Results 21 to 37 of 37
Thread: engine swap
10-08-2007, 01:28 PM #21
10-08-2007, 02:21 PM #22
- LA
Grey- 2010 Camaro 2SS/RS CGM
Nah you can easily get a whole engine/trans with computer and everything for 3k, i have a guy i know who parts out salvaged/recovered and will sell a whole eng/tranny with ECM for 3300, most of the ones on ebay also include the computer, just have to get a new k-member and your pretty much set.
Im keeping my eyes out for a ls2/m6, hopefully the prices will go down with the LS3 coming out, so im hoping to scoop one for around 6k
10-08-2007, 02:32 PM #23
- Jul 2007
- tennessee
TA-White, Camaro-Black- Track-TA98A4 DD-98z28M6
you need to do your research before you go off making statements... i thought i ha ddone mine... bought an engine and stuff... then more research and i have found out that it is VERY expensive..... there is a bunch of small things that they dont mention that you need.. trust me... i have pages of parts that you have to have... thats just a 99 to 99 v6 to ls1 swap... not different years and especially not lt1 model to ls1...
10-08-2007, 07:17 PM #24
- Aug 2006
- Streetsboro, Ohio
Red- 1998 Firebird Trans AM
You are correct 3300.00 JUST FOR THE ENGINE, TRANS, ECM, AND THE ENGINE HARNESS!! From his year to a 99+ LS1 he needs K member, Rad, engine compartment harness, and the engine harness, Car harness, Body control Harness, Air Bad sensors, Fuel pump, possible the updated fuel lines. If you got a PCM with traction control, you need to make sure you have a series 3 carrier or your abs ont work, ABS computer, cruise control computer, AIR Pump. Steering shaft. Inst Cluster, and there is still more... There are alot of misc things you are forgetting. Trust me I have done it. You can hack your way through it and "make it work" . If you are doing a fully caged car, with a carb, then you are in the ball park to convert it. BUT if you want to convert a LT1 over to a fully functional "stock" 99+ LS1 you are going to be closer to $6,0000 (that is also adding some "needed items to the LS1 build like, headers, y pipe, and a few other body upgrades that should be done. If you can convert fully functional stock LS1 cars for 3300.00 and under then you should start going into business.
10-08-2007, 07:36 PM #25
- Jul 2007
- tennessee
not possible updated fuel lines... you have to have them.... 97 vette lines are the best to go with if your going to do it... and like he said.. the list goes on and on and on... people usually just list the main things you need... comp. rails, k member.... they dont list the other things that add up to be a few grand.. cause yes they are small things... but 60 bucks here and 40 bucks there.... its a pretty penny...
10-08-2007, 07:54 PM #26
- Aug 2006
- Streetsboro, Ohio
yup, I hear ya, I have seen some people, try to re-use the old lines by trying to flare the end of the old lines and using a hose clamp or 2, dosent work well with 30+ psi. Its even more $$$ if you upgrade the lines to braded hose and add an external pump to it.
Ill say it again, if you want to upgrade a LT1 to a LS1..get a wrecked LS1 car and then do your swap, I bet you will call me and say "thank you sir ... may I have another."
10-08-2007, 08:13 PM #27
- Aug 2006
- Streetsboro, Ohio
I almost forgot the best part of all....You will most likely need a computer tune/reprogram as well. Cuz most likely the engine/trans PCM you get from a yard will probibly be programed for a different ratio of gear then the Lt1 has. It is possible that you would get lucky and have the same ratio that the LS1 PCM you get will have, but most likely not. Yes it can also be fixed with a hypertech or diablo sport, but again thats about 400.00-500.00 just there.
10-08-2007, 08:58 PM #28
- Jul 2007
- tennessee
haha ive never heard of that one... fuel lines are a must... dont rig it... buyer a honda before you do that shit haha..... people today.. i just dont think people realize how much it costs... but back on topic... if your planning on doing it... buy a 99+ sixer and do that swap then... if you have a longblock.... you will only need about 3,500 more....
10-09-2007, 04:26 AM #29
- Aug 2006
- Streetsboro, Ohio
10-09-2007, 09:02 AM #30
10-09-2007, 09:54 AM #31
- Oct 2007
- CANFIELD, OHIO
PEWETER METALIC- 2002 CAMARO Z-28 M-6
Thanks for this Great info guys! Im still buying the motor and Stuff. But I may keep the new motor Have it as a spare and sell the 93 T/A and Buy this nice black 00 WS6 6spd my neighbor just put for sale today! Ive been drooling over the Car since I moved up here in 03!
10-09-2007, 12:07 PM #32
- Aug 2006
- Streetsboro, Ohio
cool...just remember.....Drive it like you stole it......
10-09-2007, 01:49 PM #33
10-09-2007, 04:46 PM #34
- LA
10-09-2007, 05:43 PM #35
- Oct 2007
- CANFIELD, OHIO
That would be hot as hell!!! but I like the looks of the late models a little bit better. I called my neighbor he only wants 8k for it and its got 53k on the clock. I told him consider it sold. Im going to try and find a junk yard lt1 for the 93 to get it running, yank the hotchkis suspension off and swap it on the 00, then sell the 93.
10-09-2007, 08:52 PM #36
10-10-2007, 06:38 AM #37
- Oct 2007
- CANFIELD, OHIO
The title is clean, its always been garage kept, He did tell me it was hit in the rear once back in 01 but it was at 20 mph and only the bumper cracked. Honestly whoever did the body work did a good job cause all the lines are tight and match. I thought the same about the price but Im taking to my friend whose a gm tech at a pontiac chevy dealer up here to go over it. If there is anything wrong he will find it. Fingers crossed this will be the right car if not oh well back to looking around
Engine swap
By FOSTER21 in forum CorvetteReplies: 0Last Post: 09-11-2008, 09:13 PM -
engine swap
By larry111069 in forum General HelpReplies: 1Last Post: 12-20-2007, 10:37 PM -
Engine swap and computer swap
By mrmiatanut in forum Computer & TuningReplies: 4Last Post: 09-08-2007, 05:10 PM -
Engine Swap from v6 / v8...
By j_j_mccoy RS in forum Camaro / SSReplies: 15Last Post: 04-28-2007, 03:23 AM
