Originally Posted by
Whamhammer
The guy at Spohn actually said to use an impact! He said from the pictures, (summary):
to check the mounting bolts on the rears of the lower arms, the k-frame mounting boxes because some people think they are tight but the box isn't sucked tight against the rod spacers. "Use an impact wrench there."
The noise is on both sides of the car now, and it even makes a popping noise when I pull open the door, get in or out, etc.
I would have put it up myself but my shoulder has been hurting for the last month or so (tendinitis), that's why I've been looking for a shop. I still have the snow tires on.
I'll drive by Mr Tire and talk to them, and see if they will work with it.
My big concern is telling the difference between just needing to be tightened, and needing to be replaced, I guess if it needs to be replaced, tightening the ends won't help.
