Page 124 of 357 FirstFirst ... 24748494104120121122123124125126127128144154164174224274324 ... LastLast
Results 2,461 to 2,480 of 7122
  1. #2461
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Looks good.
  2. #2462
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Quote Originally Posted by robcas47 View Post
    Installed this 8" Bazooka, it's ported and sounds decent. also installed a 6.5" pyle sub in the r/s sail panel. I haven't had any speakers in the sails since I got the TA, my son was a toddler back then and I wanted to protect his lil ears. He rides up front with me now and I keep the cut-out closed and the tunes lower so I figured upgrading to a full system was due. Sort of feel like a poser with this sub but I get a kick out of it. Right now it's wired in as the l/s sail panel sub and running off the stock amp. Suprisingly it hits pretty decent, will probably add an aftermarket amp to power the two sail panel subs and the front door speakers whenever I get around to replacing the door speakers, will probably just wait till those give out since I'm content with how it sounds for now.
    I 1st read this and thought.."wtf is wrong with this guy? That's a NOS bottle." Then I noticed the speaker grille and the bass port on the bottom. I had a set of two 10" bazooka's in 1 of my old cars back in the day with a 300 watt amp. They sound really good and can be removed if you need the extra space. I did find a better sound from them if you face the sub to the rear, and move it about 7-10" away from any given wall so the sound can reflect. It will increase the bass twice as much. Just any fyi. Unstrap it any spin the baby and I bet it will sound better. Cool sub btw!
  3. #2463
    Army Dude robcas47's Avatar
    Ft. Rucker Area, Lower AL
    01 TA / 06 Duc 749D
    Thanks Ron, I tested out several different positions for this sub. Apparently the ideal position for this sub is facing a rear corner, I found that in the trunk space where the T-Tops are stored gives off the best sound. Of course I don't like the idea of not having anywhere to store my tops so up top was where it had to go. I tried out what you are suggesting but couldn't get it to work without getting rid of the divider. I also did not want the nozzle sticking over the seat, you can't tell but the line coming out of nozzle is the sub wiring. In the end having the sub facing to the left gives the driver the best overall sound, probably a combination of the 6.5" pyle sub in the l/s sail panel,(I know OP said r/s but I meant l/s), and the 8" sub facing into somewhat of a corner,(with the hatch closed and the divider in normal position). It's probably all in my head but I tried several different setups and this worked best. In the end my Lil Man in the passenger seat doesn't complain and that's what really matters.
  4. #2464
    MARYLAND
    BLACK
    1998 PONTIAC TA
    [QUOTE=robcas47;2861156]Thanks Ron, I tested out several different positions for this sub. Apparently the ideal position for this sub is facing a rear corner, I found that in the trunk space where the T-Tops are stored gives off the best sound. Of course I don't like the idea of not having anywhere to store my tops so up top was where it had to go. I tried out what you are suggesting but couldn't get it to work without getting rid of the divider. I also did not want the nozzle sticking over the seat, you can't tell but the line coming out of nozzle is the sub wiring. In the end having the sub facing to the left gives the driver the best overall sound, probably a combination of the 6.5" pyle sub in the l/s sail panel,(I know OP said r/s but I meant l/s), and the 8" sub facing into somewhat of a corner,(with the hatch closed and the divider in normal position). It's probably all in my head but I tried several different setups and this worked best. In the end my Lil Man in the passenger seat doesn't complain and that's what really matters.[/QUOT
    That's cool. I didn't know about the wiring getting in the way, and cosmetically it looks bad a$$. I made up a 12" sub box that sits in the same place yours is, because I also want to be able to store my t-tops so they don't get broken. I actually have my sub box facing the rear and painted the box a flat black so even when you try to look through the tinted rear window, you cant tell what is in there. It sticks up just a tad over the rear seat, so even from the front windshield, none is the wiser. That way the lil hood theives wont try and steal my stuff.
