Thread: Fuel line disconnection?
07-18-2007, 02:48 PM #1
I have the 3/8 fuel line disconnect plastic tool, but the fuel line will still not budge. Has anyone had this problem too? Is there a proper method in doing this?
07-18-2007, 05:12 PM #2
- Aug 2006
- Madrid, Iowa
red- 02 trans am ws6
Push in on both the tool and the line (towards each other, then try to seperate), takes abit of patience. wiggle it alittle and it should pop out (make sure you have no fuel pressure in the line/rails)
07-18-2007, 05:55 PM #3
Yeah I've been trying that... it's still not coming off. I'm going to buy a metal tool tomorrow. I'm hopeing that will help. Then i'll continue with that method.
07-19-2007, 12:59 PM #4
plastic tool- 5 hours (no success)
metal tool- 5 seconds (success)
screw the plastic fuel line disconnect tools.. they arent worth anything
07-21-2007, 06:54 PM #5
I used the plastic ones last time and the first time I used them it popped right off. The second time it took a while longer and really tested my patience. I finally got it after some struggling.
I can PM you the correct combination of swear words it took to get it apart if you'd like. There was a pretty long list of swear words involved. I almost had to take a second breath to say them all at once like that.
07-21-2007, 08:25 PM #6
- Aug 2006
- Madrid, Iowa
thats funny!
07-21-2007, 10:24 PM #7
update:
I just finished up pulling my intake to change out my knock sensors and used the plastic release again. Got it first try so I had to take back some of the things I called it last time.
07-22-2007, 08:09 AM #8
- Nov 2006
- Earth
I had mine fold over inside of itself. I think the trick is if it doesn't go easily then pull the tool out and inspect it. Then try it again. Just like you, I've had it work like a breeze one time then give me fits the next.
07-23-2007, 12:35 PM #9
Funny, I didn't disconnect the fuel line at all to do my intake swap. Just took the rails off and moved them to the side...
ls1 fuel rail 98-? single fuel line
By LEADSLED in forum Parts Wanted / TradeReplies: 4Last Post: 12-08-2011, 01:50 PM -
For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
By '99 SLP#24 in forum Parts For Sale / TradeReplies: 2Last Post: 01-11-2011, 06:24 PM -
kinked fuel line while changing fuel filter
By krese in forum Firebird / WS6Replies: 4Last Post: 10-04-2010, 03:02 PM -
Fuel line kit
By Naf in forum GTOReplies: 0Last Post: 07-25-2007, 04:39 AM -
Removing fuel supply line from fuel rail
By GatorSS in forum General HelpReplies: 8Last Post: 01-02-2007, 05:10 PM
