yeah dude thats my other camaro i have two
Hi, could you please???
2G1FP32G2Y2166251
Thanks, I appreciate it....
Can you run my vin # 2G2FV22G522137345 please
Thanks in advance
Vehicle Information
VIN: 2G1FP32G2Y2166251 Model: -
Service Contract: No Branded Title: No Warranty Block: No PDI Status:
Order Type: N/A
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Vehicle has no current record of applicable warranties.
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
11/10/2004 268947 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 76,475 KM
No vehicle build.
Vehicle Information
VIN: 2G2FV22G522137345 Model: 2FV87-2002 PONTIAC FIREBIRD TRANS AM
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Branded Title
Warranty Block
Service Information
Valid Description Start Date Effective Odometer End Date End Odometer
Corrosion Limited Warranty 04/29/2002 50 MI 04/29/2008 100,050 MI
Bumper to Bumper Limited Warranty 04/29/2002 50 MI 04/29/2005 36,050 MI
Special Coverage 05513 04/29/2002 50 MI 04/29/2012 120,050 MI
Emission Select Component Ltd Wty 04/29/2002 50 MI 04/29/2010 80,050 MI
Service Contract
02/05/2004 220275 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 32,337 MI
10/06/2003 216669 ZREG----Regular Vehicle Transaction J6380 - Sensor, Oxygen (Catalyst Monitoring) - Replace 26,821 MI
10/06/2003 216669 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 26,821 MI
07/31/2003 214591 ZREG----Regular Vehicle Transaction J6372 - Sensor, Oxygen (Engine Control) - Replace 22,431 MI
03/17/2003 210170 ZREG----Regular Vehicle Transaction J6372 - Sensor, Oxygen (Engine Control) - Replace 14,024 MI
11/11/2002 206715 ZREG----Regular Vehicle Transaction E0437 - Firestone Tire Replacement 9,831 MI
10/14/2002 205851 ZREG----Regular Vehicle Transaction H0127 - Front Brake Rotor Replacement - Both Sides 8,347 MI
10/14/2002 205851 ZREG----Regular Vehicle Transaction E0201 - Tire and Wheel Balancing - Two 8,347 MI
02/06/2002 A37345 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Vehicle Build
Model: 2FV87-2002 PONTIAC FIREBIRD TRANS AM Order Number: DWQJ9V
Gross Vehicle Weight: 1,939 Build Date: 02/06/2002
Build Plant: 2-
Option Codes
*GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
192 - TRIM, EBONY 19I - INT TRIM, EBONY
1SA - OPTION GROUP - 1SA 41U - BLACK
6BT - COMPONENT FRT LH COMPUT SEL SUS 7BT - COMPONENT FRT RH COMPUT SEL SUS
8TJ - COMPONENT RR LH COMPUT SEL SUSP 9TJ - COMPONENT RR RH COMPUT SEL SUSP
AAA - STANDARD EQUIPMENT PROCESSING OPTION AG1 - 6-WAY POWER DRIVER SEAT
AK5 - DUAL FRONTAL AIR BAGS AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY C60 - AIR CONDITIONING, CUSTOM
CAE - HANDLING CHG-ST. THERESE TO TO SLP LASALLE QUEBEC CC1 - LOCKING HATCH ROOF, REMOVABLE
DE4 - HATCH ROOF SUNSHADES, REMOVABLE DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE FE2 - SUSPENSION SYSTEM, HANDLING
FE9 - 50-STATE LOW EMISSION VEHICLE G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
GU5 - REAR PERFORM AXLE, 3.23 RATIO IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE M30 - AUTOMATIC TRANSMISSION
MX0 - TRANSMISSION, 4-SPEED AUTOMATIC NF7 - FEDERAL LOW EMISSION
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT KNOB NW9 - TRACTION CONTROL
PA6 - PAINTED STYLED WHEEL PDC - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY
PDN - POWER PACKAGE QLC - TIRES, P245/50ZR16 PERFORMANCE
SLM - SALES STOCK ORDERS STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID T78 - HEADLAMP CONTROL DELETE
U75 - POWER ANTENNA UA6 - THEFT DETERRENT SYSTEM
UB3 - RALLY GAGES W/TACHOMETER UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS
V12 - POWER STEERING COOLING SYSTEM V73 - VEHICLE CERTIFICATION U.S.
