VIN : 2G1FP22G922101222
VEHICLE INFORMATION
Merchandising Model : 1FP87 -2002 CAMARO Z28 2-DOOR COUPE Warranty Start Date : 01/09/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : COMMUNITY CHEVROLET COMPANY
PO BOX 128
BURBANK , CA 91503-0128
(818) 843-2200
Selling Source : 13 - CHEVROLET
Site Code : 20120
Business Associate Code : 114553
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/09/2002 8 miles 01/09/2005 36008 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/09/2002 8 miles 01/09/2008 100008 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/09/2002 8 miles 01/09/2010 80008 miles
36/50000 CALIFORNIA EMISSIONS 01/09/2002 8 miles 01/09/2005 50008 miles
84/70000 CALIFORNIA SELECT COMPONENT 01/09/2002 8 miles 01/09/2009 70008 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/31/2006 174999 B N3315 - FRONT SIDE DOOR WINDOW REGULATOR MOTOR REPLACEMENT - LEFT 87662 miles
11/07/2005 158171 0 N3315 - FRONT SIDE DOOR WINDOW REGULATOR MOTOR REPLACEMENT - LEFT 74875 miles
11/07/2005 158171 0 N2144 - SWITCH - DOOR WINDOW - RIGHT FRONT - REPLACE 74875 miles
11/07/2005 158171 0 E4187 - INSULATOR AND/OR SUPPORT, REAR STABILIZER SHAFT - BOTH - R 74875 miles
11/07/2005 158171 0 D4440 - COMPRESSOR ASSEMBLY - REPLACE 74875 miles
11/07/2005 158171 0 J3480 - PUMP AND/OR GASKET, COOLANT - REPLACE 74875 miles
04/12/2005 144982 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 60037 miles
02/11/2005 137048 0 K7020 - CONVERTER ASSEMBLY, TRANSMISSION - REPLACE 55144 miles
02/11/2005 137048 0 Z7905 - 5-DAY COURTESY TRANSPORTATION 55144 miles
11/09/2004 139010 3 J4640 - STARTER MOTOR REPLACEMENT 49080 miles
10/07/2004 137806 0 E7200 - IGNITION LOCK CYLINDER REPLACEMENT 47684 miles
10/07/2004 137806 0 C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 47684 miles
02/24/2004 128786 # C6150 - HANDLE, SEAT ADJUSTER - REPLACE 39183 miles
12/01/2003 125738 # D1444 - DEFLECTOR, AIR (OUTLET VENT) - RIGHT SIDE GLASS - REPLACE 35161 miles
12/01/2003 125738 # D1442 - DEFLECTOR, AIR (OUTLET VENT) - RIGHT CENTER - REPLACE 35161 miles
12/01/2003 125738 # E0022 - COVER, WHEEL - FRONT - REPLACE 35161 miles
07/18/2003 120359 # C3140 - HOOK, COAT - R&R OR REPLACE 29094 miles
07/03/2003 119781 # C2795 - PLATE OR BOOT, CONSOLE FLOOR SHIFT - REPLACE 28295 miles
07/03/2003 119781 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 28295 miles
01/14/2002 076249 # B4241 - STRIKER, FRONT DOOR LOCK - LEFT - REPLACE 637 miles
05/25/2001 A01222 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 2G1FP22G922101222
VEHICLE BUILD
Gross Vehicle Weight Rating : 1922 kg (4238 lb) Order Number : DHFF6M
Build Date : 05/25/2001 Build Plant : 222F
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AR9 - BUCKET SEATS W/LEATHER TRIMMED SEATING SURFACES AU0 - KEYLESS REMOTE ENTRY W/ ILLUMINATED INTERIOR FEATURE W/THEFT DETERRENT ALARM SYS
AU3 - POWER DOOR LOCK SYSTEM WITH DELAYED ACCESSORY BUSS A31 - POWER WINDOWS W/ DRIVER'S SIDE EXPRESS DOWN
A90 - POWER HATCH RELEASE B84 - BODY SIDE MOLDINGS
CC1 - REMOVABLE ROOF PANELS W/LOCKS C49 - ELECTRIC REAR WINDOW DEFOGGER
C60 - AIR CONDITIONING DE4 - REMOVABLE ROOF PANEL SUNSHADES
DG7 - ELEC TWIN REMOTE SPORT MIRRORS DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE2 - RIDE & HANDLING SUSPENSION SYSTEM GU5 - LIMITED SLIP AXLE
G80 - LIMITED SLIP DIFFERENTIAL IP2 - TRIM INTERIOR DESIGN - AR9
J65 - POWER DISC FRONT & REAR BRAKES K34 - CRUISE CONTROL-ELECTRONIC
K43 - GENERATOR 102 AMP LS1 - ENG 5.7 LITER SFI V8 ENGINE
MX0 - 4-SPEED AUTOMATIC TRANSMISSION M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV NP5 - LEATHER WRAPPED STEERING WHEEL
PW7 - 16" CHROME CAST ALUMINUM QLC - P245/50 ZR-16 S/B RADIAL B/W TIRES
SLM - STOCK ORDERS STE - ST THERESE, GM OF CANADA PLANT CODE
T82 - TWILIGHT SENTINEL HEADLAMPS T96 - FOG LAMPS
UA6 - THEFT DETERRENT ALARM SYSTEM UB3 - GAGE PACKAGE WITH TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS UN0 - MONSOON 500 WATT (PEAK) PREMIUM SOUND SYSTEM ELECTRONICALLY TUNED AM/FM STEREO RADIO WITH SEEK-SCAN,DIGITAL CLOCK, AUTO- TONE CONTROL, CD PLAYER, THEFTLOCK, AND SPEED COMPENSATED VOLUME WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (INCLUDING UZ7)
UZ7 - MONSOON PREMIUM SOUND SYSTEM WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (BASE SYSTEM Z28 & UPLEVEL ON BASE COUPE) U73 - FIXED MAST ANTENNA
VG6 - NOTICE TO BUYER LABEL - 5 MPH BUMPER IMPACT VG8 - NOTICE TO BUYER LABEL
VK3 - FRONT LICENSE PLATE MOUNT V12 - POWER STEERING COOLING SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA YA7 - CALIF. ASSY. LINE EMISSION TEST
YF5 - 50-STATE LOW EMISSION VEHICLE Z28 - CAMARO Z28
1SD - PREFERRED EQUIPMENT GROUP INCLUDES: * ELEC SPEED CONTROL W/RESUME * REMOTE HATCH RELEASE * FOG LAMPS * POWER DOOR LOCK SYSTEM * POWER WINDOWS * MIRROR TWIN REMOTE ELECTRIC * LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS * REMOTE KEYLESS ENTRY * THEFT DETERRENT ALARM SYSTEM * BODYSIDE MOLDINGS * POWER DRIVER SEAT (6 WAY) 1SZ - PREFERRED EQUIPMENT SAVINGS
52I - NEUTRAL INTERIOR TRIM 522 - NEUTRAL
6BS - FRONT SPRING 7BS - FRONT SPRING
8TJ - REAR SPRING 81Q - BRIGHT RED BODY SIDE MOLDING
81U - BRIGHT RALLY RED 9TJ - REAR SPRING
