Results 21 to 40 of 42
10-18-2009, 09:03 PM #21
I agree with you too but that still having reverse is messing me up. Either way though 2-4 or sunshell I think it has to come apart. I have had them do really odd things when a sunshell is breaking or broken. once I had a problem with the trans missing the 2-3 shift add readline the motor every time when I operated the manual valve from 2nd to 3rd and worked fine with the manual valve in OverDive . It was a cracked HP sunshell. another time I lost 2,4 and R. Again broken sunshell. They never seem to do the same thing for me they always keep me guessing.
10-19-2009, 04:17 PM #22
Could the band be broke?
10-19-2009, 04:19 PM #23
I can put it in reverse and get on it with no problems
10-19-2009, 04:23 PM #24
I've disassemble servo and inspected all the seals. Pulling what hair I have out. I'm going to drop pan and again and apply band with presure and see if I can turn output shaft, will this confirm any band problem?
10-19-2009, 05:07 PM #25
- Apr 2008
- Madison, WI
Seriously, its time to pull the trans out and disassemble it at least down to the sunshell. I've never seen or heard of a broken band so that's probably not it.
10-19-2009, 05:14 PM #26
10-19-2009, 05:16 PM #27
- Apr 2008
- Madison, WI
I don't know, thats what I would do.
10-19-2009, 05:33 PM #28
Ok I'm going in, I'll let you know if you were right, thanks
10-19-2009, 06:02 PM #29
- Apr 2008
- Madison, WI
10-20-2009, 07:02 AM #30
either the 2-4 band or the servo isn't getting fluid pressure. been there done it many times.
11-07-2009, 07:12 AM #31
- Nov 2009
- Joplin, Mo
Red- 1998 Suburban
Same issue
Have you found a solution. I am having the exact same problem. I lost reverse, 2nd and 4th. Pulled the tranny, replaced the broken sunshell with the beast sunshell. Easy money, now have reverse, but still no 2nd and 4th. So upgraded to the corvette 2-4 servo, still nadda. Band was in good shape, sunshell is new. Baffled?
11-07-2009, 08:45 AM #32
should have replaced the band. did you check the piston travel to engage the band?
11-08-2009, 07:28 AM #33
- Jan 2006
- cedar falls
white- 1999 suv
forward sprag is broken
11-16-2009, 03:51 PM #34
- Nov 2009
- Joplin, Mo
Red- 1998 Suburban
Fixed
Replying my own quote. I found the issue with my trans.
I dropped the pan, checked to make sure the servo was working and engaging the band. Worked Jim Dandy. Dropped the valve body, tore it down, checked and cleaned. checked the electronics, all good. Turns out after a phone call to local trans shop/parts supplier, he is about 70 years old. He told me to check my separator plate. Sure enough, there lies the problem. 2 holes were elongated. Bought a Trans-Go separator plate, He drilled a couple holes out. Put it all back together. Works perfect.
11-17-2009, 08:24 AM #35
11-17-2009, 04:18 PM #36
- Apr 2008
- Madison, WI
LOL...Thats weird. How did the sunshell strip out and 2 holes in the spacer plate elongate at the same time??
Well, glad you got it fixed. Now I really wanna hear what the OP finds with his!
11-19-2009, 12:14 PM #37
my trans started doing the same thing on friday Wont shift into 2nd or 4th and no reverse at all took it to a shop and they said they want 1400 for a complete rebuild and a new torque converter from reading this it sounds like its just my sunshell what do u guys think
Built A4 with B&M Transpak shift kit, Hooker Lt's, 0RY, 4in cutout, Debaffled, K&N, SLP Lid, Bellows, p+p+descreened MAF,TB bypass, 180 degree Theromostat, AC removed, RP Trans fluid, oil, MSD 8.5 wires, Autolite Xtreme perf plugs, Nitto DR
Coming soon SFC, 373 gears, 96mm intake/96mm TB, Tune
11-19-2009, 04:53 PM #38
Haven't tore in to mine yet but plan to soon and I will post what I find.
11-19-2009, 07:08 PM #39
Sounds like the sunshell. You have to tear it far enough down that if it hasn't had a rebuild and has some miles on it it would be worth it to just fix the weak links with a beast sunshell, good clutch pack, bands ect. New T/C just because you never know what kind of fragments might have been released when it broke. They can cause all kinds of problems in the T/C and if they make thier way back to the valve body you will chase problems untill you tear it apart and start all over. If it's an older or stock T/C I would upgrade it a bit.
11-19-2009, 08:43 PM #40
ya ive got 134000 miles so it could use a rebuild it needs to be updated
Help: 4l60e crazy shifting issues! long story behind it
By jessimusprime in forum Automatic TransmissionReplies: 5Last Post: 01-09-2013, 11:30 AM -
Ratchet Shifting a 4l60e
By MudStainKILLA in forum Automatic TransmissionReplies: 29Last Post: 04-18-2010, 09:07 AM -
4L60E shifting problem
By shiftless in forum Automatic TransmissionReplies: 4Last Post: 05-30-2008, 02:04 PM -
1995 Trans Am 4L60E shifting problem
By 1999TransAmWS6 in forum Automatic TransmissionReplies: 0Last Post: 08-30-2007, 06:30 PM -
problems with 1996 4L60e trans shifting
By acollins2187 in forum Automatic TransmissionReplies: 4Last Post: 07-06-2006, 08:04 AM