  5. #2465
    Member Nutball's Avatar
    Dec 2012
    Indiana
    Maple Red Metallic
    2001 T/A
    Try this. Custom box that fits in the rear corner. You can cut it to fit 12", but I had a 10" already so.....Sounds really good with 1000w behind it. Perfect spot for it.
  6. #2466
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Quote Originally Posted by Nutball View Post
    I thought about making a sub box for that spot!! I wouldn't go any bigger then a 10" sub though, not much box space for the 12" to breath. I also made up a board from mdf wood and mounted it below the latch for the hatch, then covered in the same color carpet of the trunk. Hide all the wiring behind the board for a nice custom look.
  7. #2467
    Years ago, I had a Kicker Solobaric sub mounted that way in an Eagle Talon. They hyped them for the small enclosures that could be utilized -- I think the catch phrase was "all the bass in half the space" or something like that.
  8. #2468
    01 TA / 06 Duc 749D
    I like the Stealth Box and had a couple 10" subs laying around but decided to go with the Bazooka sub mainly to try something different. I also wanted to use the stock amp for now and it pushes the 8" just fine for my liking. Very nice setup up Nutball
  9. #2469
    *whistles* There's a 4th one hidden under the box firing down..
  10. #2470
    ^^ Is that the '97?
  11. #2471
    was. I kept the box, but I believe it's since then been burnt. No big deal to build anything like that, though.
  12. #2472
    Member bhunter0830's Avatar
    Apr 2012
    Fishers (Indianapols), IN
    2009 Pontiac G8 GT
    Cleaned up the engine bay after the body shop left it a mess.
  13. #2473
    Hey, Ben. Do you have any more pictures of your car I can browse? I'm considering that color for my 78.
  14. #2474
    Apr 2012
    2009 Pontiac G8 GT
    Hope these help. If you want something specific, let me know!
  15. #2475
    Sharp car. Still don't know what I want!
  16. #2476
    Man...I wonder if I didn't own a MRM 97 Formula...
  17. #2477
    Apr 2012
    2009 Pontiac G8 GT
    If you don't like showing your amp off to the world, you could always mount it under the latch between the tail lights. There's a support bar that runs between the lights that you can tie into. Here's what it looks like and there's enough room to still store your t-tops.
  18. #2478
    Dec 2012
    Indiana
    Maple Red Metallic
    2001 T/A
    Quote Originally Posted by bhunter0830 View Post
    I like it Ben. I know what I'll be doing Saturday
  19. #2479
    Apr 2012
    2009 Pontiac G8 GT
    And take the extra step to his the wires and use a utility knife to cut a slit for your wires to come out of.
    2000 Trans Am - Sold
    BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, American Racing Torq Thrust 2's, Founders STB, LCA's, LCA Relocation Brackets, Adjustable PHB, BMR Lowering Springs. Deleted AIR & EGR & Tuned By Frost. 1 of 23 MRM with options.
    2009 Pontiac G8 GT Stock
  20. #2480
    Member jonnyman's Avatar
    Chicopee, Ma
    candy tangerine
    1998 ws6 6spd
    Thanks to Ramey and UMI's outstanding customer service, replaced a bushing for rear sway bar( First one didn't fit quite right). fixed a rear axle seal on my Moser, and put in the new UMI adjustable torque arm, and torque arm relocation bracket.
  1. new guy just got my first trans am today
    By roger_johnson2002 in forum New Member Introductions
    Last Post: 07-14-2011, 09:35 AM
  2. Found this on the windshield of my Trans Am today
    Last Post: 03-10-2009, 01:11 PM
  3. Got into an accident in the Trans Am today
    Last Post: 09-21-2008, 05:32 PM
  4. Just got my Trans Am today!
    Last Post: 09-20-2007, 10:57 AM
  5. First time at Track today!!! 2000 Trans Am ws6
    Last Post: 11-12-2005, 02:34 PM
