If you want a carfax, I suggest you pay the $24 and get one. This is not what we do here. Please read the thread before posting again.
If you have time. Thanks:usa: 2G1FP22G622160065
VIN : 2G1FP22G622160065
VEHICLE INFORMATION
Merchandising Model : 1FP87 -2002 CAMARO Z28 2-DOOR COUPE Warranty Start Date : 07/16/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : BOBBY MURRAY CHEVROLET, INC.
PO BOX 40639
RALEIGH , NC 27629-0639
(919) 834-6441
Selling Source : 13 - CHEVROLET
Site Code : 16780
Business Associate Code : 114092
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 07/16/2002 215 miles 07/16/2005 36215 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/16/2002 215 miles 07/16/2008 100215 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/16/2002 215 miles 07/16/2010 80215 miles
36/36000 FEDERAL EMISSION 07/16/2002 215 miles 07/16/2005 36215 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/28/2006 010068 # A9221 - ROOF PANEL - REPAIR 31125 miles
08/15/2005 100259 # H2810 - GRIP AND/OR BUTTON, PARKING BRAKE HANDLE - REPLACE 17871 miles
08/05/2005 099960 # D1441 - DEFLECTOR, AIR (OUTLET VENT) - LEFT - REPLACE 17815 miles
08/01/2005 099702 # C6011 - ADJUSTER ASSEMBLY, FRONT SEAT MANUAL - BUCKET SEAT - DRIVE 17779 miles
07/19/2005 099247 # C2540 - PANEL/PAD ASSEMBLY, INSTRUMENT PANEL - REPLACE 17721 miles
07/19/2005 099247 # Z7901 - 1-DAY COURTESY TRANSPORTATION 17721 miles
06/13/2005 097944 # C2540 - PANEL/PAD ASSEMBLY, INSTRUMENT PANEL - REPLACE 17291 miles
04/05/2005 095773 # J1000 - PAN AND/OR GASKET, OIL - REPLACE 16953 miles
04/05/2005 095773 # K2160 - SEAL, TRANSMISSION EXTENSION REAR OIL - REPLACE 16953 miles
04/05/2005 095773 # J1120 - SEAL, CRANKSHAFT REAR MAIN - REPLACE 16953 miles
04/05/2005 095773 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 16953 miles
04/05/2005 095773 # Z7903 - 3-DAY COURTESY TRANSPORTATION 16953 miles
08/17/2004 087523 # D1442 - DEFLECTOR, AIR (OUTLET VENT) - RIGHT CENTER - REPLACE 14681 miles
08/03/2004 087136 # D1443 - DEFLECTOR, AIR (OUTLET VENT) - LEFT CENTER - REPLACE 14601 miles
05/24/2004 084573 # N6606 - WIRING AND/OR CONNECTOR - FUEL SYSTEM - REPAIR OR REPLACE 14507 miles
05/24/2004 084573 # J5542 - IDLE AIR CONTROL VALVE REPLACEMENT 14507 miles
03/01/2004 082033 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 14256 miles
03/01/2004 082033 # T2020 - TOWING 14256 miles
03/01/2004 082033 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 14256 miles
01/30/2004 081132 # B7010 - EMBLEM AND/OR NAMEPLATE - ONE - REPLACE 13290 miles
01/22/2004 080925 # B7010 - EMBLEM AND/OR NAMEPLATE - ONE - REPLACE 13247 miles
01/22/2004 080925 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 13247 miles
12/11/2003 079635 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 12879 miles
11/24/2003 079103 # J0627 - LIFTER, VALVE - BOTH BANKS - REPLACE 12759 miles
11/24/2003 079103 # Z7903 - 3-DAY COURTESY TRANSPORTATION 12759 miles
11/14/2003 078836 # C4208 - FLOOR PANEL CARPET REPLACEMENT 12759 miles
11/14/2003 078836 # J1060 - OIL PUMP SUCTION PIPE AND SCREEN ASSEMBLY REPLACEMENT 12759 miles
11/14/2003 078836 # Z7902 - 2-DAY COURTESY TRANSPORTATION 12759 miles
01/27/2003 319605 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH 8681 miles
01/27/2003 319605 # B1783 - WINDSHIELD WIPER BLADE REPLACEMENT 8681 miles
09/16/2002 311536 # C1561 - RETAINER, WEATHERSTRIP - HATCH ROOF - LEFT - ALIGN OR REPL 3257 miles
08/23/2002 310157 # R0955 - SPEAKER, RADIO - REAR COMPARTMENT LIFTGATE OR DOOR - LEFT 2139 miles
05/31/2002 A60065 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 2G1FP22G622160065
VEHICLE BUILD
Gross Vehicle Weight Rating : 1900 kg (4190 lb) Order Number : FHBDB5
Build Date : 05/31/2002 Build Plant : 222F
