Results 21 to 40 of 70
Thread: Fastest 98-02 SS??
09-08-2009, 12:38 PM #21
09-08-2009, 01:54 PM #22
What do you think better sealing of the rings and more useable rpms will do for the motor........slightly better power. Do research to back up your statements like I did. I'm not saying a LS6 block vs LS1 block that the LS6 will come out everytime.......depends on too many factors. But ask any REAL engine builder and the LS6 is the way to go. No argueing that point. Engine builders that I have talked to (on this site and off) say any where from 5 - 15 rwhp which isn't much by any means but in this day and age, every bit counts. And 01-02 had the LS6 intake which is another reason why they run faster times.
09-08-2009, 03:05 PM #23
09-08-2009, 03:13 PM #24
Not really guys. The LS6 intake isn't worth mentioning on the 01-02 cars. They also got the whimpy truck camshaft those years.
In all honesty it was a trade off.
Kind of like, damned if ya do, damned if ya dont.
09-08-2009, 03:20 PM #25
09-08-2009, 03:45 PM #26
You stuck an LS6 intake on a 2000 model that has the .500 lift camshaft,,,so it's no surprise you saw a nice improvement.
Try that on an LS1 with the little truck cam and it's not that steller. You could pull that cam and stick the little .460 lift cam in there,,,and I bet you'll find a rather noticable power drop,,,especially up top.
I have a 2000 and a 2002. I just recently stuck an LS6 intake on the 2000, and noticed some difference. I can also tell you that my 2002 with the stock truck cam feels like a pooch above 5,500 or so.
09-08-2009, 03:52 PM #27
09-08-2009, 04:53 PM #28
02 Cam
I have an 02 Camaro, and Ive been looking for the block number with mirrors for quite a while and havent had any luck. The other day I jacked the front of the car up and looked between the transmission and the driver side cat and could see the number clear as day. I have an ls6 block on mine, and with slp Y pipe, mass air, lid and filter and Corsa Exhaust, I can run 13 flat babying it or high 12s beating it all day long. The guy I got mine from said he ran a 13.1 bone stock.
09-08-2009, 05:07 PM #29
09-08-2009, 07:16 PM #30
09-08-2009, 08:57 PM #31
The bigger cam in the 98-00 mattered just as much as the ls6 intake on the 01-02. An ls1 is an ls1 thank you and goodnight.
09-09-2009, 05:20 AM #32
Tuning
I thought about getting it tuned, but im waiting to see what direction I will go with it. Id like a P1sc, and some QTP long tubes.
09-09-2009, 05:50 AM #33
- Mar 2009
- Milwaukee
Arctic White, red/gray- 1997 Corvette, 92 Typhoon
09-09-2009, 05:55 AM #34
Here you can see for yourself http://www.smokemup.com/tech/ls1.php
But to give you an idea.
98-00 models
202 degrees at .050 intake
210 degrees at .050 exhaust
.496 lift intake and exhaust with 116 lobe sep angle.
01-02 models
197 degrees at .050 intake
207 degrees at .050 exhaust
.467 lift intake
.479 lift exhaust with 116 lobe sep angle.
As you can see the 98-00 models had 5 degrees more duration on the intake side and 3 degrees more on the exhaust side. Almost .030 lift is given to the 98-00 models on the intake, and .017 on the exhaust side.
When it comes to camshafts that's a sizeable difference and could mean quite a few HP. In this case, about as much as an LS6 intake is worth on a stock motor.
09-09-2009, 06:04 AM #35
In BlackSS's defense,,,there is alot of truth to ring seal and HP. GM went to a smaller ring pack on these LS engines,,,,3mm to be exact. You have less drag (ring pull/drag is measured on our high end engine builds) Less friction and/or drag means more HP,,,but GM also did this for fuel economy reasons.
When you get into small ring packs such as the LS series,,,,ring seal becomes an issue,,,especially on street motors destined for 100,000 miles.
That's the biggest reason you see vacuum pumps on race engines, to promote better ring seal, makes HP.
Having the crankcase ventilated properly promotes ring seal.
Now it is said the LS6 block does this better. I can't personally say for sure but I believe that is what BlackSS is referring to. Now whether the LS6 block would make more power remains to be seen, on a stockish motor with these whimpy camshafts I'm betting you wouldn't see any.
Once you start building some cylinder pressure though,,,,the outcome could be different.
09-09-2009, 08:36 AM #36
- Mar 2009
- Milwaukee
I have said many tiems the ls6 is better for building because of these reasons but stock vs stock a ls6 block f-body vs a ls1 block f-body should be a drivers race requardless of block. And on dynos they put down the same numbers. Assuming you have 5-15 more whp because you have a ls6 block is silly.
09-09-2009, 08:37 AM #37
09-09-2009, 09:04 AM #38
- Mar 2009
- Milwaukee
09-09-2009, 09:42 AM #39
09-09-2009, 12:28 PM #40
- Mar 2009
- Milwaukee
228/228 .588/.588 112lsa, very fun
What is the fastest 0-60
By Mike0202 in forum Firebird / WS6Replies: 9Last Post: 12-01-2009, 06:19 AM -
Fastest 346 On Nos
By O-YES-NOS in forum NitrousReplies: 12Last Post: 11-23-2006, 06:24 PM -
fastest LT1?
By bmoney in forum LT1Replies: 11Last Post: 01-08-2006, 09:33 PM -
The South's fastest car?!
By BadBlueBird* in forum Southern MembersReplies: 82Last Post: 11-19-2005, 09:31 AM
