Originally Posted by
Firebirdjones
Yes, as well as it's cleaning purposes. Since lead was removed from gas in the early 70's, gasoline has lost it's lubricating properties. Gas also lubes things like valve seats, combustion chambers and cylinder walls as fuel can be washed down there, as well as some fuel being washed up passed the valves and affecting valve guides and seals. It will also lube the injectors and the fuel pump. So I find the lubrication properties more important to me than anything else.
The other benefit (if it has TCW3 on the label) are the cleaning properties, cleaning the fuel injectors, the combustion chambers, and should keep down carbon buildup if used regularly.
Since they have removed sulfer from the diesel fuels now, (gave diesel it's lubricating properties) I've started adding it to my diesel as well.
