Results 1 to 3 of 3
Thread: Misfire
05-23-2010, 09:50 AM #1
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
Misfire
My ses light just went off and the code is for a cylinder six misfire. The car is running very rough. What are some things that would cause a misfire? Also there is a very noticable ticking sound at idle. Any help would be appreciated.
05-23-2010, 09:59 AM #2
Bad, cracked or fouled spark plug; a bad wire connection; moisture in the plug boot; a broken plug wire; a burned plug wire; or a bad coil. That should about cover it. Not a bad idea to pull that wire and plug to look things over. Upon reinstallation, you should hear or feel the plug boot click on and the coil boot should double click when properly seated.
05-23-2010, 08:10 PM #3
- Nov 2006
- Broken Arrow, OK
Check the coil, plug, plug wire and injector. Most likely one of those is not working. You may have to move them around to another cylinder to pinpoint the problem.
Question: Misfire???
By motorhead584 in forum General HelpReplies: 8Last Post: 04-06-2014, 02:56 AM -
Help: could a bad o2 cause a misfire?
By SteveCZ28 in forum General HelpReplies: 18Last Post: 07-25-2011, 04:10 PM -
Misfire cyl #3 HELP!!!!
By blownh2x in forum General HelpReplies: 16Last Post: 03-28-2009, 11:06 AM -
Misfire on #1
By INeedLS1 in forum General HelpReplies: 4Last Post: 04-22-2007, 06:44 PM -
3.8 misfire
By andrew rs in forum V6Replies: 4Last Post: 03-10-2007, 08:33 AM
