Thread: pcm wire
06-25-2016, 04:59 AM #1
06-25-2016, 05:29 AM #2
pcm wire
It would be easier if you could tell what pin it is spliced into.
Depending on that you could determine if it's for an after-market shift light, tach, nitrous switch, two step or just a crappy repair.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
06-25-2016, 07:11 AM #3
Does that gray cover just pop off or is it bolted on?
06-25-2016, 10:56 AM #4
The cover is an integral part of the connector. Remove the bolt in the center and carefully extract the connector. Ensure that you disconnect the battery first before messing with it. If you can post the pin number I can tell you what it is spliced into.
Wire Mod
By kenro23 in forum General HelpReplies: 61Last Post: 05-01-2012, 05:25 AM -
vss wire
By scubamark3995 in forum Automatic TransmissionReplies: 22Last Post: 11-24-2010, 03:06 AM -
fly by wire
By NEXSTAR7 in forum External EngineReplies: 2Last Post: 06-27-2009, 02:56 PM -
I-wire mod
By CamaroFan71 in forum General HelpReplies: 7Last Post: 03-19-2008, 09:06 PM -
wire mod
By nastyz1 in forum Appearance SectionReplies: 7Last Post: 04-27-2006, 04:40 PM
