Thread: P0440
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    P0440
    showed up today on my buick,
    some kind of EVAP code, says something is up with my fuel pressure. My first thought was to pop the schrader valve to relieve it, but I haven't done it yet.
    Online it said something about an EVAP canister getting clogged?
    Just wondering what you guys thought about it
    Indianapolis
    2000 WS6 6spd Hooker LT
    Can't remember off the top of my head, but I believe the 440 code is a gross evap leak.
    First thing to check is your gas cap. If it's loose/off, it will set the gross leak code pretty quickly.
    check your cap and the lines to your evap canister.
    USA
    Velocity Yellow
    2008 Corvette Z06
    fuel vapor leak... check gas cap and vent valve.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    p0440 is the famous gas cap code. Could also be other things but usually loose gas cap. tighten it down and clear the code
    2000 SS Black M6
    ok cool, will do....and i have no idea where this evap canister is located, lol
    usually in the rear of the car somewhere near the tank. On the f-bodies it's behind the drivers side rear tire between the fill nozzle and tail light assembly.
    Get under there and follow the vacuum line coming out of the tank and it'll take you right to it.
    2000 SS Black M6
    sweet thanks, I would have been looking under the hood, lol
  1. Through code P0440
    By CamaroFan71 in forum General Help
    Last Post: 01-04-2009, 10:14 AM
  2. P0440 Code
    By joevee1446 in forum Computer & Tuning
    Last Post: 01-03-2007, 01:44 AM
  3. p0440 code
    By sierra in forum General Help
    Last Post: 09-13-2006, 05:34 PM
  4. P0440 help 01 Z28
    By Corvettejon in forum Computer & Tuning
    Last Post: 01-07-2006, 03:39 PM
  5. P0440???
    By shady1504 in forum Computer & Tuning
    Last Post: 11-18-2005, 09:25 AM
