Results 21 to 40 of 111
Thread: cam too big?
07-07-2008, 06:41 PM #21
- Thornton, CO
Not unless you find it used.
07-07-2008, 06:43 PM #22
What do ya'll reccommend for a lid, pushrods and springs cause i'm gonna order all that tonite so i can get up to atlanta asap...
Does anyone know who the good dyno tuners are in the atlanta area?
yeah i'll just get the cam off the texas speed website
07-07-2008, 06:45 PM #23
98 Ticket Red Z28
Mods: Front/rear sway bars, poly bushings all around, Bilstein Shocks, Centerforce Dual Friction Clutch, Pacesetter LT's, 2.5" Custom True Duals over the axle with Magnaflow mufflers, Shortened Pro 5.0 shifter, TurnOne PS pump.
07-07-2008, 06:47 PM #24
so new motor mounts? oil pump?
07-07-2008, 06:48 PM #25
yeah man heres the link http://www.texas-speed.com/shop/item...d=167&catid=44
is that workin?
and google 228r and it'll show forums where people just go on and on about how awesome it is...
07-07-2008, 06:51 PM #26
- Thornton, CO
Mileage on the motor??
Motor mounts...are a pain in the ass to replace. Nice to have though. Probably not needed at this point in your mod list.
If you have a strut tower brace, remove it before finishing the mount install. I cracked an intake with my Prothane mounts since they lift the motor just a touch.
07-07-2008, 06:54 PM #27
i'll turn over 65k this week, it's just that i've heard the headers will bang the floorboard sometimes w/o motor mounts and while i have access to all the tools i want i figured i'd do it.
what springs and rods should i get with it... should i get them off texas speed?
Stock length rods right?
Do i need to get the basic camshaft bolt and gasket kit with it on the site?Last edited by chevyss1234; 07-07-2008 at 06:58 PM.
07-07-2008, 06:56 PM #28
- Thornton, CO
Tools or not...Pain.
65K miles. Oil pump would be a good idea.
07-07-2008, 07:01 PM #29
damn which oil pump should i get, i dont know where to start with that
07-07-2008, 07:03 PM #30
07-07-2008, 07:06 PM #31
oh that's not terrible, and i'm guessin i should get a new one?
What brand motor mounts?
Do i need this: http://texas-speed.com/shop/item.asp?itemid=85
oh just found a ported one for 160 nvmLast edited by chevyss1234; 07-07-2008 at 07:08 PM.
07-07-2008, 07:08 PM #32
- Thornton, CO
Always nice to have new bolts. Crank bolt is 100% needed.
Prothane motor mounts from Thunder.
07-07-2008, 07:18 PM #33
word, by the way thanks for the help man
07-07-2008, 07:29 PM #34
i should get comp 918 springs i assume?
i'm gonna get stock length rods comp rods, doesnt really matter brand i'm guessin
07-07-2008, 08:48 PM #35
do i need new retainers for this cam?
07-08-2008, 05:06 AM #36
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
Basically all that I have done to the car are lid, long tubes (kooks), true dual exhaust, and a tune. I still even have a few free mods that need to be done (tearing out the AIR pump today). It is a solid DD cam as long as you get a good tune. You could even get a tamer cam then mine since I have the 112 lsa.
I like the cams from Vengeance, but the TSP 228R is a solid cam as is there 224 if you want something milder. I just prefered to have a little more on my exhaust side of the cam instead of running a symmetrical cam like the 228.
For springs I am using the Patriot Dual Golds. Good cheap spring with all the little bits you need and they are a steal about 255, and I feel a little better running a dual spring in my DD.
Pushrods are a debate, I run the stockers, but I know many people recommend to get hardened.
07-08-2008, 07:15 AM #37
word i just decided to go with the 228r and now i'm just lookin for a good place to get a tune in the atlanta area
07-08-2008, 07:24 AM #38
- Thornton, CO
Get the Patriot Dual Gold springs.
Everything you need.
07-08-2008, 07:27 AM #39
ah damn i already got the comp 918s, but i called texas speed and they said the comp 918s would be fine, do you think i'll need the dual gold ones?
07-08-2008, 07:29 AM #40
- Thornton, CO
I would see if you can back out of the COMP's.
They have had issues with them breaking over the last 2 years.
Some will say it was a bad batch, some will still use them. Start failing at the rate they did...and I refuse to use them.
