Results 1 to 16 of 16
Thread: dtc p0174
    Member Pete Rock98's Avatar
    Bronx NY
    1998 z28
    dtc p0174
    My car is running horrible it has no power at all .The car is throwing dtc p0174. Need some imput
    Junior Member blatty86's Avatar
    baltimore,md/jville, nc
    2000 chevy camaro
    "system to lean right bank" (passenger side) check ur o2 and take a look at your header for any leaks.
    Bronx NY
    1998 z28
    ok thanks
    old timer blue02Z's Avatar
    2002 Z28
    also look for vacuum leaks around your intake manifold.
    2002 Z28
    btw that is bank 2 which is the passenger side if i am not mistaken
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    A bad O2 WILL NOT make your car run that bad. I would check for vacuum leaks first.
    Bronx NY
    1998 z28
    Quote Originally Posted by blue02Z View Post
    I checked the vacume lines they looked good.
    Bronx NY
    1998 z28
    Quote Originally Posted by Goldcuffs View Post
    The car has a bad hesitation and surge on acceleration
    I disagree....a bad O2 can make a car run like ass. With that said, I'd look for vacuum leaks first. The hesitation is most likely due to it being so lean. Check the back of your pcv line going into the intake, they like to crack back there although I would think it would lean out both banks. Is the idle funny at all or is it just hesitating?
    Bronx NY
    1998 z28
    At idle the car sounds like I have a misfire when I drive the car it's hesitating real bad...
    Orion you mean the line off of the brake booster
    Aug 2008
    Florida
    2000 Trans Am
    Please explain. I'm always willing to learn something new. I have never seen an 02 cause a severe drivability problem (except on an old Dodge) You could unplug all of you 02's and the car would run just fine. I'm not trying to argue but I would like to hear your input.
    there's a difference between an unplugged O2 and a fouled or mis-reporting O2. I've seen O2's responsible for sooting exhaust tips do to incorrect fueling. They can wreak havoc if they're reporting inaccurately. If you unplug them the car just stays in open loop.
    Aug 2008
    Florida
    2000 Trans Am
    Ok, I guess I can't argue with that, but I really don't think an 02 will make his car run as bad as he is saying. But..... just because I have never seen it doesn't mean it can't happen.
    Pete Rock 98- let us know what the problem was when you figure it out.
    I'm definitely not saying that it's an O2 issue. I would look for a vacuum leak first but the O2's can have a drastic effect on fueling. If it stays on bank 2 I would probably swap the front O2's from side to side and see if the code follows it before replacing an O2. I typically count O2's as a maintenance issue anyhow and replace mine periodically.
    Bronx NY
    1998 z28
    You were on point all of my intake manifold bolts were not tight.I snuged them up and started the car and I could tell right away that misfire was gone.Thanks all
    2002 Z28
  1. P0174 Code, only when hot out......
    By jfl330 in forum General Help
    Last Post: 06-17-2013, 04:00 PM
  2. More on the P0174 Code.....
    Last Post: 06-09-2012, 07:12 AM
  3. Help: P0174 Code (only, no other codes)
    Last Post: 06-03-2012, 10:23 AM
  4. P0171 and P0174
    By LSCyaL8R in forum General Help
    Last Post: 11-10-2010, 06:50 AM
  5. p0171 p0174
    By SandmanWs7 in forum General Help
    Last Post: 10-23-2007, 11:56 AM
