Results 21 to 31 of 31
Thread: DD knock rattle? I'm lost
06-12-2012, 06:28 PM #21
Thanks I'll add that stuff to my list,
I had some people suggest cracked transmission mounts and maybe a cracked flywheel, judging from my video and the info I've provided do either of those sound legit,
Also has anyone here ever even heard a sound like that before?
06-12-2012, 08:30 PM #22
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
What's your oil pressure look like when it's idling? How about when you're driving? What does the oil pressure gauge indicate when you're in park with the engine idling once the car gets up to operating temp?
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
07-15-2012, 05:19 PM #23
update i finnaly pulled the oil pan because a few friends said after hearing it in person that it sounded much more mechanical than fuel related so i am starting there now, i took some pics and am wondering what i should be looking for on the bottom side of the motor dont know much about whats going on down there. thanks
IMG_0716.JPGIMG_0717.JPGIMG_0718.JPGIMG_0719.JPGIMG_0720.JPGLast edited by thefridge; 07-15-2012 at 05:21 PM.
07-15-2012, 06:00 PM #24
- Apr 2012
- virginia
blue- 2001 trans am
did you find any metal shavings or anything in the oil pan? I would check to make sure nothing is loose while your down there. Doesn't hurt to look for a worn bearing.
07-19-2012, 02:27 AM #25
Can't tell anything from the pictures..
Reach up in there with your fingers and give the rod caps a wiggle.
If any one of them move around easier than the others you have a spun rod bearing.
07-19-2012, 02:33 AM #26
07-19-2012, 02:42 AM #27
10-18-2012, 04:48 PM #28
Sorry I haven't updated I was deployed, anyway it's a t56 so flex plate/ t converter, don't thnk it's those lol
10-19-2012, 08:49 AM #29
Haha yes that changes things..lol
10-19-2012, 07:06 PM #30
Pull the plugs and check if one is wet. Get a mechanics stethoscope and try to isolate the sound. I had a similar noise that turned out to be a bad cam that then chewed up the the lifetr rollers.
10-19-2012, 07:54 PM #31
Seeing as you just got the headers installed have you re-checked the header bolts? sometimes they can back out of the hole a little and cause a leak, Also depending on the brand/type of gasket used you may have a leak at one of the gasket contact points?....
knock knock...who's there? wait...engine knock...
By jiveass in forum Internal EngineReplies: 60Last Post: 04-26-2011, 07:04 AM -
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
will bad knock sensor knock down hp
By zaaronz in forum General HelpReplies: 11Last Post: 10-14-2010, 04:49 PM -
Anybody know any good knock knock jokes?
By preston1980 in forum Almost Anything GoesReplies: 15Last Post: 07-22-2009, 01:35 PM -
5.3 rattle rattle knock knock........ NOOO!!
By crawdad369 in forum GM TrucksReplies: 5Last Post: 02-14-2008, 01:38 PM