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
WS9 - FORMULA OPTION WU6 - FORMULA FIREHAWK PACKAGE
Y82 - TRANS AM OPTION
Thanks man....
Thank you for doing this! I just picked up this 2001 Camaro SS Vert. Do you mind running the number for me? Thanks again!
2G1FP32G312101222
Vehicle Information
VIN: 2G1FP32G312101222 Model: 1FP67-2001 CAMARO CONVERTIBLE
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N000105 00105 RADIATOR CAP (MANUALLY CLOSED 6/28/02 - EXPIRED 12/31/01) 12/21/2000 Closed
Branded Title
Warranty Block
Service Information
Bumper to Bumper Limited Warranty 11/02/2000 36 MI 11/02/2003 36,036 MI
Corrosion Limited Warranty 11/02/2000 36 MI 11/02/2006 100,036 MI
Emission Select Component Ltd Wty 11/02/2000 36 MI 11/02/2008 80,036 MI
Special Coverage 05513 11/02/2000 36 MI 11/02/2010 120,036 MI
Service Contract
01/20/2004 027509 ZSCT----Service Contracts C0182 - Front Side Door Window Regulator Replacement - Right Side 41,602 MI
01/12/2004 222408 ZSCT----Service Contracts E7060 - Lever, Multifunction - Replace 41,520 MI
01/12/2004 222408 ZSCT----Service Contracts H2640 - Pedal And/Or Bushing, Brake - R&R Or Replace 41,520 MI
08/25/2003 200140 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 38,126 MI
02/10/2003 183567 ZREG----Regular Vehicle Transaction J6355 - Powertrain Control Module Transmission Reprogramming with SPS 32,497 MI
01/22/2003 182303 ZREG----Regular Vehicle Transaction F2383 - Ring Gear And Pinion - Rear Differential - Replace 32,007 MI
01/22/2003 182303 ZREG----Regular Vehicle Transaction Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 32,007 MI
06/03/2002 163773 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 19,341 MI
06/03/2002 163773 ZREG----Regular Vehicle Transaction F2023 - Seal, Pinion Shaft Oil - Rear Differential - Replace 19,341 MI
04/02/2001 132285 ZREG----Regular Vehicle Transaction Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 5,963 MI
04/02/2001 132285 ZREG----Regular Vehicle Transaction D4440 - Compressor Assembly - Replace 5,963 MI
04/02/2001 132285 ZREG----Regular Vehicle Transaction Z7906 - 6+ DAY COURTESY TRANSPORTATION 5,963 MI
04/02/2001 132285 ZREG----Regular Vehicle Transaction J1840 - Engine, Universal - Replace 5,963 MI
02/12/2001 128958 ZFAT----Field Action Recall V0632 - Radiator Cap 4,706 MI
01/15/2001 127221 ZREG----Regular Vehicle Transaction F1280 - Propeller Shaft Assembly - R&R Or Replace 2,163 MI
Vehicle Build
Model: 1FP67-2001 CAMARO CONVERTIBLE Order Number: CPMCJ4
Gross Vehicle Weight: 1,985 Build Date: 07/24/2000
Build Plant: 2-
Option Codes
192 - INT EBONY 19I - EBONY INTERIOR TRIM
