #25
oh ok your right.. im prejudice of my hurst with the short stick you caught me
00 SS TRak CAM,VALVETRAIN,CAI,HOOKER LT'S,3" ORY,CAT DELETE,PCV+EGR DELETE,LS6 MAN.90MM PORTED T/B, ASP UNDERDRIVE PULLEY,LS6PORTED OIL PUMP, FULLY BUILT T56 VIPER TRANNY,MOSER 12 BOLT 3.73'S 33 SPLINE BOLT IN AXELS ALL HOTCHKISS SUSPENSION.,BMR ADJ. TQ. ARM.,SFC'S, E. CUTOUT. 423 rwhp 416 rwTQ.
01-05-2007, 11:29 PM #26
you could also try rev matching when you down shift, and double clutching when you up shift... when your on it and you up shift it grinds right, when it does the clutch in blip the throttle and select the gear again... if it doesn't like that, no racing -
Fairfield yes fairfield, there's a few bad cars around there once in a while
01-06-2007, 11:55 AM #27
Fairfield was the former home of the Wayne County Speed. We were the NHRA world funny car champs back in '90-'91. Tons and tons of super fast street cars came out of the speed shop in the 70s and 80s. Nowadays the speed shop is no more. I wish it was still around.
01-10-2007, 06:22 PM #28
01-10-2007, 07:27 PM #29
01-10-2007, 08:01 PM #30
Double clutching is a technique used on older (like 1940's) vehicles to engage gears without grinding them. These older transmissions were not synchronized, meaning that the user had to manually match the speeds of the engine and the input shaft of the transmission to engage the desired gear.
This is done like so: Accelerate through 1st gear, clutch in, pull gear lever into neutral, let clutch out, match revs to what they will be when next gear is engaged, put clutch back in, engage next gear, make sure RPM's are at the right speed, engage clutch.
Double clutching a modern synchronized manual transmission is pointless, being that the whole purpose of synchros is to eliminate the need to double clutch. However, if the synchros are going bad or completely shot, the car can still be driven without an issue by double clutching the transmission.
01-12-2007, 02:27 AM #31
Could not have said it better myself
02-28-2007, 05:43 PM #32
- Dec 2006
- Arizona
Black- 1998 Ws6 Trans Am M6
Mine only does it SOMETIME, mostly in the mornings when its cold.
02-28-2007, 09:45 PM #33
I've got the same problem in 3rd and 5th. I grit my teeth every time I grind
. Never does it in the summer though. So does anyone know if temperature has a big influence on this, or is it just me?
02-28-2007, 10:49 PM #34
- Dec 2006
- Michigan
Black- Formula... soon
03-01-2007, 04:35 AM #35
you guys with the problem, how many miles you got?
03-01-2007, 06:32 AM #36
Tempurature has a direct affect on the transmission from what I've found as well. If its really cold out, any attempt at fast shifting will usually net me a grind going into 3rd and 4th.
When I was at the track last fall though, and it was almost 90 degrees out, I ran 1st - 4th gear as fast as I could on my first pass and I didn't even get one little grind. So I'd say that temps definitely affect the performance of the transmission.
03-01-2007, 06:59 AM #37
03-01-2007, 07:56 AM #38
My 1st gear grinds. However, I dont have to shift fast into 1st often.
03-01-2007, 04:28 PM #39
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
mine started small, now within 2000 miles, i cant use 3rd 4th or rev...
03-01-2007, 05:10 PM #40
mine started doing about a year after i got it in 2004. it was just every now and then but most of the time i would just be over about 2000 RPM before i shifted and i never got the grind anymore. but i'm in the process of rebuilding my motor now.( it had about 150,000 miles on it ) since i got the tranny out, i might as well fix the syncros.
taking shit apart and putting it back together has always been easy for me, i was wandering if anyone knew where to get a book on the T56 tranny that shows a step by step of how to rebuild it? i'd like to try and do it myself, cause i have another tranny coming to me from a friend of mine so if i screw up, at least i have a back up till i get a tranny shop to fix my screw up.
Help: Headlight Gear Grinding
By Ant71130 in forum Firebird / WS6Replies: 4Last Post: 05-21-2011, 07:56 AM -
Gear grinding
By Ironwolf in forum Manual TransmissionReplies: 0Last Post: 01-11-2010, 08:45 PM -
Grinding going into Second gear
By matt333cars in forum Manual TransmissionReplies: 4Last Post: 09-05-2008, 12:38 PM -
3rd and 4th gear grinding?
By vinnie311 in forum Manual TransmissionReplies: 8Last Post: 11-04-2006, 10:26 AM -
Grinding and locking in 3-4 gear
By Warwick in forum Manual TransmissionReplies: 3Last Post: 06-23-2006, 05:08 PM
