If it has tits or is mechanical, at some point it will be a PITA.
I've heard that too, but mechanical encompasses so much more. Like boats for instance......
180* out? #1 at TDC for sure? Get the rotor pointed just shy of #1 on the dist and drop it into place. When i first swapped the cam in my car the dist dropped right back into place perfectly, when I pulled the intake due to the coolant leak, it wouldn't line up again. Took a long piece of clean 1/2" flat stock steel, bent a 90* for a handle and dropped it down the dist. hole to turn just the oil pump drive so that the dist. would drop in.
Apparently ladybugs have the ability to write on walls and ceilings with their asses?! :wtf:
I have black tracks in two spots on our bedroom wall and ceiling. Hopefully, this shit cleans off and doesn't leave a telltale mark. Bastages.