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS AR9 - BUCKET SEATS W/LEATHER TRIMMED SEATING SURFACES
BBS - HURST SHORT THROW SHIFTER CC1 - REMOVABLE ROOF PANELS W/LOCKS
C49 - ELECTRIC REAR WINDOW DEFOGGER C60 - AIR CONDITIONING
DE4 - REMOVABLE ROOF PANEL SUNSHADES DL5 - ROADSIDE SERVICE INFORMATION DECAL
D35 - LH REM, RH MAN SPORT MIRRORS FE2 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE GU6 - 3.42 RATIO REAR AXLE
G80 - LIMITED SLIP DIFFERENTIAL IPB - INTERIOR TRIM DESIGN
J65 - POWER DISC FRONT & REAR BRAKES K43 - GENERATOR 102 AMP
LS1 - ENG 5.7 LITER SFI V8 ENGINE MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF7 - FEDERAL EMISSION SYSTEM NLEV
NK3 - SPORT STEERING WHEEL PW7 - 16" CHROME CAST ALUMINUM
QLC - P245/50 ZR-16 S/B RADIAL B/W TIRES SLM - STOCK ORDERS
STE - ST THERESE, GM OF CANADA PLANT CODE T82 - TWILIGHT SENTINEL HEADLAMPS
UB3 - GAGE PACKAGE WITH TACHOMETER UN0 - MONSOON 500 WATT (PEAK) PREMIUM SOUND SYSTEM ELECTRONICALLY TUNED AM/FM STEREO RADIO WITH SEEK-SCAN,DIGITAL CLOCK, AUTO- TONE CONTROL, CD PLAYER, THEFTLOCK, AND SPEED COMPENSATED VOLUME WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (INCLUDING UZ7)
UZ7 - MONSOON PREMIUM SOUND SYSTEM WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (BASE SYSTEM Z28 & UPLEVEL ON BASE COUPE) U73 - FIXED MAST ANTENNA
VM3 - CONSUMER INFORMATION LABEL V12 - POWER STEERING COOLING SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA Z28 - CAMARO Z28
1SC - Z28 BASE VEHICLE 1SZ - PREFERRED EQUIPMENT SAVINGS
19B - INT EBONY CLOTH 19I - EBONY INTERIOR TRIM
6BS - FRONT SPRING 7BS - FRONT SPRING
8TJ - REAR SPRING 81U - BRIGHT RALLY RED
9TJ - REAR SPRING
To Cool. Thank you very much.:usa:
One more for my sons Z28? Thanks again:usa: 2G1FP22G522118776
VIN : 2G1FP22G522118776
VEHICLE INFORMATION
Merchandising Model : 1FP87 -2002 CAMARO Z28 2-DOOR COUPE Warranty Start Date : 11/10/2001
Delivering Dealer : REED-LALLIER CHEVROLET
PO BOX 40637
FAYETTEVILLE , NC 28309-0637
(910) 426-2000
Site Code : 16468
Business Associate Code : 114026
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 11/10/2001 43 miles 11/10/2004 36043 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/10/2001 43 miles 11/10/2007 100043 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/10/2001 43 miles 11/10/2009 80043 miles
36/36000 FEDERAL EMISSION 11/10/2001 43 miles 11/10/2004 36043 miles
CLAIM HISTORY
10/03/2006 010168 # A9221 - ROOF PANEL - REPAIR 28467 miles
07/12/2002 797678 # Z8015 - ROADSIDE SERVICE (FLAT TIRE) 3010 miles
09/25/2001 A18776 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 2G1FP22G522118776
VEHICLE BUILD
Gross Vehicle Weight Rating : 1929 kg (4253 lb) Order Number : DPTHRM
Build Date : 09/25/2001 Build Plant : 222F
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AR9 - BUCKET SEATS W/LEATHER TRIMMED SEATING SURFACES AU0 - KEYLESS REMOTE ENTRY W/ ILLUMINATED INTERIOR FEATURE W/THEFT DETERRENT ALARM SYS
AU3 - POWER DOOR LOCK SYSTEM WITH DELAYED ACCESSORY BUSS A31 - POWER WINDOWS W/ DRIVER'S SIDE EXPRESS DOWN
A90 - POWER HATCH RELEASE B84 - BODY SIDE MOLDINGS
CC1 - REMOVABLE ROOF PANELS W/LOCKS C49 - ELECTRIC REAR WINDOW DEFOGGER
C60 - AIR CONDITIONING DE4 - REMOVABLE ROOF PANEL SUNSHADES
DG7 - ELEC TWIN REMOTE SPORT MIRRORS DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE2 - RIDE & HANDLING SUSPENSION SYSTEM FE9 - 50-STATE LOW EMISSION VEHICLE
GU2 - REAR AXLE 2.73 RATIO G80 - LIMITED SLIP DIFFERENTIAL
IP2 - TRIM INTERIOR DESIGN - AR9 J65 - POWER DISC FRONT & REAR BRAKES
K34 - CRUISE CONTROL-ELECTRONIC K43 - GENERATOR 102 AMP
LS1 - ENG 5.7 LITER SFI V8 ENGINE MX0 - 4-SPEED AUTOMATIC TRANSMISSION
