Page 16 of 20 FirstFirst ... 121314151617181920 LastLast
Results 301 to 320 of 382
  1. #301
    May 2012
    Nw wisconsin
    Ok, so is there any other ideas as too what will cause this? Maybe starter? Ive only had the car 3 weeks. 02 trans am ws6
  2. #302
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    yep. Starter was kinda what I had in mind.
  3. #303
    May 2012
    Nw wisconsin
    Thanks, ill try that, also I had the bypass work a few times then not. so thats todays project.
  4. #304
    Bay Area
    arctic white
    2002 z28
    I just recently performed this fix on my car and it worked, but the security light stays on. Will it go off at some point? I only have the resistor jammed into the back of the clip, I took it out and adjusted so it was in good and tight but the light stays on. Car still starts. I guess if the light doesn't go off I can just cut wires and solder the resistor in. My problem started with a solid security light and the occasion shut off ( the car) right after the first start attempt ( it would always fire up and stay on during the 2nd attempt). Finally the light started to flash and I bypassed the VATS.
  5. #305
    if it's done correctly the light shouldn't be on at all.....check your resistance values again to make sure you're right in the middle and make it a more permanent fix. I prefer solder for sure but even taping or using wire nuts would work.
  6. #306
    Bay Area
    arctic white
    2002 z28
    I figured the light should not be on. My keys tested at 9.54k and 9.56k. The two resistors i soldered together in series add up to 9.48k, which should be almost perfect. I will check it again. I had a hard time getting the connectors apart (ign to VAT module), i actually did not get them apart so i just worked in it connected. I guess if i cut the two white wire coming from the ign cylinder i could solder my resistors there, not like that ign cylinder is any good anymore. I do have one more question. i did the inital work on the car on friday so i could drive it home, the car was at my parents house, when i went to work on it again yesterday, i added a switch, the car turned out without the resistor in place ( i tested it out when i could not get the light off). Could that have to do with the sercurity light being stuck on. Like the car was giving me a fw more starts before it wouldnt start again. Sort of like when the ign cylinder was going out?? Does that make sense?
  7. #307
    I know what you're asking...kinda. There are a few levels of vats failure.....I honestly don't know all of them. It's not as simple as pass fail though. I do know that if it passes the light will go out immediately. It looks like you have pellet 14.....the median for that pellet is 9530. If it were me ( and while I was doing the work) I would get that resistor set dead on 9530. You would probably be fine with 9480 but keep in mind that there's a possibility it'll could vary outside the range. Also, are you using 5% resistors ( gold band)? If they're silver band there will be a 10% variance in there and if there's no band it'll be 20%. I honestly think most of your trouble is how you have it wired in.....make that more permanent and see what happens.
  8. #308
    Bay Area
    arctic white
    2002 z28
    Thank you for your quick replies! I will post an update once i get back under there and tackle it again.
  9. #309
    Dec 2012
    Alabama
    Quote Originally Posted by rick88 View Post
    The red bulb on the dash flashes very rapidly and a clicking noise is coming from the glove compartment and that is it. When I turn the key the bulb goes out and nothing happens at all.
    did you ever figure out what caused this problem and how to fix it? my car does the exact same thing.
  10. #310
    Apr 2013
    Arlington, TX
    1999 Pontiac Trans Am
    Security light stays solid when my car is on, but it has thankfully only stranded me once. I picked up my resistors for this "fix" today from RS, but I'm a little concerned about removing the this part of the theft-deterrent system. How many of you have installed an ignition kill switch? What style switch (lighted or unlighted, rocker or toggle, etc.)? Where did you mount it? Thanks.
  11. #311
    Jan 2012
    Granite City, IL
    I have a 5.3 that im swapping into my car. I took the original harness & turned it into a stand alone harness. Is there a way I can do something like this to to bypass vats and get my engine started without having to send it to a tuner to get removed?
  12. #312
    Madison, WI
    2001 Silverado Z71
    I assume your donor setup is based off of a 5.3 truck/Suv, correct? what year? Either way, those trucks have a different theft deterrent system and the resistor trick doesn't apply. I think there are Bypass modules to eliminate the system, but you might as well just have a tuner do it.
  13. #313
    Jan 2012
    Granite City, IL
    Ok. Thanks
  14. #314
    Dec 2008
    Miami
    Golden Brown
    01 Z28
    I went ahead and tested my key at the 20k ohm setting and it came with the result 2.96 would a 3.3k resistor work they were the nearest to 2.96 I could find I bought a 1/2 watt 5% tolerance resistor.
  15. #315
    looks like you have a #9 on the chart which is 2890-3150 with a median of 3010. That 3300 will put you out of range on that. It make work sometimes but then others it might not. You want to get as close to 3010 as you can. You can put 2 or more in a series if you need to in order to get that resistance value.
  16. #316
    Madison, WI
    2001 Silverado Z71
    +1 agreed
  17. #317
    Dec 2008
    Miami
    Golden Brown
    01 Z28
    Well I took off the kick panel and it seems that someone has already done the bypass as there is a black box where t he connectors should be but I am still having issues any thou ghts?
  18. #318
    Madison, WI
    2001 Silverado Z71
    Try measuring the resistance of the black box and consider replacing it with resistors if you find its out of spec or if you just suspect its bad.
  19. #319
    New Jersey
    1999 Trans Am
    New vats cylinders w/key are available on e-bay from 30-90 bucks with key, just need to know your keys code or ohm value to order the proper one.
  20. #320
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    So I'm trying to help a friend with this issue on his SS. We can't get it to go though. His key reads 4.4 which isn't on the scale, so I assumed they key got weak and its just sliding under the minimums of the key #11. So he got some resistors and the one he got reads 4.59 which is just above the minimum of 4.56 but it's still not working. What do you guys think?
There are currently 45 users browsing this thread. (0 members and 45 guests)
  1. Vats bypass????
    By red4thgen in forum LT1
    Last Post: 08-13-2015, 02:39 AM
  2. Vats Bypass or Air bag?
    By phish_311_live in forum General Help
    Last Post: 09-27-2009, 04:34 AM
  3. Help With Vats Bypass
    By fasted in forum Stereo and Electronics
    Last Post: 03-03-2008, 02:53 AM
  4. vats bypass
    By formy01 in forum General Help
    Last Post: 01-18-2008, 05:51 AM
  5. doing the vats bypass on my car
    By 0rion in forum General Help
    Last Post: 08-19-2006, 07:56 PM
