Results 1 to 3 of 3
Thread: Finding GM PIDs
10-06-2010, 09:24 PM #1
- Mar 2008
- NYC
Navy Blue Metallic- 2000 T/A Firehawk M6
Finding GM PIDs
hello. I am setting up a bluetooth scan device to pair with my cell phone so that I can use the phone as secondary gauges and for troubleshooting. The software i installed has a list of GM extended PID's along with the ability to add more if i have the relevant hex data and formulas etc.
I haven't had much luck in finding a complete list of the GM OBD II PIDs and was wondering if anyone here had them. I don't need any kind of uploadable data as i don't mind programming it into the phone manually. In fact if i'm lucky the PID list is already complete and i'm not missing anything! I know for a fact it already has Knock retard, Knock retard alternative and knock sensor active counter. as well as a bunch of other extended PID's for GM. Again. i'm looking for the list more to make sure i have everything.
If no such list is readily available perhaps simply a listing of what readouts i should be able to access?
Thank you
10-07-2010, 07:43 AM #2
- Apr 2008
- Madison, WI
here's a list of all the stuff you can read on a GM Tech 2 scan tool
A/C High Side Pressure
A/C Relay Command
A/C Request
A/C Status
Actual EGR Position
AIR Pump Relay
AIR Solenoid
Air Fuel Ratio
BARO
CAM Signal Input High to Low
CAM Signal Input Low to High
Clutch Pedal Position Switch
Cold Startup
Commanded EGR
Cruise Requested
Cruise Control Inhibit
Current Gear
Cycles of Misfire Data
Cylinder Mode Misfire Index
DTC Set This Ignition
Desired IAC Airflow
Desired EGR Position
Desired Idle Speed
ECT
EGR Closed Pintle Position
EGR Pintle Position
Engine Load
Engine Run Time
Engine Speed
EVAP Canister Purge
EVAP Canister Vent Valve
Fail Counter
Failures Since First Fail
FC Relay 1
FC Relay 2 and 3
FT Diag. Inhibit
Fuel Gauge Control
Fuel Level Sensor
Fuel Tank Level Remaining
Fuel Tank Pressure
Fuel Tank Pressure
Fuel Tank Rated Capacity
Fuel Trim Cell
Fuel Trim Learn
Generator L Terminal
HO2S Bank 1 Sensor 1
HO2S Bank 1 Sensor 2
HO2S Bank 2 Sensor 1
HO2S Bank 2 Sensor 2
IAC Position
IAT
IC Circuit Cylinder 1-8
Ignition 1
Inj. PWM Average Bank 1
Inj. PWM Average Bank 2
Knock Retard
Long Term FT 1 Average
Long Term FT 2 Average
Long Term FT Bank 1
Long Term FT Bank 2
Loop Status
Low Oil Lamp
Low Oil Level
MAF
MAF Frequency
MAP
MIL
Mileage Since DTC Cleared
Mileage Since First Failure
Mileage Since Last Failure
Mileage Since MIL Request
Misfire Current #1-#8
Misfire History #1-#8
Misfiring Cylinder
Misfire Revolution Status
Not Run Counter
PCM Reset
PNP (A/T only)
Park/Neutral
Reverse Inhibit (M/T only)
Revolutions With Misfire
SHRT FT Average 1
SHRT FT Average 2
Short Term FT Bank 1
Short Term FT Bank 2
Skip Shift Lamp (M/T only)
Skip Shift Solenoid (M/T only)
Spark
Start Up ECT
TCC Brake Switch
TCC Duty Cycle
TCC Enable Sol.
Total Misfire Current Count
Total Misfire Failures Since First Fail
Total Misfire Passes Since First Fail
TP Sensor
TP Angle
Traction Control
Transmission OSS
Transmission Range
Vehicle Speed
VTD Fuel Disable
Warm-Ups w/o Emission Faults
Warm-Ups w/o Non-Emission Faults
10-07-2010, 08:05 AM #3
- Mar 2008
- NYC
yay! excellent! i'll have to compare and see how complete my list is. at least it narrows down what i might have to look for!
Thank you very very much!
on a side note it would seem as though i have a decent number of these. I can spot a few right off the bat that i know don't exist currently in my software. I'll need to compile a complete list and let the hunt begin!Last edited by LSCyaL8R; 10-07-2010 at 08:08 AM.
Please help finding...
By FBracing1222 in forum External EngineReplies: 4Last Post: 06-08-2010, 07:20 PM -
Finding someone
By tornado in forum Almost Anything GoesReplies: 0Last Post: 01-31-2010, 11:41 AM -
Finding a cam
By Bad Co. in forum General HelpReplies: 5Last Post: 11-05-2009, 04:49 PM -
Help: Finding one....
By clg82 in forum Appearance SectionReplies: 11Last Post: 10-23-2009, 07:31 AM -
finding a ss
By BigVAto506 in forum Camaro / SSReplies: 3Last Post: 02-26-2007, 02:32 PM
