Results 1 to 10 of 10
Thread: LS6 manifold conversion
07-27-2009, 08:19 AM #1
- Mar 2007
- oxnard, ca.
red and black- 1999 Formula/WS6
recently purchased new LS6 manifold and coolant crossover tubes and block offs. im hoping someone has the part numbers and a place to order the gaskets i need fo the install. thanks for the help!!
07-27-2009, 09:08 AM #2
All of the LS6 intakes I've seen have come with the new gaskets.
If not, just go down to your local auto parts store and order some, the LS6 ones are the same as the stock ones.
07-27-2009, 06:33 PM #3
- Mar 2007
- oxnard, ca.
well im hoping i can order the parts before i get home. im deployed right now, and dont wanna have to go to the dealership when i get back.
07-27-2009, 11:29 PM #4
You don't need new gaskets, you can use the ls1 gaskets.
07-28-2009, 12:11 AM #5
- Mar 2007
- oxnard, ca.
so you dont think there will be a problem using all the old gaskets, even for the coolant line?
07-28-2009, 03:33 AM #6
they are not gaskets they are rubber o-rings on the water lines and rubber gaskets on the intake,should be on the intake and waterlines already.
easy swap did mine this past weekend took me 3hr.
3 main things.
1. unhook the vacume line from the brake booster(or you will break the oil pressure sender)
2. cut 5 peices of 5/16 rubber fuel line at 1 inch. put 2 on the back 2 bolts passanger side and 3 on the back 3 drivers side(holds the bolts up to remove)
3.lift the front of intake up and pull forward about 8 inches while turning the front twards the drivers side(reach around back pull off small air line unhook electric plug)then pull out guiding the brake booster line around oil sender
also unclip the knock sensor clip from the drivers side rear of intake.
also pull the black tape off the 2 clips that hold the knock sensor to the old water line and discard them.
07-28-2009, 08:16 AM #7
- Mar 2007
- oxnard, ca.
wow, thanks for the info, im looking forward to the install.
07-28-2009, 09:51 AM #8
just another option you don't have to install the new lines you can grind the fins down to accomadate your current ones
http://www.ls1tech.com/forums/genera...-manifold.html
you already go the kit but just another option.
07-28-2009, 11:45 AM #9
- Jan 2006
- Shepherd, Michigan
i used clothes pins..worked awsome..better then having to cute rubber hose etc.
07-30-2009, 05:56 AM #10
- Mar 2007
- oxnard, ca.
ive heard of people doing that, i figured since it wasnt that expensive, i might as well do it by the book. thanks though.
T56 conversion
By 98 Trans-am in forum Manual TransmissionReplies: 7Last Post: 08-09-2010, 06:56 PM -
ls1 to ls6 conversion help.
By BITEMALOT in forum General HelpReplies: 20Last Post: 01-29-2010, 06:56 AM -
WTB/WTT for a t56 conversion
By itSSlow98 in forum Parts Wanted / TradeReplies: 4Last Post: 10-18-2008, 06:19 AM -
does anyone know the conversion from 1/8th to 1/4
By jimmybling31 in forum Almost Anything GoesReplies: 15Last Post: 05-04-2008, 06:33 PM -
A4 to m6 conversion?
By Joel Nicewander in forum Automatic TransmissionReplies: 1Last Post: 06-01-2006, 08:52 AM
