Results 21 to 26 of 26
Thread: Turbo LS1 with 317 Heads
01-30-2013, 01:40 PM #21
was wondering, what do you think aout running 317 heads with cometics .040 gaskets that put the CR (calculated of course) to about 9.9:1 CR? with a TU1 or simlar cam?
01-31-2013, 07:38 AM #22
Well I'm going for a low compression build my 317s LS9 gaskets and the LS1 we are think I am around 9.5:1... I'm sure it won't matter but for boost I wanted mls gaskets
01-31-2013, 09:16 AM #23
so as long as they are MLS they shuold be fine? the cometics are MLS
01-31-2013, 09:47 AM #24
Ya I guess they are lol but the LS9s have more layers for better sealing under boost
01-31-2013, 11:50 AM #25
i dont plan on anything over 14 psi (hell im gonna stay under 12psi for that matter lol) and im gonna run studs as well, so unless someone has had some heads leaking with this setup, i think im gonna go this route. 9.9ish CR should be an ok drop with pump gas, intercooler, and meth right?
01-31-2013, 12:11 PM #26
Should be fine...
317 heads and gasket help related to turbo info
By JoshuaGrooms83 in forum Internal EngineReplies: 9Last Post: 02-17-2013, 05:44 PM -
Turbo, LS6 heads, MS4 cam, PRC Dual valve springs 92mm TB
By woodymaro in forum Parts For Sale / TradeReplies: 32Last Post: 12-27-2011, 06:30 AM -
turbo heads
By DreamLS1 in forum Forced InductionReplies: 5Last Post: 04-19-2008, 04:04 AM -
Heads/Cam for Twin Turbo's
By Bouvers in forum Forced InductionReplies: 0Last Post: 09-16-2007, 02:24 PM -
Turbo or Heads cam package
By 95TA383 in forum Forced InductionReplies: 0Last Post: 04-09-2006, 04:30 PM
