Results 21 to 26 of 26
Thread: My trans am needs help
11-05-2009, 02:15 PM #21
11-05-2009, 03:19 PM #22
The slave is located inside the bell housing, most likely it has blown out and need to be replaced, hence the no fluid. To replace it you need to drop the trans, and while your are at it, might as well do the clutch and anything else that might need looking after while you are in there.
11-09-2009, 11:52 AM #23
kentucky speed is a sponsor here and had a sale on clutches not to long ago, talk to them and see what they can do for you
11-10-2009, 10:25 PM #24
- Nov 2005
- Missouri
Torch Red- 1999 Corvette Hardtop
If the clutch fluid was low or gone, you def have a hydraulics problem. Time for a new slave cylinder or master cylinder, or maybe both, then it will need bled, your clutch may be ok, just have to check it out when you drop the tranny. Labor wise, you would save if you did them all at the same time.
If it were me, I would do a new master, slave cylinder, with the drill mod, and a new clutch with a alum. flywheel. And a new pilot bearing, rear main seal, tranny mount, and tranny fluid change. Also have the tranny seals and u joints checked when the tranny is out. But thats just me.
11-10-2009, 10:33 PM #25
www.kyspeed.com can get great deals on the LS7 clutch's.
Bleeding is simple with a 30 dollar Mity Vac. 15 second job.
11-10-2009, 10:49 PM #26
2002 Pontiac Trans Am WS6 - A Trans Am Owner Transfuses His
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 12-02-2011, 12:22 AM -
2000 Pontiac Firebird Firehawk Trans Am, T-Tops, Auto Trans
By Handyman401 in forum Vehicles For Sale / TradeReplies: 0Last Post: 11-20-2011, 05:33 PM -
For Sale: mt et street radials/b&m trans cooler/tci deep trans pan
By senicalj4579 in forum Parts For Sale / TradeReplies: 7Last Post: 12-10-2010, 08:34 PM -
1999 Pontiac Trans Am SLP Performance Parts Test - Trans Slam
By Ed Blown Vert in forum GTOReplies: 0Last Post: 09-29-2007, 06:50 AM -
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-29-2007, 03:10 AM
