Results 1 to 14 of 14
Thread: Need some tips on DIY R&R.
11-20-2014, 12:58 AM #1
So, the day before I was scheduled to take my car in for maintenance, I noticed the rattling that prompted the other thread about the LS3.
However, the car was already due for some other work.
I need to replace my bump stops and my LCAs.
I'm wondering: with the LCAs, is there anything I need to consider when removing or installing them? Does the suspension need to be loaded? Unloaded? Any other tips? They look like a simple swap: just take the old ones out with a wrench and put the new ones in, but I've learned not to make assumptions when it comes to working on cars.
In case it matters, I have bolt-in SFCs on the car.
11-20-2014, 02:59 AM #2
Only do one side at a time. The rear will move a bit, but you can use a screwdriver or prybar to move things back into place to get the bolts through the holes. Make sure the car is supported by the body and not under the rear axle when you do this. You will need a floor jack under the axle though to hold it in place and to make minor adjustments. Absent rusted bolts that are seized up in the stock bushings... it is a simple swap.
11-20-2014, 07:01 AM #3
Are they stock or aftermarket, adjustable?
If adjustable use the stock LCA to get as close to the length needed as possible. Go bolt hole to bolt hole. I took a 6" long bolt in the same size as the LCA hardware to line it up.
11-20-2014, 01:23 PM #4
The ones coming off are rod-end, adjustable. The ones going on will be UMI poly-roto adjustable. I was thinking I would just check the length before removing the currently installed ones, make the adjustments to the new ones and then R&R.
Based on what you guys are saying, I'm thinking I can use my jack-stands under the body, and then put the jack under the diff.
When you say do one side at a time, does that mean to lift only one side of the car at a time, or is it okay to lift both sides, but to leave one side as is until the other side is torqued down?
11-20-2014, 01:33 PM #5
Good to lift both sides, just remove only one LCA at a time.
11-20-2014, 01:45 PM #6
Once you get both sides installed, snug but do not tighten the bolts all the way. Put your stands back under the axle to load the suspension to a level height then do your final torque to 87 lb ft. If you torque the bolts down while the suspension is unloaded you may get some binding.
11-20-2014, 02:26 PM #7
One thing to keep in mind is that the bolt holes in the body are smaller than the bolt holes in the LCAs. I took my LCAs off and drilled the bolt holes in the body out. Installed bigger bolts. That took a lot of noise and slap out of the rear end. It used to clack going over speed bumps and steel gate tracks set in parking lots, etc, but not any more. I used a stepped drill bit and a flexible tip extension to do mine. There is no room to get a drill in there. Maybe a right angle drill, but the flex extension did the trick nicely.
11-20-2014, 04:44 PM #8
I thought the torque on the suspension bolts was 75 lb.ft.?
11-20-2014, 06:34 PM #9
11-20-2014, 08:48 PM #10
Thanks, guys. As much as I've learned in school and with research, I still feel like a newb. :P
If I remember correctly, Jeff is correct. When I installed my SFCs, the torque spec given by UMI was 75 ft.lbs. for the front end of the bolt. Could it be that the rear end has a different torque spec?
Keith, I like your idea about using a bigger bolt.
Does anyone know why the LCAs are designed with a bigger hole?Last edited by Naaman; 11-20-2014 at 08:50 PM.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
11-20-2014, 09:26 PM #11
So it's easier to get them to line up to bolt in. Almost everything you buy that uses bolt holes to bolt to something else is like that. It allows for bolt hole spacing tolerance deviation also.
11-20-2014, 11:41 PM #12
Oh, okay. I was imagining significantly bigger holes, but it sounds like they are just "bigger enough" by what you're saying.
11-21-2014, 05:12 AM #13
That's just a guess, but I'm assuming your assumption is correct as far as the bolt hole size in comparison.
11-23-2014, 07:40 AM #14
The 87 lb ft torque spec is what the factory service manual shows for the LCAs. If the manufacturer shows something different (different bushing materials) definitely go with that.
For sale.. Corsa Exhaust tips. Quad tips (2/side)
By 5abivt in forum Parts For Sale / TradeReplies: 2Last Post: 09-05-2009, 11:14 PM -
Need tips again
By axcellclan in forum Parts Wanted / TradeReplies: 2Last Post: 12-31-2008, 05:07 PM -
SLP tips?
By Shermanator86 in forum Appearance SectionReplies: 3Last Post: 12-13-2007, 11:49 AM -
About to buy a WS6, any tips?
By Jimbro727 in forum Firebird / WS6Replies: 39Last Post: 10-19-2007, 02:51 PM -
Corsa knock off tips, or GMMG Oval tips?
By BlkBirdWS623 in forum Appearance SectionReplies: 13Last Post: 04-10-2006, 02:28 PM
