Originally Posted by
az gt eater
Rear end, windows, power steering cooler, door panel cracks, steering column, clutch master, antenna, front turn signals, headlight motors, rear quarter flex from no subframe connectors, no sound insluation, water in the knock sensors, PCV blowby... There is quite a list of things that GM screwed up on with the F-Body. Sail panel bubbling. The longer you think about it, the more you come up with. Making the Camaro look like a catfish. Making the Camaro at all..............
