Results 1 to 17 of 17
06-15-2007, 03:56 PM #1Bomb Technician
- Nov 2006
- In A Jesus Christ pose.... on the banks of the Thames with Ratty and Mole.
hunter Green- 92 Camaro RS 350 Special
Not sure whats going on but car will not start.
Ok i recently bought a 92 rs that had a 350 swapped into it.
the problem i am having is the piece will start for me 85% of the time and then the rest of the time is will click and do nothing. checked all wires. its all fine. checked battery, fine. Checked fuses, fine. I am clueless as to why some times it will start and others it wont do nothing.
06-15-2007, 04:27 PM #2
Stick or auto? Starter getting switched power? Perhaps your main power to the starter grounded out of fried on a header/manifold somewhere?
Lots of things to check... we'd need more info.
Otherwise, take the starter in for testing. They sometimes get a bit sluggish and will act like that before straight up failing. $40 or so should get you a reman'd starter, so might just be a good time to try to see if that fixes it?
-Eagle
06-15-2007, 04:33 PM #3Bomb Technician
- Nov 2006
i said i checked all wires including starter. its not the starter because when it actually works it is instant. I do notice the security light flashes when i first put the key in. other than that i really dont know what else info you need. its auto. and before you suggest its not the start safety. Sorry if i seem like an ass but this is my only mode of transport and im new to GM stuff so im very frustrated.
06-15-2007, 04:41 PM #4
Alright bud. If it clicks, you either have a starter which takes too much power to turn over, a short somewhere, a weak ground (block, battery, etc) or an electrical system to weak to crank it over. Those are pretty much your choices.
If it was the security light getting you, it wouldn't even click. It would just be a complete no go. You have a bad starter or an electrical issue, just my $.02
-Eagle
06-15-2007, 04:42 PM #5
BTW, most TPI'd motors turn over VERY easily with little cranking...
06-15-2007, 04:43 PM #6Bomb Technician
- Nov 2006
it only clicks the first time then the light comes on and it wont do anything after that for anywhere from 3-15 minutes.
06-15-2007, 04:50 PM #7
Well, the only other thing I can see wrong is some flaky PASS key system failure... might try a different key, or replacing the key you're using. If that doesn't work it might be the cylinder itself.
Check this out for more info
06-15-2007, 04:52 PM #8Bomb Technician
- Nov 2006
thats describes it perfect. now how the hell can i bypass all that technical stuff
06-15-2007, 04:53 PM #9
Is the key you're using really worn? Does the ign cyl show excessive signs of wear and tear?
06-15-2007, 04:55 PM #10Bomb Technician
- Nov 2006
both are original and yes they look very very used.
06-15-2007, 04:58 PM #11
06-15-2007, 04:59 PM #12
I'd say try replacing the key and or the cyl bud... hacking the PASSkey system might not be the best idea if you're not up to it.
-Eagle
06-15-2007, 05:00 PM #13Bomb Technician
- Nov 2006
what kinda price am i looking at for this
06-15-2007, 05:01 PM #14
The key should be about $25 @ the stealership. The cylinder will be in the $80-100 range and will require quite a bit of labor to replace...
06-15-2007, 05:03 PM #15Bomb Technician
- Nov 2006
alrighty thanks a million bud, one again sorry for being an ass but after it leaving me stranded for the 15th time i decided to ask for help
06-15-2007, 05:03 PM #16
Might try autozone too, I just looked it up and it seems you can get the key and a new cyl for like $60 if you're up to doing the install yourself.
06-15-2007, 05:03 PM #17
No start, help
By dlbrando in forum General HelpReplies: 8Last Post: 10-10-2007, 10:29 PM -
whats the best mods to start with?
By greatwhiteZ28 in forum GTOReplies: 18Last Post: 07-30-2007, 12:12 PM -
Whats a good start out car?
By TripleBlackTA in forum General HelpReplies: 41Last Post: 06-16-2007, 10:49 PM -
Cold Start/Warm Start Problem
By I'mLS1John in forum General HelpReplies: 11Last Post: 02-23-2007, 08:11 PM -
By I'mLS1John in forum New Member IntroductionsReplies: 0Last Post: 02-22-2007, 06:26 PM
