Results 21 to 27 of 27
02-26-2009, 09:34 AM #21
No you would fine with a 10.5" wheel! But even staying with a 275 would still be NIGHT and DAY difference from those Nitto's.
Time slip's are a hush hush for me sorry. . . . . . I can tell you I have "stock sus." F-bodys on a single stage that do 1.58-1.64 60's ALL Day on a 275.
Yes it would be well worth the swap if your making ANY type of real power.
Do you still have stock rear springs? If so get a pair of V-6 rear springs from the junk yard. Also take a cut off wheel on a dia grinder and cut off ANY access threads you have on your front sway bar end links. When you get to the track it will take you 5 min. to undo the bolts and nuts. It will gain you at least a couple of inches in front end travel which will equal MORE WEIGHT TRANSFER.
Do you street race alot? You don't have to answer that ? on here! Anyways if so the 18's are a big ADVANTAGE in my eye's because you can get ALOT more kids to race you with there shit box import's thinking you can't hook.Don't be afraid of the bottle!!! Be afraid of your tune!!!
02-26-2009, 10:50 AM #22
I got 17s. I went with em because tires were way cheaper...most people can't tell the difference in 17s and 18s anyways.
I've raced on the streets...not afraid to say it. Still on stock suspesion besides SFCs. My next mods for suspension would probably be LCA relocation brackets and a TQ arm though.
Just curious would I could get for a 60' the way i sit though..pm me if ya like. I just wanted to know if the 325s would fit in the wheelwell. Main reason being traction and 60' fts but, damn it'd look BADASS too. Also, what kinda mileage can I get out of these?
02-26-2009, 11:55 AM #23
O.E. Concepts has a 18x10.5" +58mm c6 z06 wheel. I could get different rims, but I just got them and i don't really wanna switch rims yet. So i could just upgrade to these 18s.
Would the +58mm work? Life of these DRs?
one more ?
what's the difference between these and MT ET STREETS II?Last edited by allbaugh_04; 02-26-2009 at 12:11 PM.
02-26-2009, 09:34 PM #24
325s on a 10.5??? really?
people think im crazy for 315/30/18 MT et street 2 drag radials on my 10.5s much less a 325!
02-27-2009, 03:11 AM #25
02-27-2009, 03:20 AM #26
Yeah your tire is VERY different! It's a little rubber band that is a mear 25.5" in overall dia. The tire we are talking about has a REAL sidewall and is 28" in dia.
As I said I would run the 275 but he would be ok due to the fact it has a large sidewall which will flex alot more WITHOUT cupping the tread.
02-27-2009, 08:06 AM #27
Thanks Tuner
Looking for new drag radial
By RONS98TA in forum Wheels and TiresReplies: 1Last Post: 08-16-2013, 05:15 AM -
drag radial
By fastt in forum Wheels and TiresReplies: 12Last Post: 09-21-2010, 10:27 PM -
Which is the better Drag Radial?
By 2001ws6ta in forum Wheels and TiresReplies: 1Last Post: 02-03-2009, 09:17 AM -
is 255 Drag Radial enough?
By ApexVIII in forum Wheels and TiresReplies: 2Last Post: 08-24-2007, 01:28 PM -
best 18" drag radial for streets
By Nhra Firebird in forum Wheels and TiresReplies: 4Last Post: 06-01-2006, 06:25 AM