1AY - STOCK ORDERS PROC OPTION 1SB - CAMARO CONVERTIBLE PREFERRED EQUIPMENT GROUP INCLUDES: * ELEC SPEED CONTROL W/RESUME * REMOTE HATCH RELEASE * FOG LAMPS * POWER DOOR LOCK SYSTEM * POWER WINDOWS * MIRROR TWIN REMOTE ELECTRIC * LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS * REMOTE KEYLESS ENTRY * THEFT DETERRENT ALARM SYSTEM * CARPETED REAR FLOOR MATS * BODYSIDE MOLDINGS * POWER DRIVER SEAT (6 WAY)
1SZ - PREFERRED EQUIPMENT SAVINGS 41Q - BLACK BODY SIDE MOLDING
41T - BLACK CONVERTIBLE TOP 41U - EXT ONYX BLACK
6ZM - FRONT SPRING 7ZM - FRONT SPRING
8TJ - REAR SPRING 9TJ - REAR SPRING
A31 - POWER WINDOWS W/ DRIVER'S SIDE EXPRESS DOWN AG1 - SIX-WAY POWER DRIVER SEAT
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS AR9 - BUCKET SEATS W/LEATHER TRIMMED SEATING SURFACES
AU0 - KEYLESS REMOTE ENTRY W/ ILLUMINATED INTERIOR FEATURE W/THEFT DETERRENT ALARM SYS AU3 - POWER DOOR LOCK SYSTEM WITH DELAYED ACCESSORY BUSS
B35 - COLOR-KEYED CARPETED FLOOR MATS B84 - BODY SIDE MOLDINGS
C60 - AIR CONDITIONING CAE - UPFITTER CONVERSION - Z28
DG7 - ELEC TWIN REMOTE SPORT MIRRORS DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE4 - RIDE & HANDLING SUSPENSION SYSTEM FE9 - 50-STATE LOW EMISSION VEHICLE
G80 - LIMITED SLIP DIFFERENTIAL GU5 - REAR AXLE 3.23 RATIO
IP2 - TRIM INTERIOR DESIGN - AR9 J65 - POWER DISC FRONT & REAR BRAKES
K34 - CRUISE CONTROL-AUTO K43 - GENERATOR 102 AMP
LS1 - ENG 5.7 LITER SFI V8 ENGINE M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
MX0 - 4-SPEED AUTOMATIC TRANSMISSION AUTOMATIC TRANS. W/OVERDRIVE N73 - CUSTOM SPORT WHEEL
NF7 - FEDERAL EMISSION SYSTEM NLEV NP5 - LEATHER WRAPPED STEERING WHEEL
NW9 - ACCELERATION SLIP REGULATION PBT - ID TEMPORARY HOOD, PROC OPTION
QFK - P275/40 ZR-17 S/B RADIAL B/W STE - ST THERESE, GM OF CANADA PLANT CODE
T82 - TWILIGHT SENTINEL HEADLAMPS T96 - FOG LAMPS
U59 - SPEAKER SYSTEM 8, QUADFRT DR U73 - FIXED MAST ANTENNA
UA6 - THEFT DETERRENT ALARM SYSTEM UB3 - GAGE PACKAGE WITH TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS UL0 - MONSOON 500 WATT (PEAK) PREMIUM SOUND SYSTEM ELECTRONICALLY TUNED AM/FM STEREO RADIO WITH SEEK-SCAN, DIGITAL CLOCK, AUTO-TONE CONTROL, CASSETTE PLAYER THEFTLOCK AND SPEED- COMPENSATED VOLUME
V12 - POWER STEERING COOLING SYSTEM V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VK3 - FRONT LICENSE PLATE MOUNT VM3 - CONSUMER INFORMATION LABEL
WU8 - "SS" PERFORMANCE/APPEARANCE PKG INCLUDES: *325 HORSEPOWER *FORCED AIR INDUCTION HOOD *17" ALUMINUM WHEELS *SS SPECIFIC REAR SPOILER *P275/40 ZR17 GOODYEAR F1 TIRES *HI PERF. RIDE & HANDLING SUSP. *LOW RESTRICTION DUAL OUTLET EXHAUST SYSTEM *POWER STEERING COOLER *SS BADGING Z28 - CAMARO Z28
Hey Andy....I can't find the VIN thread...can you run this one for me?