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NP5 - LEATHER WRAPPED STEERING WHEEL NW9 - ACCELERATION SLIP REGULATION
PW7 - 16" CHROME CAST ALUMINUM QFZ - P245/50 ZR-16 S/B RADIAL B/W TIRES
SLM - STOCK ORDERS STE - ST THERESE, GM OF CANADA PLANT CODE
T82 - TWILIGHT SENTINEL HEADLAMPS T96 - FOG LAMPS
UA6 - THEFT DETERRENT ALARM SYSTEM UB3 - GAGE PACKAGE WITH TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS UN0 - MONSOON 500 WATT (PEAK) PREMIUM SOUND SYSTEM ELECTRONICALLY TUNED AM/FM STEREO RADIO WITH SEEK-SCAN,DIGITAL CLOCK, AUTO- TONE CONTROL, CD PLAYER, THEFTLOCK, AND SPEED COMPENSATED VOLUME WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (INCLUDING UZ7)
1SD - PREFERRED EQUIPMENT GROUP INCLUDES: * ELEC SPEED CONTROL W/RESUME * REMOTE HATCH RELEASE * FOG LAMPS * POWER DOOR LOCK SYSTEM * POWER WINDOWS * MIRROR TWIN REMOTE ELECTRIC * LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS * REMOTE KEYLESS ENTRY * THEFT DETERRENT ALARM SYSTEM * BODYSIDE MOLDINGS * POWER DRIVER SEAT (6 WAY) 1SZ - PREFERRED EQUIPMENT SAVINGS
19I - EBONY INTERIOR TRIM 192 - INT EBONY
8TJ - REAR SPRING 81Q - BRIGHT RED BODY SIDE MOLDING
81U - BRIGHT RALLY RED 9TJ - REAR SPRING
First off you guys rock for doing this and with that said here's mine
2g2fv22g322140700
mine to please 2g2fv22g812127083:D
VIN : 2G2FV22G322140700
VEHICLE INFORMATION
Merchandising Model : 2FV87 -2002 FIREBIRD TRANS AM Warranty Start Date : 03/23/2002
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : ROSELAND AUTO SALES COMPANY
10954 S MICHIGAN AVE
CHICAGO , IL 60628-3529
(773) 785-6070
Selling Source : 16 - PONTIAC
Site Code : 10435
Business Associate Code : 116080
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/23/2002 18 miles 03/23/2005 36018 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/23/2002 18 miles 03/23/2008 100018 miles
3/3000 GM CERTIFIED USED LIMITED WARRANTY 10/08/2007 30211 miles 01/08/2008 33211 miles
60/100000 GM CERTIFIED USED POWERTRAIN LIMITED WARRANTY 03/23/2002 18 miles 03/23/2007 100018 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/23/2002 18 miles 03/23/2010 80018 miles
36/36000 FEDERAL EMISSION 03/23/2002 18 miles 03/23/2005 36018 miles
CLAIM HISTORY
10/04/2004 013562 # C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 18879 miles
10/04/2004 013562 # N3860 - WINDSHIELD WASHER PUMP REPLACEMENT 18879 miles
10/04/2004 013562 # Z7902 - 2-DAY COURTESY TRANSPORTATION 18879 miles
06/09/2003 012709 # E8061 - TIE ROD END AND/OR ADJUSTER SLEEVE - LEFT - REPLACE 10544 miles
02/12/2003 012453 # H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 8041 miles
02/22/2002 A40700 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 2G2FV22G322140700
VEHICLE BUILD
Gross Vehicle Weight Rating : 1939 kg (4275 lb) Order Number : DZHJ6F
Build Date : 02/22/2002 Build Plant : 222F
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION AG1 - 6-WAY POWER DRIVER SEAT
AK5 - DUAL FRONTAL AIR BAGS AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY CAE - HANDLING CHG-ST. THERESE TO TO SLP LASALLE QUEBEC
CC1 - LOCKING HATCH ROOF, REMOVABLE C60 - AIR CONDITIONING, CUSTOM
DE4 - HATCH ROOF SUNSHADES, REMOVABLE DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE FE2 - SUSPENSION SYSTEM, HANDLING
FE9 - 50-STATE LOW EMISSION VEHICLE GU5 - REAR PERFORM AXLE, 3.23 RATIO
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE MX0 - TRANSMISSION, 4-SPEED AUTOMATIC
M30 - AUTOMATIC TRANSMISSION NF7 - FEDERAL LOW EMISSION
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT KNOB NW9 - TRACTION CONTROL
PA6 - PAINTED STYLED WHEEL PDC - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY
PDN - POWER PACKAGE QLC - TIRES, P245/50ZR16 PERFORMANCE
R6J - CDN R9Z - POMS EXPEDITE
SLL - SALES SOLD ORDERS STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID T78 - HEADLAMP CONTROL DELETE
