Results 21 to 25 of 25
06-25-2011, 03:18 AM #21
- Nov 2006
- Indianapolis
Well then the wiring/socket is ok to the one light that works. But it should come on and probably not flash with the R turn signal as well. If it doesn't, and that side brake lights don't work, it may be a turn signal switch or the wiring to the socket that doesn't work is bad.
Sure sounds like the turn signal switch is going bad, the only way to know for sure is trace down the wiring. I used to have a diagram but I don't anymore, that way I could tell you which wires to check.
06-25-2011, 07:44 AM #22
is there a good write up to change it cause ill pull the one out of the camaro and see what that does
06-25-2011, 09:31 AM #23
well i took my tail light apart again and switched the bulbs around and its working now idk if the guy at the parts store gave me the wrong bulbs or what. i took the bulb from the revese light and put it in and she lite right up so i dont have a reverse light but i have tail lights!
06-25-2011, 12:45 PM #24
- Nov 2006
- Indianapolis
The reverse light is not the right one, it only has one filament. Or should only have one.
06-25-2011, 01:23 PM #25
thats what i thought
Guages arent working!
By Dave-TransAm in forum Firebird / WS6Replies: 2Last Post: 12-30-2011, 03:36 PM -
Wipers arent working..
By Lunatikgixxer in forum General HelpReplies: 9Last Post: 01-26-2011, 08:29 AM -
Dashboard brake light stopped working
By chuckstop00 in forum General HelpReplies: 3Last Post: 06-03-2008, 03:42 PM -
my blinker is not working??
By Hector in forum General HelpReplies: 23Last Post: 12-30-2006, 09:59 AM -
I'd like my MOD status back, PM's arent' working....
By Pete2k_Z28 in forum Request and FeedbackReplies: 15Last Post: 08-25-2005, 06:49 AM