2g1fp22g4y2144696
Vehicle Information
VIN: 2G1FP22G4Y2144696 Model: -
Order Type: N/A
Branded Title
Warranty Block
Service Information
Service Contract
01/14/2008 076399 ZREG----Regular Vehicle Transaction A9221 - ROOF PANEL - REPAIR 52,760 MI
03/15/2002 044661 ZREG----Regular Vehicle Transaction Z7097 - BUYBACK DEALER ADMINISTRATIVE ALLOW OTHER THAN LEGAL 20,941 MI
01/23/2002 144405 ZREG----Regular Vehicle Transaction C3385 - Bezel, Front Door Inside Pull Handle - Left - Replace 25,667 MI
01/07/2002 143600 ZREG----Regular Vehicle Transaction C7051 - Cover And/Or Pad, Front Seat Back Cushion - Left - R&R Or Replace 25,581 MI
12/27/2001 143175 ZREG----Regular Vehicle Transaction N3315 - Front Side Door Window Regulator Motor Replacement - Left Side 25,244 MI
06/06/2001 133694 ZREG----Regular Vehicle Transaction Z7906 - 6+ DAY COURTESY TRANSPORTATION 20,941 MI
06/06/2001 133694 ZREG----Regular Vehicle Transaction K2720 - Transmission Replacement 20,941 MI
05/03/2001 132139 ZREG----Regular Vehicle Transaction K2752 - 3rd Gear Replacement 19,902 MI
05/03/2001 132139 ZREG----Regular Vehicle Transaction Z7906 - 6+ DAY COURTESY TRANSPORTATION 19,902 MI
No vehicle build
oh wow...so a new trans at 20k miles.....and a new roof at 50k?
i assume the new roof was to correct the bubbling problem?
I was really hopnig to have a vehicle build....I forgot to check RPOs when i test drove it, and was hoping to see "SS Package" on here...oh well
Hi Andy, I've been curious about my '01 TA. COuld you run the numbers for me also? Thank you//Bob.
2001 Pontiac Trans Am WS6
VIN: 2G2FV32G712145628
Production date: April 2001
Vehicle Information
VIN: 2G2FV32G712145628 Model: 2FV67-2001 FIREBIRD TRANS AM CONV
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: No
Branded Title
Warranty Block
Service Information
Bumper to Bumper Limited Warranty 10/03/2001 413 MI 10/03/2004 36,413 MI
Emission Limited Warranty 10/03/2001 413 MI 10/03/2004 50,413 MI
Emission Select State Component Lty Wty 10/03/2001 413 MI 10/03/2008 70,413 MI
Corrosion Limited Warranty 10/03/2001 413 MI 10/03/2007 100,413 MI
Special Coverage 05513 10/03/2001 413 MI 10/03/2011 120,413 MI
Emission Select Component Ltd Wty 10/03/2001 413 MI 10/03/2009 80,413 MI
Service Contract
Policy Number: 816309573 Owner: EDDY
Description: GMPP 36/36 MAJOR GUARD Deductible Amount: 200.00
Effective Date: 12/21/2006 Expiration Date: 12/21/2009
Effective Odometer: 53011 MI Expiration Odometer: 89011 MI
Daily Rental Limit: 35.00
06/30/2004 111617 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 39,212 MI
03/12/2004 107238 ZREG----Regular Vehicle Transaction R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 33,818 MI
03/11/2004 107238 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 33,818 MI
03/11/2004 107238 ZREG----Regular Vehicle Transaction C0167 - Front Side Door Window Module Replacement 33,818 MI
03/11/2004 107238 ZREG----Regular Vehicle Transaction R0763 - Receiver, Radio - Install 33,818 MI
03/11/2004 107238 ZREG----Regular Vehicle Transaction E7200 - Ignition Lock Cylinder Replacement 33,818 MI
