Results 21 to 36 of 36
Thread: Which Aftermarket Rotors?
10-10-2005, 10:22 AM #21
Originally Posted by delinquent543
I have the OE Brembo rotors all around, metal master pads up front, hawks out back. NEVER GET METAL MASTERS. They dust like a motherfucker and squeak like a sick bitch. As far as performing goes, they are just as good as the OEM replacement.
Only thing I would do differently is to get Hawks all around.
Metal masters....jesus, what the fuck was I thinking.
Oh yeah, reason why I didnt get drilled was cuz of the crack thing and slotted I didnt get cuz, well, can you re-surface slotted rotors?
P.S. Since Powerslot has decent prices, I WAS going to go with the slotted/drilled combo ones..BUT. If you read carefully, the drilled holes are for LOOKS rather than performance.Last edited by AKIRA; 10-10-2005 at 10:24 AM.
10-18-2005, 06:28 PM #22lt11leGuest
I drilled my stock rotors and they work great!?!?
this is just a joke and don't try it at home....LOL
11-02-2005, 08:12 PM #23
- Texas
Black- 2002 WS6 Trans Am
Anyone put a Baer GT+ kit on the front?
11-02-2005, 09:09 PM #24
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
I have to agree with the Sarge on this topic.... I speak from experience also and I will tell you that all cross-drilled rotors I have ever used have had seriouse issues with cracking. If you want something fancy for the daily street go with something that is slotted and not cross-drilled. I personal just bought a set of Powerslots for my 02' Z28, I now own 5 sets for 5 different vehicles and I have never had a problem with them. The zinc plating they give you is awsome for corrosion protection!!! As far as pads go I am running VGX Semi-Metalic Carbon pads. I love them!!!! They are smooth, guiet, and really can stop on a dime.
Ps... The powerslots look awsome if you have an opened up rim design
11-03-2005, 02:38 AM #25
cross drilled rotors suck but powerslots make a dimpled and slotted rotor which are great
11-04-2005, 01:10 AM #26Anyone put a Baer GT+ kit on the front?
I previously had the Powerslot rotors with GM Durastop & Raybestos Quiet Stop pads - nothing wrong with that setup either. Actually I liked these pads over the Hawks - very low dusting on all types, but the Hawks seem to break in much differently (at least the way I'm using them). Next time I'll go back to the GM/Raybestos pads.
One thing I didn't like about the Baer kit was the fact I was told by Baer they would fit with the 17" TTII's (I know, I should have used the template to check for myself) Guess what - the inner bulge out of the wheel right behind the spokes locks up solid on the leading edge of the caliper fins. Found this out after already modding my spindles for the Baer kit - so couldn't stop at that point.Had to grind off the leading edge of all caliper fins to clear. Of course that removed the powdercoating so I had to touch that up with paint.
On top of that the front nose of both bottom control arms had a rather large weld that hit the backside of the rotor braking surface (another nicety that was not in the instructions) Had to grind the welds flush around the nose on both sides.
Besides those problems everything else has been peachy with the baer setup
BTW, the T/A is actually the 1st car I have owned that seems to have the brake bias between front and rear fairly good. My rear pads wear almost the same amount as the fronts - which means the rear brakes must actually be doing something. All other cars I have/had still have the factory rear brake pads/shoes on them after years and years but the fronts I need to change every year. Means to me that the rears on most cars do almost nothing other than help 'slow' the car.
11-14-2005, 12:07 PM #27
Ceramic pads
Anyone every tried these? I think they work good...and NO brake dust !!
11-14-2005, 12:20 PM #28
- Severna Park, MD
Autozone rotors are excellent and the price can't be beat
Autozone rotors are excellent and the price can't be beat. Drilled and slotted are only eye candy. If you want to barke better upgrade the brake lines to satinless steel. This is an excellent brake upgrade, one the ACTUALLY decreases stopping distance.
11-14-2005, 12:44 PM #29
Originally Posted by BBATCAR
05-11-2006, 08:11 PM #30
- North San Diego Co.
Black- 1998 Camaro Z28
okay so is there a consensus on this board about rotors?
mine are warped againand I need to replace them SOON.
powerslots sound good but who sells them cheapest?Steve
1998 Black Z28 Pro 5.0 shifter, Borla Catback, DirectFlo Lid, !CAGS
05-11-2006, 08:34 PM #31
Originally Posted by RaSScal
05-12-2006, 07:00 PM #32
- Jan 2006
- Maryland
red- 1999 WS6
I have brembos all around and akebono pads havent had problem in six months
05-12-2006, 08:36 PM #33
- Feb 2006
- GARDEN GROVE, CA
BLACK- 2002, CAMARO Z28
I have Powerslots slotted and dimpled rotors on the front for about 1 and half yrs with no warping. I have hawk pads and they do squeak some but the braking is good. Before the Powerslots my rotors would warp in 3k miles. The stock ones twice and Autozones 2 twice.
05-14-2006, 08:30 AM #34
i just bought a complete set of Brembo rotors w/ hawk pads, and no problems so far. Very good response so far. I haven't replaced my calipers, but i want to at some point. Baer Eradispeeds are great too. Those were my 2 choices, and i went w/ brembo.
good luck
Whisper Lid/SLP HarmonicBalancer/MAFTranslator/DiabloTuner A-Pillar Gauges (Aem Uego A/F,Trans Temp, D-Pic)Magnaflow CB w/CME Tips/ Eibach Pro Kit/ Brembo Cross Drilled/Slotted Rotors/ H.I.D.Kit
05-14-2006, 08:39 AM #35
- Feb 2006
- Long Valley, NJ
Black- 2002 Camaro Z-28
anyone ever tried doing the Z06 caliper conversion? I heard doing that was a pretty good setup considering most brakes you buy will warp with the stock calipers. with the Z06 conversion, its a direct bolt on, and you get an extra inch of rotor which as you all know is more stopping power for those of us that have good amounts of power on here.
05-15-2006, 07:36 PM #36
- Burlington, NC
Black- 2000 Camaro SS
If you want the BEST brake rotors and pads have a look see here:
http://www.sp-performance.com/
Question: Aftermarket Name Brand Rotors
By Agarcia67 in forum General HelpReplies: 13Last Post: 03-03-2014, 02:21 PM -
Aftermarket pads and rotors help?
By jdizzim in forum Firebird / WS6Replies: 2Last Post: 04-09-2012, 08:26 AM -
new rotors =D
By blackbird0230 in forum Appearance SectionReplies: 12Last Post: 08-28-2010, 08:57 PM -
Question: Need aftermarket rotors for Yukon
By MrMasterCraft in forum GM TrucksReplies: 3Last Post: 02-28-2010, 08:24 AM -
Rotors
By najaf4life in forum General HelpReplies: 31Last Post: 10-25-2008, 04:45 AM
