Originally Posted by
konigandy6
vehicle information
vin: 2g2fv22g312115410 model: 2fv87-2001 pontiac firebird trans am
service contract: No branded title: No warranty block: No pdi status: No
order type: 70 - retail - stock
field actions: 0 open
required field actions open field actions are highlighted
type number original nbr description release date status
customer satisfaction program n000105 00105 radiator cap (manually closed 6/28/02 - expired 12/31/01) 12/21/2000 closed
branded title
*the vin information contained herein and information derived therefrom is the proprietary property of the polk company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty block
vehicle has no current record of warranty block.
Service information
vehicle has no current record of outstanding service information.
Onstar and xm satellite radio information
vehicle has no current record of onstar / xm radio information.
Applicable warranties valid warranties are highlighted
valid description start date effective odometer end date end odometer
bumper to bumper limited warranty 03/21/2001 163 mi 03/21/2004 36,163 mi
corrosion limited warranty 03/21/2001 163 mi 03/21/2007 100,163 mi
emission select component ltd wty 03/21/2001 163 mi 03/21/2009 80,163 mi
certified used limited warranty 03/21/2001 163 mi 06/21/2004 39,163 mi
special coverage 05513 03/21/2001 163 mi 03/21/2011 120,163 mi
service contract
vehicle has no current record of service contracts.
Transaction history view details
job card date job card number transaction type transaction adjustment labour operation odometer reading
04/28/2004 427386 zreg----regular vehicle transaction n6600 - brake system/traction control wiring and/or connector repair or replacement 32,887 mi
04/28/2004 427386 zreg----regular vehicle transaction c0182 - front side door window regulator replacement - right side 32,887 mi
12/12/2003 413181 zreg----regular vehicle transaction n3315 - front side door window regulator motor replacement - left side 28,802 mi
05/08/2003 388951 zreg----regular vehicle transaction d1322 - motor and/or fan, blower - r&r or replace 21,963 mi
vehicle build
model: 2fv87-2001 pontiac firebird trans am order number: Cqzp6j
gross vehicle weight: 1,934 build date: 09/20/2000
build plant: 2-
option codes
*gmvis is not the definitive source of gm vehicle rpo information and is intended for service reference only. Should there be any questions about the vehicle's original build or rpo information please refer to the original vehicle invoice or window sticker.
1ay - order modification stock 1sa - option group - 1sa
522 - trim, taupe 52i - trim, taupe
6zm - component frt lh comput sel sus 7zm - component frt rh comput sel sus
81u - paint, bright red 8tj - component rr lh comput sel susp
9tj - component rr rh comput sel susp a31 - power windows
aaa - standard equipment processing option ag1 - power seat, driver 6-way
ak5 - dual frontal air bags aq9 - custom bucket seats w/adjustable lumbar supports
au0 - remote keyless entry au3 - power door locks
c60 - air conditioning, custom caf - handling charge-st. Therese to american sunroof
cc1 - locking hatch roof, removable de4 - hatch roof sunshades, removable
dg7 - dual power sport mirrors dl5 - decal roadside service
fe4 - ride & handling special suspension system fe9 - 50-state low emission vehicle
g80 - limited slip torsen rear differential gu6 - 3.4 ratio rear axle
il2 - trim interior design j65 - brakes, pwr 4-whl,disc frt & rr
k43 - 102 amp generator ls1 - 5.7 liter sfi v8 engine
mm6 - transmission, 6-speed manual mn6 - transmission, 6-speed manual
nf7 - federal low emission np5 - steering wheel, leather wrapped w/leather wrapped shift knob
nw9 - traction control, electronic pbt - temp. Whl & tire-upfitter dlvy
qf6 - 5-spoke 17" high polished aluminum wheels qfk - tires, p275/40zr17 speed rated
r6j - cdn r7x - security package consists of: Theft deterrent system remote keyless entry
r9p - power package includes: Power door locks retained accessory power, power windows including express down driver's side dual power sport mirrors power antenna ste - asm plt st. Therese
t43 - spoiler, rear deck lid t78 - headlamp control delete
u75 - power antenna ua6 - theft deterrent system
ub3 - rally gages w/tachometer uk3 - leather wrapped steering wheel w/radio controls
v12 - power cooling system, steering v73 - vehicle certification u.s.
Vm3 - bumper std impact 5 mph frt &rr w55 - radio etr am/fm stereo w/compact disc player and graphic equalizer, incl. Clock, seek up/down, remote cd pre-wiring, monsoon 500 watt peak power w/10 speaker premium sound system and steering wheel, leather wrapped, w/radio controls
ws6 - ram air perform.& handling pkg: * ram air induction system * functional air scoops * 17" high polished aluminum wheels * p275/40zr17 speed rated tires * specific low restriction dual exhaust system * specific tuned suspension * power steering cooler ws9 - formula option
y82 - trans am option
