Results 21 to 40 of 42
  1. #21
    15sec stalled A4 TransAmy's Avatar
    Lake in the Hills
    Shhh! There's a
    hooker in the trunk
    They fit. You need to make some cuts and adjustments. Check out Brent Frankers website.
    well you learn something new everyday i guess..
  2. #22
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    Do you have T/A door panels on your Camaro?
    Nope no T/A door panels on the Maro..
  3. #23
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by WARP211 View Post
    Then you have nothing to worry about as this is not a problem w/ the Camaro door panels.
  4. #24
    doylestown, Pa
    SILVER
    2004 CTS-V
    i did this mod on sunday. it was long and a bitch. i took out all the staples and put in 6 screws on each side(pass and driver). 1 in each "section" of plastic. it is awesome..the door doesnt bulge anymore when i role my windows down. i suggest everyone do it.
    It does not bulge anymore? Hmm, I thought it would be the opening and shutting of the door that caused them to break.
    But from what you are saying, it sounds like it is from the window going up and down?
  5. #25
    Feb 2007
    FairField, CA
    Right on man for the info..
  6. #26
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    +1, if yours haven't cracked yet, you can save the headache of them actually breaking.
    I got a new dremel for christmas and it made the job so much easier. I just cut the staples out. It probably would've taken all day if I had to pull em out.
    it does
  7. #27
    I cleaned this up some and I'll sticky it until the link goes dead.
  8. #28
    Shepherd, Michigan
    98' trans am
    thanks bud.
  9. #29
    doylestown, Pa
    SILVER
    2004 CTS-V
    I have a concern when doing this mod.
    The screw protrudes through the back of the panel where it lips over the door. After the extra threads of the screw are cut off, all that is left is the nut on the back side. How does this not effect the fitment of the door panel?
  10. #30
    Shepherd, Michigan
    98' trans am
    it doesnt..the top of the screw is on the top side. i did it with 4-40 machine screws 1/2 and everything worked fine.
  11. #31
    Shepherd, Michigan
    98' trans am
    you want to use 1/2
  12. #32
    doylestown, Pa
    SILVER
    2004 CTS-V
    you want to use 1/2
    1/2 what?
  13. #33
    Shepherd, Michigan
    98' trans am
    1/2 what?
    1/2 in length
  14. #34
    Feb 2008
    gresham oregon
    2002 firebird
    thanks guys I just got my car and dont have the issue ((yet )) so I did not even know it was a issue I will take care of this one soon !
  15. #35
    BLKHWK Durango's Avatar
    New Brunswick Canada
    BLK TA modded 12.2@113mph
    Thanks a lot man I just did my door as you suggested and when I removed the door I noticed that the door was already done but with rivets and it had a gap in the break. I did what you listed but duck taped the panel togheter then used plastic good and that glue actually is flexible when dried and now you can see a small line onle you have to know it's there. I hope that it holds...
  16. #36
    Allen, TX
    2001 Trans Am
    sounds good but seems like a lot of work, i don't wanna screw it up
  17. #37
    Shepherd, Michigan
    98' trans am
    ahh dont worry..i did mine awhile ago..and still no cracks...73k now on the car
  18. #38
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by patriot1136 View Post
    Pulling an engine and trans is alot of work! Pulling a door panel to prevent a crack is easy! DO IT! You don't want them to crack do you?
  19. #39
    Billings,MT
    Sunset Orange Metalic
    2002 Firehawk
    Doing the fix now.Just got new panels and do not want them to crack.The old ones have 3 inch cracks in them.Thanks for the great information!!
  20. #40
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    Quote Originally Posted by mghawk57 View Post
    Where did you find new panels, & what did they cost ya?
  1. Door Panel Crack Fixed!
    By atmrestyle in forum Appearance Section
    Last Post: 08-07-2013, 05:11 PM
  2. Door panel crack
    By johnfin in forum Firebird / WS6
    Last Post: 04-20-2013, 02:27 PM
  3. Ebony door panels,headlights,sail panels
    By VENOMOUS in forum Parts For Sale / Trade
    Last Post: 02-02-2009, 07:30 AM
  4. Firebird Door Panel Crack Repair - Door Panel Pandemic
    Last Post: 10-18-2007, 10:50 AM
  5. My Door Panel Crack Pic's
    By wnmech in forum Firebird / WS6
    Last Post: 02-27-2007, 09:25 AM
