Thread: trouble code P0751
09-19-2007, 03:34 PM #1
trouble code P0751
what does the "stuck off" condition on solenois "A" mean?
09-19-2007, 04:29 PM #2
- Jul 2005
- Jacksonville, FL
Don't know what the problem is, but think it can also mean solenoid A performance too. Are you running the stock TC? Found this for you, don't know if it helps: www.ls2.com/boggs/a4/DTC%20P0751%205.7.htm
09-20-2007, 09:31 AM #3
yes and that link does help a lot thanks
09-20-2007, 06:18 PM #4
It means the trans comanded the solenoid on but the gear expected did not occur more than likely its a bad solenoid I usually suggest you replace both of the shift solenoids at once they are about 30 dollars each .
09-21-2007, 10:40 AM #5
how much would it be for the whole electrical part of the trany and who do u recommend I by it from?
09-21-2007, 01:42 PM #6
Well you can buy all of it from several places on line but I really dont think thats nessesary . If I were you I would just goto the GM dealer and get the two shift solenoids and replace the trans filter and fluid while your in there,
09-21-2007, 02:24 PM #7
09-24-2007, 04:23 PM #8
10-29-2007, 07:46 AM #9
I had the same exact code thrown, replaced shift solenoid A. something with shift lock being off...
take off the transmission pan, then 1 bolt... the shift solenoid pops out. $30 bucks part, 1 hr labor.Last edited by djvaly; 11-14-2007 at 04:22 PM.
Trouble Code Help?
By SS_Crazy in forum Camaro / SSReplies: 1Last Post: 05-27-2007, 11:02 AM -
Trouble code, need help
By wicked1 in forum Computer & TuningReplies: 3Last Post: 04-30-2007, 07:57 PM -
Trouble Code!!! 26 & 61
By SloLt1Camaro in forum LT1Replies: 3Last Post: 10-31-2006, 01:23 PM -
Trouble code help
By GLUMAKER in forum General HelpReplies: 5Last Post: 04-10-2006, 05:37 PM
