If this helps the original poster at all, I didn't have to get to fancy on the carb tuning to make it happy.
A 4779 750 holley. I drilled the idle feed restrictors to .033 for a little more adjustability. I can make the cam idle down to 600 if I want to which is pretty good with a 107 LSA. I would have to play more with the idle circuit if this were an auto car more than likely.
I had to play with the squirter circuit going to a .035 squirter with a pink cam set in the #2 hole.
Got the idle AFR at about 13.8 to 14.0, sometimes fluctuating a tad leaner at 14.2 or 3. Could probably go leaner but it makes the car more tempermental on cold starts and even luke warm starts. I am currently running 16 initial timing and 34 degrees total. The motor liked 36 on the dyno and I may bump it to that with more driving. Experimenting with 91 octane right now with no complaints.
This cam is a bit more radical than the fuel injection version they make for the LS motors. But I'm sure a savy tuner can make it idle and work if this is really what you are looking for. Vacuum sucks as you would expect on a 107 LSA. Once warm I get a rock steady 8 inches at an idle of about 8-900. It wouldn't like power brakes at all. In a smaller motor it would make even less vacuum.
