Results 1 to 20 of 22
    Member Bandit1's Avatar
    Philly PA
    2002 TA WS7
    to stall or not to stall that is the question
    i wanna install 3.73's in the ta in place of the 2.73's. now the question is would it be recomended to stall it higher in addition to the new gears? would the big gear difference put to much stress on the rear and break it sooner?
    thanx for all ur info
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Well to answer your ?'s . . . . . . . . . . . . . . . . . . NO it will take a lot more than your gear swap to break the rear end. Put it this way I have more then a few street cars out there that are low 11 second street cars on 175 shot with drag radials,4.10's,6 cylinder springs,and 2800-3000 stall converters and they are ok. So yes you'll be fine.
    Yes you would see an et improvement by putting a looser TQ con.
    Start with the gears it will be night and day difference. Then do the V-6 spring swap with a pair of springs from the junkyard.
    Any engine mods?
    Philly PA
    2002 TA WS7
    no engine mods just a lid and full exhaust. i want to do gears but not a TC yet
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by Bandit1 View Post
    Do it you'll be fine. Just spend the money to have it done by a PROFESSIONAL and not a friend of a friend in their garage. And I would straight up tell him if it whine's I'll be bringing it right back for you to change the set-up until it's quit like it's supposed to be. People say it's normal but it's NOT.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    a stall can easily drop your e.t by half a second, while a 3.73 wont.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Philly PA
    2002 TA WS7
    i was thinkin about gettin the gear package from thunder racing
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Just do some shopping sround and you can almost ALWAYS find somewhere running a sale on 3.73's.
    How many miles are on your car?
    Philly PA
    2002 TA WS7
    59k on the car its a 2002 thunder racing has a whole kit seals bearings everything u need for 399
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    With that low of mileage I wouldn't bother with changing the bearings they should be just fine. Save the money for other parts. All I would replace is the ring and pinion,crush sleeve,pinion seal,and fluid.
    http://store.summitracing.com/partde...5&autoview=sku
    http://store.summitracing.com/partde...rt=RMG-831044B
    http://store.summitracing.com/partde...5&autoview=sku . . . . . . X 2
    Tatasta rcleveland@barrick.c's Avatar
    Nevada
    '99 TA
    A stall WILL make your car quicker than gears. If you can't do both, do a stall. It makes more difference and it is easier to do yourself.
    Member vannatte's Avatar
    Noblesville, IN
    1998 Pontiac Trans Am A4
    What would you recommend for my car? I have a 98 with 63,000. There is a slight drip from the rear end, so would I need to change the bearings or just the gears, ring & pinion, crush sleeve, and fluid? Also, I know very little about stalls, so what would be a good stall for a DD. If you have a stall, do they always launch at the higher RPM's or do you have to be under WOT?
    1998 Trans Am, A4, SLP Loudmouth I, US Exotics WS9 ram air hood, Volant intake, 3.23's, 70k miles
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Well I can tell you for a fact unless you enjoy doing burnouts and spinning the tires I would NEVER put a high stall converter in a car with 2.73 gears. That ratio even with a rubber band tire (25.5" tall) it's still by NO means a performance ratio for a LS motor that lacks bottom end power.
    Powerstrokin LT1 > LS1's Avatar
    Aurora IL
    Trans Am owner
    former
    would it be smart to put like a 2800 stall in a daily driver with only a catback, intake, and stock 2.73 rear end?
    I plan on eventually gettin 3.73's and a cam, but would a stall be stupid at this point?
    with just 2 boltons.
    Member DemonSpeed's Avatar
    Virginia
    Pewter Metallic
    1999 Trans Am
    a stall is probably the single biggest mod you can do to an a4 car. The stall WILL drop your e.t. Mine dropped a little over 4 tenths after I put in a stall (3000 tci street fighter).
    LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
    Pics of my car
    http://community.webshots.com/user/demonspeed_ta
    Virginia beach
    SOM
    Quote Originally Posted by LS2Tuner View Post
    would this work for my car, Ive got a stock rear end on a 98 ta right now but want the 3.73 gears (130k miles on the rearend) (not trying to jack the thread)
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    Arizona
    383 Procharged & N20 Vert
    I would do a stall before gears.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by Justin23454 View Post
    Just depends on what your stock gears are.
    Virginia beach
    SOM
    like 2.23 or whatever it is.
    Philly PA
    2002 TA WS7
    thats what i have the 2.73's i thought it would make a real big difference going from 2.73's to 3.73's rather than going from 3.23's to 3.73's
    Aurora IL
    Trans Am owner
    former
    yup. i got 2.73's also.....great on gas for sure.
  1. Stall question for FI
    By 98TransAmWs-6 in forum Automatic Transmission
    Last Post: 05-26-2011, 11:20 AM
  2. stall question again (HELP)
    By stefos in forum Automatic Transmission
    Last Post: 12-26-2008, 07:21 PM
  3. Stall question
    By LETHALxLS1 in forum Automatic Transmission
    Last Post: 07-08-2007, 03:56 PM
  4. Replies: 15
    Last Post: 07-02-2007, 01:49 PM
  5. a4 Stall Question
    By pipes_ta in forum Automatic Transmission
    Last Post: 10-17-2006, 06:16 PM