10/20/2003 101339 ZREG----Regular Vehicle Transaction A1231 - Front Side Door Refinish/Clear Coat - Left Side 30,105 MI
08/28/2003 099203 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 28,988 MI
08/28/2003 099203 ZREG----Regular Vehicle Transaction Z7902 - 2-DAY COURTESY TRANSPORTATION 28,988 MI
07/17/2003 097374 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 27,726 MI
09/30/2002 085493 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 17,841 MI
09/30/2002 085493 ZREG----Regular Vehicle Transaction R0480 - Antenna Assembly, Power (Complete) - Replace 17,841 MI
09/30/2002 085493 ZREG----Regular Vehicle Transaction Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 17,841 MI
09/30/2002 085493 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 17,841 MI
08/08/2002 083327 ZREG----Regular Vehicle Transaction C0221 - Guide, Front Door Window - Left - R&R Or Replace 15,866 MI
08/08/2002 083327 ZREG----Regular Vehicle Transaction R0220 - Mast, Standard Antenna - Replace 15,866 MI
08/08/2002 083327 ZREG----Regular Vehicle Transaction E7060 - Lever, Multifunction - Replace 15,866 MI
08/08/2002 083327 ZREG----Regular Vehicle Transaction N6614 - Interior/Rear Compartment Lighting Wiring and/or Connector Repair or Replacement 15,866 MI
07/29/2002 082813 ZREG----Regular Vehicle Transaction K5220 - Lever, Shift Control (At Transmission) - Replace 15,377 MI
04/30/2001 057611 ZREG----Regular Vehicle Transaction B4350 - Knob, Front Door Inside Locking - Right - Replace 15 MI
04/10/2001 A45628 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Vehicle Build
Model: 2FV67-2001 FIREBIRD TRANS AM CONV Order Number: DFFRB6
Gross Vehicle Weight: 2,008 Build Date: 04/10/2001
Build Plant: 2-
Option Codes
1AY - ORDER MODIFICATION STOCK 1SA - OPTION GROUP - 1SA
41T - BLACK CONVERTIBLE TOP 41U - PAINT, BLACK
AAA - STANDARD EQUIPMENT PROCESSING OPTION AK5 - DUAL FRONTAL AIR BAGS
AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS C60 - AIR CONDITIONING, CUSTOM
CAF - HANDLING CHARGE-ST. THERESE TO AMERICAN SUNROOF DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE FE4 - RIDE & HANDLING SPECIAL SUSPENSION SYSTEM
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL GU5 - REAR PERFORM AXLE, 3.23 RATIO
IL2 - TRIM INTERIOR DESIGN J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR LS1 - 5.7 LITER SFI V8 ENGINE
M30 - AUTOMATIC TRANSMISSION MX0 - TRANSMISSION, 4-SPEED AUTOMATIC
NC1 - CALIFORNIA EMISSIONS LEV NC7 - FEDERAL EMISSIONS OVERRIDE
NG1 - 50-STATE LOW EMISSION VEHICLE NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT KNOB
NW9 - TRACTION CONTROL, ELECTRONIC PBT - TEMP. WHL & TIRE-UPFITTER DLVY
QB6 - 17" HIGH POLISHED ALUMINUM WHEELS QFK - TIRES, P275/40ZR17 SPEED RATED
R6J - CDN R6M - NEW JERSEY SURCHARGE
R7C - EXPEDITE PROCESSING OF ORDERS R7X - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY
R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA SLM - SALES STOCK ORDERS
STE - ASM PLT ST. THERESE T78 - HEADLAMP CONTROL DELETE
U1S - REMOTE COMPACT DISC CHANGER, TRUNK MOUNTED, 12 DISC CAPACITY U75 - POWER ANTENNA
V12 - POWER COOLING SYSTEM, STEERING V73 - VEHICLE CERTIFICATION U.S.
