Results 1 to 13 of 13
08-14-2012, 08:21 AM #1
- Aug 2012
- Montreal, Qc, Canada
Difference between GM clutches: 12581650 and 19182561?
Online searches indicate that 12581650 is the clutch kit to use on a 1998 LS1 Trans Am these days.
Other numbers that pop up are 19182561 (which is also referred to as 381408 on some search results, I believe both numbers are printed on the AC Delco labels).
What's the difference between these two?
08-15-2012, 06:38 AM #2
- Aug 2012
No one with any info on these two part numbers? Both appear self-adjusting, both listed as LS1 applicable. So what's the difference?
I really need to get this car back on the road.../Steve
1987 Trans Am GTA
1998 Trans Am WS6
1978 Trans Am L78
1978 Trans Am W72 4-speed WS6
08-15-2012, 11:47 AM #3
What's the cost? Have you considered upgrading to say a LS7 clutch? Might not be that much of a price difference and it's a better clutch.
08-15-2012, 12:29 PM #4
- Aug 2012
It's more a matter of the fact I actually have a 381408 in my basement from a long long long time ago, and all my current research is saying 12581650 is the LS1 clutch. So I'm wondering what is the difference between AC Delco part numbers and "genuine GM".
As for LS7 clutch, I probably own one of the last remaining bone stock LS1s in existence. LOL! And it spends a lot of time in traffic to work and back, so clutch feel and performance needs to remain as close as possible to stock. To put in perspective how happy I've been with the stock setup, in the few times I've taken the car down the 1/4, I've never ever experienced any hangings or problems, that's how babied this car is (from a WOT point of view). I'm really afraid to go to all the trouble and "upgrade" and end up with a car I don't like to drive on a daily basis. No room for a weekend warrior here. :-)
This is all new to me... I've never actually had a manual transmission car that needed a clutch change. My clutches usually outlast my cars!
08-15-2012, 12:51 PM #5
I see. Well the LS7 is what is used in Corvettes. Pretty much the same exact feel as stock. Can't help you on the numbers, I went with a Spec Stage 3+
I get it too. My car was bone stock except for exhaust for the first 8 years I owned it. Only had 12K miles on it in 8 years. Then, I got the mod itch and tens of thousands of dollars later in mods here I am and the car has 27K miles on it.
It happens sooner or later. It's inevitable lol.
08-15-2012, 01:32 PM #6
Op, I have had the LS7 clutch going on 2.5 yrs and have put on about 50000 miles on it. I rate it much better then the stock one and no issues. The feel of it is that the pressure plate grabs very well. It may take a little time to get use to shifting because like all things new it will feel different from before but after break in you'll love it. You should have no worries if you upgrade to it. IMHO I think this should have been the stock clutch.
Also like Jon said, when the mod bug bites, it bites hard.....
08-15-2012, 02:10 PM #7
- Jun 2011
- Branchville, NJ
LS7 clutch is the way to go. You get a stock feel but also get a much tougher unit that should last longer and take more abuse. The cost is not that much more then the stock unit and no mods are required.
08-15-2012, 03:23 PM #8
08-16-2012, 01:10 PM #9
AC Delco LS6 clutch kit is the one you have in your basement. The pre 01 LS1's came equipped with the LS1 clutch kit.
The difference between the two is the pressure plate. The LS6 holds better and was actually used in the 01-02 LS1's.
The LS1 clutch is not produced anymore and was replaced with the better LS6 clutch.
Hope this helps.
08-16-2012, 10:19 PM #10
08-17-2012, 04:39 AM #11
Decal. All the 35th LE Camaro's came that way so I'm not sure where to even tell you to look.
08-17-2012, 11:08 PM #12
08-18-2012, 04:42 AM #13
Thanks! Emblem Pros came to mind just now. Keep us up to date!
Question: 3-4 clutches
By 383ls6 in forum Automatic TransmissionReplies: 0Last Post: 09-21-2013, 05:18 PM -
Question: Spec clutches
By Same ol Situation in forum Manual TransmissionReplies: 42Last Post: 07-22-2011, 03:49 PM -
ls1,ls7 clutches
By ssmoken in forum Manual TransmissionReplies: 4Last Post: 04-13-2007, 11:57 AM -
Clutches!!
By orangecrusht/a in forum Manual TransmissionReplies: 4Last Post: 04-10-2007, 12:31 PM -
Clutches
By bazaz.j in forum Manual TransmissionReplies: 2Last Post: 07-25-2006, 07:28 AM