UA6 - THEFT DETERRENT SYSTEM UB3 - RALLY GAGES W/TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS U75 - POWER ANTENNA
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR V12 - POWER STEERING COOLING SYSTEM
V73 - VEHICLE CERTIFICATION U.S. WS9 - FORMULA OPTION
WU6 - FORMULA FIREHAWK PACKAGE W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
Y82 - TRANS AM OPTION 1SA - OPTION GROUP - 1SA
11U - PEWTER METALLIC 19I - INT TRIM, EBONY
192 - TRIM, EBONY 6BT - COMPONENT FRT LH COMPUT SEL SUS
7BT - COMPONENT FRT RH COMPUT SEL SUS 8TJ - COMPONENT RR LH COMPUT SEL SUSP
9TJ - COMPONENT RR RH COMPUT SEL SUSP
VIN : 2G2FV22G812127083
VEHICLE INFORMATION
Merchandising Model : 2FV87 -2001 FIREBIRD TRANS AM Warranty Start Date : 02/17/2001
Delivering Dealer : COURTESY PONTIAC
7100 W. SAHARA
LAS VEGAS , NV 89117-2835
(702) 256-7100
Site Code : 24113
Business Associate Code : 130564
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/17/2001 41 miles 02/17/2004 36041 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/17/2001 41 miles 02/17/2007 100041 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/17/2001 41 miles 02/17/2009 80041 miles
36/36000 FEDERAL EMISSION 02/17/2001 41 miles 02/17/2004 36041 miles
CLAIM HISTORY
09/24/2007 202322 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 70796 miles
03/25/2002 053308 # H2840 - CONTROL ASSEMBLY, PARKING BRAKE - REPLACE 23923 miles
03/25/2002 053308 # R0951 - RADIO REAR SIDE DOOR SPEAKER REPLACEMENT - LEFT SIDE 23923 miles
03/14/2002 052717 # L1260 - FUEL TANK REPLACEMENT 23525 miles
03/14/2002 052717 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH 23525 miles
08/27/2001 198820 # K0060 - PEDAL, SHAFT AND/OR BUSHING, CLUTCH - REPLACE 12278 miles
04/05/2001 186688 # N6610 - WIRING AND/OR CONNECTOR - ENGINE WIRING - REPAIR OR REPLAC 3381 miles
04/05/2001 877880 # T2020 - TOWING 3000 miles
11/15/2000 A27083 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 2G2FV22G812127083
VEHICLE BUILD
Gross Vehicle Weight Rating : 1941 kg (4280 lb) Order Number : CWNZD0
Build Date : 11/15/2000 Build Plant : 212F - STE THERESE ASSEMBLY GM-CANADA
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION AG1 - POWER SEAT, DRIVER 6-WAY
AU0 - REMOTE KEYLESS ENTRY AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS BBS - HURST SHIFTER
CAF - HANDLING CHARGE-ST. THERESE TO AMERICAN SUNROOF CC1 - LOCKING HATCH ROOF, REMOVABLE
C60 - AIR CONDITIONING, CUSTOM DE4 - HATCH ROOF SUNSHADES, REMOVABLE
DG7 - DUAL POWER SPORT MIRRORS DL5 - DECAL ROADSIDE SERVICE
FE4 - RIDE & HANDLING SPECIAL SUSPENSION SYSTEM FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - 3.4 RATIO REAR AXLE G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
IL2 - TRIM INTERIOR DESIGN J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR LS1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL MN6 - TRANSMISSION, 6-SPEED MANUAL
NF7 - FEDERAL LOW EMISSION NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT KNOB
PBT - TEMP. WHL & TIRE-UPFITTER DLVY QB6 - 17" HIGH POLISHED ALUMINUM WHEELS
QFK - TIRES, P275/40ZR17 SPEED RATED R6J - CDN
R7X - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA
SLM - SALES STOCK ORDERS STE - ASM PLT ST. THERESE
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR V12 - POWER COOLING SYSTEM, STEERING
V73 - VEHICLE CERTIFICATION U.S. WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER
WS9 - FORMULA OPTION W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
19I - INT TRIM, EBONY 192 - TRIM, EBONY
41U - PAINT, BLACK 6ZM - COMPONENT FRT LH COMPUT SEL SUS
7ZM - COMPONENT FRT RH COMPUT SEL SUS 8TJ - COMPONENT RR LH COMPUT SEL SUSP
Can you do mine too please.