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER
WS9 - FORMULA OPTION X2O - RADIO, ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER INC. CLOCK, SEEK UP/DOWN, REMOTE CD PRE- WIRING, MONSOON 500 WATT PEAK POWER WITH 8 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
Y84 - TRANS AM OPTION
Hello, just bought a 2000 Camaro SS about 3 weeks ago. Would you mind giving me some info on it like the others you have done. I find this very interesting!!
Thank you so much!!
VIN 2G1FP22G5Y2164276
Vehicle Information
VIN: 2G1FP22G5Y2164276 Model: -
Order Type: N/A
Branded Title
Warranty Block
Service Information
Service Contract
06/25/2004 002741 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 17,190 MI
03/30/2001 A11094 ZREG----Regular Vehicle Transaction C3358 - Front Side Door Trim Panel Replacement - Left Side 8,289 MI
03/30/2001 A11094 ZREG----Regular Vehicle Transaction K2756 - Synchronizers - 3rd-4th - R&R Or Replace 8,289 MI
03/30/2001 A11217 ZREG----Regular Vehicle Transaction K2752 - 3rd Gear Replacement 8,289 MI
03/30/2001 A11094 ZREG----Regular Vehicle Transaction E9050 - Power Steering Pump Replacement 8,289 MI
No vehicle build
Can you look at mine? :) Thanks in advance! you rock!
2G1FP22G522153432
Bought a 35th LE on June 9, 2010. Can I get the LE#. VIN 2G1FP22G422122821.
Thanks in advance.
JEFF
Vehicle Information
VIN: 2G1FP22G522153432 Model: 1FP87-2002 CHEVROLET CAMARO Z-28
Branded Title
Warranty Block
Service Information
Bumper to Bumper Limited Warranty 07/15/2002 22 MI 07/15/2005 36,022 MI
Corrosion Limited Warranty 07/15/2002 22 MI 07/15/2008 100,022 MI
Emission Select Component Ltd Wty 07/15/2002 22 MI 07/15/2010 80,022 MI
Certified Used Limited Warranty 07/15/2002 22 MI 10/15/2005 39,022 MI
Special Coverage 05513 07/15/2002 22 MI 07/15/2012 120,022 MI
Service Contract
12/06/2004 060618 ZREG----Regular Vehicle Transaction D1440 - Instrument Panel Outer Air Outlet Replacement - Right Side 30,490 MI
12/06/2004 060618 ZREG----Regular Vehicle Transaction B5490 - Rear Compartment Lid Latch Striker Replacement 30,490 MI
12/02/2004 159321 ZREG----Regular Vehicle Transaction R0954 - Speaker, Radio - Rear Compartment Liftgate Or Door - Right - Replace 30,353 MI
09/02/2004 057180 ZREG----Regular Vehicle Transaction F2283 - Differential Drive Pinion Gear Bearing Replacement 28,118 MI
09/02/2004 057180 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 28,118 MI
09/02/2004 057180 ZREG----Regular Vehicle Transaction B5924 - Liftgate Window Latch Replacement 28,118 MI
09/02/2004 057180 ZREG----Regular Vehicle Transaction B3063 - Retainer, Side Rail Weatherstrip - Left - Replace 28,118 MI
08/04/2004 155048 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 27,299 MI
07/22/2004 154558 ZREG----Regular Vehicle Transaction R0820 - Amplifier, Radio - Replace 27,101 MI
07/14/2004 154269 ZREG----Regular Vehicle Transaction R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 26,208 MI
