Results 1 to 3 of 3
    Vicksburg. Ms.
    pewter
    99 Trans Am
    Question my 69 chevy truck I believe have a intake sucking air.
    I have a 69 Chevy truck that will not idle unless it is set higher than needed The plugs on all but about three of the cylinders are covered with a black power like covering when driven at normal speed but will clean up if driven at high speed. I have replaced the carb with the one off my Camaro that I know is good but it does the same thing. I checked the compression and all are good I rechecked the timing to make sure it was not too high, I have done a vacuum check at idle it shows about 15 and goes to about 25 when I open the throttle. The engine is a 350 with a comp cam with a 501-501 lift that have a ruff idle, with
    vortec heads and a Edelbrock Rpm intake. I have run this setup for sometime and have never had this issue, intake sucking air?or burnt valves? I have changed the dist. cap and wires from the Camaro but the same.?The compression test showed the highest was 170 and the lowest was 140.
    98 T/A w/ mods, 00 FBVert
    Have you checked the pcv?
    Vicksburg. Ms.
    pewter
    99 Trans Am
    NO everything but the simple stuff, will do so today thinks I hope that's the cause.
  1. ls1 into 72 chevy truck.
    By chevylover in forum General Help
    Last Post: 01-19-2010, 11:45 PM
  2. 6.0 truck ls1 intake
    By whitez28onspray in forum External Engine
    Last Post: 01-02-2007, 08:47 AM
  3. 99 chevy truck or trade for LS1
    By turbota02 in forum Vehicles For Sale / Trade
    Last Post: 07-19-2006, 02:26 PM
  4. OBS Chevy truck AIRAID intake kit $80 shipped
    By whitelightnin99 in forum Parts For Sale / Trade
    Last Post: 07-17-2006, 07:36 AM
  5. 68 chevy truck for sale
    By speed disease in forum Vehicles For Sale / Trade
    Last Post: 10-04-2005, 05:07 AM
