06-22-2009, 11:35 AM #1Member
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
where exactly is the braided engine to chassis wir
where exactly is the braided engine to chassis ground wire I can't see it.
image would be great.
Thanks
06-22-2009, 12:41 PM #2
06-22-2009, 12:46 PM #3
I think he's aware of that, he just wants to know where it's located.
06-22-2009, 01:43 PM #4
Usually at the rear of the engine.
06-22-2009, 03:56 PM #5Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
at the rear of the engine?
I've crawled under there and have looked even at the rear of engine.
can you enlighten me on exactly where to look?
I've sean this wire years ago I think the car was on a lift, can;t remember where it's located currently car is on ramps crawled under there and just can't see it.
so please exactly where to look, image would be good.
Thanks
06-22-2009, 05:09 PM #6
are you talking about the one that bolts to the back of the drivers head?
06-22-2009, 05:35 PM #7Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
engine to chassis ground braided wire
now you maybe getting warm about it being on the driver side just where?
engine to chassis ground braided wire it's suposed to be a bare (uninsulated wire) braided wire from the engine to the chassis a ground wire.
Thanks
06-22-2009, 05:44 PM #8
yeah, it's on the back of the drivers side head. You'll have to stick your hand back there to feel it. It's attached with a 15mm bolt I believe.
06-22-2009, 05:50 PM #9Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
06-23-2009, 05:29 PM #10Senior Member
- Apr 2008
- Madison, WI
I was looking through the service manual and I'm not sure I came up with the correct answer but thought I'd throw it out here.
Ground109 - Attached to the left front frame rail, forward of the brake pressure modulator valve bracket
and
Ground111 - Attached to the lower left side of the engine, behind the generator
They are connected with a braided ground strap.
G109 = #3
G111 = #2
06-24-2009, 04:56 AM #11Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
wire
OK thanks for helping I'll snap a image if I find the wire.
cam-LTs-FAST78-Susp.-Rims
06-24-2009, 08:50 AM #12
I'm not sure but it might be easier to just add an additional wire off of the front of the engine somewhere, like the front of the cylinder head down to the frame. I've see quite a few people do this to their 4th gens.
It sure beats trying to wrestle your arm under the cowl, I avoid that if I can.
SS braided lines
By goof4080 in forum Suspension and HandlingReplies: 1Last Post: 04-03-2012, 08:38 PM -
Chassis Dyno Testing - How Bogus Is Your Local Chassis Dyno?
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-21-2011, 09:52 AM -
By Ed Blown Vert in forum Almost Anything GoesReplies: 1Last Post: 01-22-2011, 01:12 PM -
Braided lines
By SStriker in forum Automatic TransmissionReplies: 2Last Post: 05-17-2008, 05:00 AM -
Braided Hydraulic line
By FunkyTownFBody in forum Manual TransmissionReplies: 0Last Post: 11-14-2005, 06:36 PM