07/14/2004 154269 ZREG----Regular Vehicle Transaction C3128 - Headlining Trim Panel Replacement 27,008 MI
07/14/2004 154269 ZREG----Regular Vehicle Transaction R0760 - Radio, Remove and Replace 27,008 MI
07/14/2004 154269 ZREG----Regular Vehicle Transaction R0840 - Remote Compact Disc Player Replacement 27,008 MI
07/14/2004 154269 ZREG----Regular Vehicle Transaction C2770 - Front Floor Console Front Ashtray Replacement 27,008 MI
07/01/2004 153327 ZREG----Regular Vehicle Transaction R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 26,208 MI
02/07/2003 043597 ZREG----Regular Vehicle Transaction N1760 - Flasher - Turn Signal - Replace 10,076 MI
04/29/2002 A53432 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Vehicle Build
Model: 1FP87-2002 CHEVROLET CAMARO Z-28 Order Number: FBGFZN
Gross Vehicle Weight: 1,930 Build Date: 04/29/2002
Build Plant: 2-
Option Codes
1SD - PREFERRED EQUIPMENT GROUP INCLUDES: * ELEC SPEED CONTROL W/RESUME * REMOTE HATCH RELEASE * FOG LAMPS * POWER DOOR LOCK SYSTEM * POWER WINDOWS * MIRROR TWIN REMOTE ELECTRIC * LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS * REMOTE KEYLESS ENTRY * THEFT DETERRENT ALARM SYSTEM * BODYSIDE MOLDINGS * POWER DRIVER SEAT (6 WAY) 1SZ - PREFERRED EQUIPMENT SAVINGS
28Q - NAVY BLUE BODY SIDE MOLDING 28U - NAVY BLUE METALLIC
522 - NEUTRAL 52I - NEUTRAL INTERIOR TRIM
6BS - FRONT SPRING 7BS - FRONT SPRING
A31 - POWER WINDOWS W/ DRIVER'S SIDE EXPRESS DOWN A90 - POWER HATCH RELEASE
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AR9 - BUCKET SEATS W/LEATHER TRIMMED SEATING SURFACES AU0 - KEYLESS REMOTE ENTRY W/ ILLUMINATED INTERIOR FEATURE W/THEFT DETERRENT ALARM SYS
AU3 - POWER DOOR LOCK SYSTEM WITH DELAYED ACCESSORY BUSS B84 - BODY SIDE MOLDINGS
C49 - ELECTRIC REAR WINDOW DEFOGGER C60 - AIR CONDITIONING
CC1 - REMOVABLE ROOF PANELS W/LOCKS DE4 - REMOVABLE ROOF PANEL SUNSHADES
FE2 - RIDE & HANDLING SUSPENSION SYSTEM FE9 - 50-STATE LOW EMISSION VEHICLE
G80 - LIMITED SLIP DIFFERENTIAL GU2 - REAR AXLE 2.73 RATIO
K34 - CRUISE CONTROL-ELECTRONIC K43 - GENERATOR 102 AMP
MX0 - 4-SPEED AUTOMATIC TRANSMISSION N96 - 16" ALUMINUM WHEELS W/ LOCKS
NW9 - ACCELERATION SLIP REGULATION QFZ - P245/50 ZR-16 S/B RADIAL B/W TIRES
SLM - STOCK ORDERS STE - ST THERESE, GM OF CANADA PLANT CODE
U1S - REMOTE CD CHANGER W/12 DISC MAGAZINE U73 - FIXED MAST ANTENNA
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS UN0 - MONSOON 500 WATT (PEAK) PREMIUM SOUND SYSTEM ELECTRONICALLY TUNED AM/FM STEREO RADIO WITH SEEK-SCAN,DIGITAL CLOCK, AUTO- TONE CONTROL, CD PLAYER, THEFTLOCK, AND SPEED COMPENSATED VOLUME WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (INCLUDING UZ7)
UZ7 - MONSOON PREMIUM SOUND SYSTEM WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (BASE SYSTEM Z28 & UPLEVEL ON BASE COUPE) V12 - POWER STEERING COOLING SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA VK3 - FRONT LICENSE PLATE MOUNT
VM3 - CONSUMER INFORMATION LABEL Z28 - CAMARO Z28
Can you do mine plz.
00 ss m6
2G1FP22G4Y2161630
Thank you
