Originally Posted by
CaseyL67
It depends on how much power you want. If you are going to forge your engine which I recommend, you should do that first. All you need is forged pistons and rods. Don't worry about the crank as it can hold past 900hp.
After you figure that out you can put on a D1 or a turbo kit. Turbos you can get a boost controller and have it set to a low and high boost setting which you can change with the push of a button. But both can yeild good hp gains.
If it were me, I would forge the engine and get the sts kit with some tips made up and run a 15psi setting and a 8psi setting for street driving. But remember when you get into big horsepower you will need more things such as a clutch, drag radials, bigger fuel system, rear end if you are drag racing etc.. And things break a lot faster with more horsepower!