2G1FP22G7Y2132963
VIN : 2G1FP22G7Y2132963
VEHICLE INFORMATION
Merchandising Model : 1FP87 -2000 CAMARO Z28 2-DOOR COUPE Warranty Start Date : 04/06/2000
Delivering Dealer : TOM BENSON CHEVROLET COMPANY, INC.
PO BOX 790285
SAN ANTONIO , TX 78279-0285
(210) 341-3311
Site Code : 30045
Business Associate Code : 114860
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/06/2000 170 miles 04/06/2003 36170 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/06/2000 170 miles 04/06/2006 100170 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/06/2000 170 miles 04/06/2008 80170 miles
36/36000 FEDERAL EMISSION 04/06/2000 170 miles 04/06/2003 36170 miles
CLAIM HISTORY
08/01/2001 048301 B E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 45000 miles
04/09/2001 096666 # N0126 - BATTERY NEGATIVE CABLE REPLACEMENT 32440 miles
04/09/2001 096666 # N6612 - WIRING AND/OR CONNECTOR - EXTERIOR LIGHTING - REPAIR OR RE 32440 miles
03/21/2001 095223 # L1200 - FUEL TANK FUEL PUMP MODULE REPLACEMENT 30163 miles
12/06/1999 232963 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 2G1FP22G7Y2132963
VEHICLE BUILD
Gross Vehicle Weight Rating : 1914 kg (4220 lb) Order Number : BZXNHR
Build Date : 12/06/1999 Build Plant : 2Y2F - STE THERESE ASSEMBLY GM-CANADA
OPTION CODES
AR9 AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM A31 - POWER WINDOWS
A90 - POWER TRUNK OPENER B35 - COLOR-KEYED CARPETED FLOOR MATS
B84 - BODY SIDE MOLDINGS CC1 - REMOVABLE ROOF PANELS W/LOCKS
DE4 DG7 - ELEC TWIN REMOTE SPORT MIRRORS
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE2
FE9 - FEDERAL EMISSIONS GU2 - REAR AXLE 2.73 RATIO
G80 - LOCKING DIFFERENTIAL-REAR AXLE IPB - INTERIOR TRIM DESIGN - AR9
J65 - POWER DISC FRONT & REAR BRAKES K34 - CRUISE CONTROL-AUTO
K43 - GENERATOR 102 AMP LS1
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF2 - FEDERAL EMISSION SYSTEM NP5 - LEATHER WRAPPED STEERING WHEEL
NW9 N96
QFZ STE - ST THERESE, GM OF CANADA PLANT CODE
UK3 UL0 - AM/FM STEREO CASSETTE RADIO
UZ7 U73 - FIXED MAST ANTENNA
VK3 - FRONT LICENSE PLATE MOUNT VM3 - CONSUMER INFORMATION LABEL
1SD - OPTION PACKAGE 04 1SZ - PREFERRED EQUIPMENT SAVINGS
19B - INT EBONY CLOTH 19I - INT EBONY INTERIOR TRIM
41Q - BLACK BODY SIDE MOLDINGS 41U - BLACK
6ZL - FRONT SPRING 7ZL - FRONT SPRING
8TJ - REAR SPRING 9TJ - REAR SPRING
Thanks alot.
It shows its a Z28, but the car is an SS. Is this right?
thanks koni its really cool that you can do this, i wish i would've seen this thread before i bought the t/a i probably woulda went with a different one. after my car got sold in 01' it pretty much never made it back to the dealership for service, :wtf: does that claim history show all maintiance(sp?) or just stuff that got done at the dealership?
